Arduino Forum
International => India => Topic started by: sainikshipth on Jun 25, 2018, 08:35 am
Title: Need help with logic
Post by: sainikshipth on Jun 25, 2018, 08:35 am
Hey, I am working a water sensor, but I cant seem to make it stop after one loop no matter what i do.
here is the code
#include <SPI.h>
#include <Servo.h>
Servo ser;
  pinMode(A0, INPUT);
  pinMode(6, OUTPUT);
  ser.attach(A4);
void ser1(int, int);
void serp(int);
void serm(int);
int pos = 0;
int strt = 0;
  int count = 0;
  int a = analogRead(A0);
  // print out the value you read:
  Serial.println(a);
  if (a != 0)
    count = 1;
    Serial.println("serp");
    serp(count);
  else if (a == 0)
    count = 1;
    Serial.println("serm");
    serm(count);
  delay(300000);
void ser1(int pos, int count)
  Serial.println("ser1");
  if (pos == 1)
    Serial.println("servo++");
    do
      ser.write(pos);
      delay(50);
      pos++;
    } while (pos <= 45);
    count = 0;
    Serial.println("servo--");
    do
      ser.write(pos);
      delay(50);
      pos--;
    count = 0;
 return;
void serp(int count)
  if (count != 0)
    int pos = 0;
    digitalWrite(9, HIGH);
    ser1(pos, count);
   return;
void serm(int count)
  if (count != 0)
    int pos = 45;
    digitalWrite(9, LOW);
    ser1(pos, count);
  return;
The motor stats off just fine and keeps rotating in that direction. I've tried everything( from my knowledge)
I've also tried including serial.print(); its always struck at "servo--", and won't budge.
I want the arduino to check for the sensor inputs every 5 minutes and iterate only once .
and repeat the same.
How do I do that? and it'd be great if someone could correct my logic/code.
P.S- I've never tried anything like this and I'm out of ideas
Title: Re: Need help with logic
Post by: AWOL on Jun 25, 2018, 01:53 pm
do
      ser.write(pos);
      delay(50);
      pos--;
maybe you're just not waiting long enough
Post by: sainikshipth on Jun 26, 2018, 10:24 am
So ill try changing to time to 500, ill get back
Post by: AWOL on Jun 26, 2018, 10:26 am
Need help with logic.
Post by: sainikshipth on Jun 26, 2018, 10:51 am
So my logic isn't right? Could you be more specific where i went wrong? It'd be a great help.
Post by: sainikshipth on Jun 27, 2018, 07:33 am
Didn't help
