Arduino Forum
Using Arduino => Storage => Topic started by: malonph on Mar 13, 2011, 03:47 pm
Title: Arduino not working properly after shorting ftdi ic pins.
Post by: malonph on Mar 13, 2011, 03:47 pm
Hello,
I was reading the contents of some 24lcXX eeproms I had lying around, everything was going fine until I shorted gnd and some ftdi pins. From there no further reading was possible.
I started thinking that the short caused the premature death of the eeprom.
But I tried two more eeproms with negative results.
Apart from this the Arduino seems to work properly, I can upload sketches and use serial.* with no strange behavior. So I don't know where the problem is.
Can someone help me with this?
Thank you very much.
Paco
Title: Re: Arduino not working properly after shorting ftdi ic pins.
Post by: malonph on Mar 16, 2011, 06:11 pm
Just in case someone find this useful,
It seems that the short f**ked the ftdi chip up but I managed to get it fully working again by reprogramming the chip following the instructions you can find in the page below.
http://www.arduino.cc/playground/Main/FTDI
Paco
