Arduino Forum
Using Arduino => Programming Questions => Topic started by: nikk4s on Jul 11, 2018, 04:40 pm
Title: Need help getting Modbus input to pwm output.
Post by: nikk4s on Jul 11, 2018, 04:40 pm
I am sending modbus word arrays to an arduino mega2560.  I have been able to get the analog read part working but cannot seem to get the analog write to pwm pins working.
#include <Mudbus.h>
#include <SPI.h>
#include <Ethernet.h>
//#include "Mudbus.h"
Mudbus Mb;
//Function codes 1(read coils), 3(read registers), 5(write coil), 6(write register)
//signed int Mb.R[0 to 125] and bool Mb.C[0 to 128] MB_N_R MB_N_C
//Port 502 (defined in Mudbus.h) MB_PORT
  uint8_t mac[]     = { 0x90, 0xA2, 0xDA, 0x00, 0x51, 0x06 };
  uint8_t ip[]      = { 192, 168, 0, 59 };
  uint8_t gateway[] = { 192, 168, 0, 1 };
  uint8_t subnet[]  = { 255, 255, 255, 0 };
  //Avoid pins 4,10,11,12,13 when using ethernet shield
  delay(5000);
  //   INPUTS
  //  OUTPUTS
  int five = 0;
  int six = 0;
  int seven = 0;
  int eight = 0;
  int nine = 0;
  int twelve = 0;
  int thirteen = 0;
  Mb.Run();
  //Analog inputs 0-1023
  Mb.R[0] = analogRead(A0); //pin A0 to Mb.R[0]
  Mb.R[1] = analogRead(A1);
  Mb.R[2] = analogRead(A2);
  Mb.R[3] = analogRead(A3);
  Mb.R[4] = analogRead(A4);
  Mb.R[5] = analogRead(A5);
  Mb.R[6] = analogRead(A6);
  Mb.R[7] = analogRead(A7);
  Mb.R[8] = analogRead(A8);
  Mb.R[9] = analogRead(A9);
//  Mb.R[10] = analogRead(A10); //work on removing
//  Mb.R[11] = analogRead(A11); //work on removing
//  Mb.R[12] = analogRead(A12); //work on removing
//  Mb.R[13] = analogRead(A13); //work on removing
  Mb.R[10] = analogRead(A14);
  Mb.R[11] = analogRead(A15);
   //Digital inputs
  //Analog outputs 0-255
//  analogWrite(4, Mb.R[12]); Leave this one out
//  analogWrite(5, Mb.R[12]);
//  analogWrite(6, Mb.R[13]);
//  analogWrite(7, Mb.R[14]);
//  analogWrite(8, Mb.R[15]);
//  analogWrite(9, Mb.R[16]);
//  analogWrite(12, Mb.R[17]);
//  analogWrite(13, Mb.R[18]);
  five = Mb.R[12];
  six = Mb.R[13];
  seven = Mb.R[14];
  eight = Mb.R[15];
  nine = Mb.R[16];
  twelve = Mb.R[17];
  thirteen = Mb.R[18];
  analogWrite(5, five);
  analogWrite(6, six);
  analogWrite(7, seven);
  analogWrite(8, eight);
  analogWrite(9, nine);
  analogWrite(12, twelve);
  analogWrite(13, thirteen);
  //Digital outputs
Title: Re: Need help getting Modbus input to pwm output.
Post by: UKHeliBob on Jul 11, 2018, 05:05 pm
None of your pins appear to be set as outputs.  Would that help, do you think ?
What do you see if you print the values that you are trying to output ?
Are you trying to write an int (the five variable) to a PWM pin that takes a maximum value of 255 ?
Post by: Juraj on Jul 11, 2018, 05:19 pm
You do not need to call pinMode() to set the pin as an output before calling analogWrite().
https://www.arduino.cc/reference/en/language/functions/analog-io/analogwrite/ (https://www.arduino.cc/reference/en/language/functions/analog-io/analogwrite/)
Post by: one2many on Jul 11, 2018, 06:21 pm
the pwm setup is missing.. set the dividers, period, etc
Post by: UKHeliBob on Jul 11, 2018, 07:52 pm
Not needed if you use analogWrite() and want the standard output.
