Arduino Forum
Topics => Interactive Art => Topic started by: Jramcam on Jul 07, 2018, 10:33 pm
Title: Problem with delay color sensor TCS3200
Post by: Jramcam on Jul 07, 2018, 10:33 pm
Hi, i am making an art project and i need to receive RGB data from a TCS3200 sensor.
The problem is that i can only delay the function 4000 ms, the moment i push down the value, the info i receive gets corrupted. (0 values on RGB or just getting R values from RGB).
Here's the code (it's the code from the network with some little changes)
#include <TimerOne.h>
#define S0     6
#define S1     5
#define S2     4
#define S3     3
#define OUT    2
int   g_count = 0;    // count the frequecy
int   g_array[3];     // store the RGB value
int   g_flag = 0;     // filter of RGB queue
float g_SF[3];        // save the RGB Scale factor
// Init TSC230 and setting Frequency.
void TSC_Init()
  pinMode(S0, OUTPUT);
  pinMode(S1, OUTPUT);
  pinMode(S2, OUTPUT);
  pinMode(S3, OUTPUT);
  pinMode(OUT, INPUT);
  digitalWrite(S0, LOW);  // OUTPUT FREQUENCY SCALING 2%
  digitalWrite(S1, HIGH);
// Select the filter color
void TSC_FilterColor(int Level01, int Level02)
  if(Level01 != 0)
    Level01 = HIGH;
  if(Level02 != 0)
    Level02 = HIGH;
  digitalWrite(S2, Level01);
  digitalWrite(S3, Level02);
void TSC_Count()
  g_count ++ ;
void TSC_Callback()
  switch(g_flag)
    case 0:
         //Serial.println("->WB Start");
         TSC_WB(LOW, LOW);              //Filter without Red
         break;
    case 1:
         //Serial.print("->Frequency R=");
         //Serial.println(g_count);
         g_array[0] = g_count;
         TSC_WB(HIGH, HIGH);            //Filter without Green
         break;
    case 2:
         //Serial.print("->Frequency G=");
         g_array[1] = g_count;
         TSC_WB(LOW, HIGH);             //Filter without Blue
         break;
    case 3:
         //Serial.print("->Frequency B=");
         //Serial.println("->WB End");
         g_array[2] = g_count;
         TSC_WB(HIGH, LOW);             //Clear(no filter)
         break;
   default:
         g_count = 0;
         break;
void TSC_WB(int Level0, int Level1)      //White Balance
  g_count = 0;
  g_flag ++;
  TSC_FilterColor(Level0, Level1);
  Timer1.setPeriod(1000000);             // set 1s period
  TSC_Init();
  Timer1.initialize();             // defaulte is 1s
  Timer1.attachInterrupt(TSC_Callback);
  attachInterrupt(0, TSC_Count, RISING);
  delay(4000);
  for(int i=0; i<3; i++)
    //Serial.println(g_array);
  g_SF[0] = 255.0/ g_array[0];     //R Scale factor
  g_SF[1] = 255.0/ g_array[1] ;    //G Scale factor
  g_SF[2] = 255.0/ g_array[2] ;    //B Scale factor
  //Serial.println(g_SF[0]);
  //Serial.println(g_SF[1]);
  //Serial.println(g_SF[2]);
   g_flag = 0;
   String message = "" ;
    //Serial.println(int(g_array * g_SF));
    message = message + int(g_array * g_SF) + ",";
   Serial.println(message);
   delay(4000);
