Arduino Forum
Community => Gigs and Collaborations => Topic started by: GadgetCanyon on Jul 17, 2018, 05:25 pm
Title: Compare logged data on SD card to current reading - £25 for working answer
Post by: GadgetCanyon on Jul 17, 2018, 05:25 pm
Hello,
I am using an Arduino Nano and trying to make a data logger for a project in my shed. It currently records pressure and temperature ever 10 seconds. Similar to a barometer I guess. The code below currently logs the data however the problem is the next bit I'm trying to do. I would like to be able to compare the current result for both temp and pressure with a previous result 24 hours ago recorded on an SD card and turn an LED on if they are the same. The code will run for about 7 days at a time and i'll manually reset it.
I am happy to reorganize the way the information goes to the SD card if it makes it easier.
I currently have no idea how to do this and would really appropriate some help.
#include <Arduino.h>
#include <TM1637Display.h>  // adds 8 led library
//code for ADS1115
#include <Wire.h>                        // needed for scl and sda
#include <Adafruit_ADS1015.h>   //ADS library
Adafruit_ADS1115 ads1115;         // construct an ads1115 at address 0x49
// Define temp sensor stuff
#include <Wire.h>
#include "TSYS01.h"
TSYS01 sensor;
//Include SD card reader set up
#include <SD.h>
#include <SPI.h>
File myFile;
//Add rtc
#include "RTClib.h"
RTC_PCF8523 rtc;
char daysOfTheWeek[7][12] = {"Sunday", "Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday"};
// Module connection pins (Digital Pins) for LED
#define CLK 3   // set pins for led
#define DIO 4   // set pins for led
TM1637Display display(CLK, DIO);
#define CLK1 5   // set pins for led
#define DIO1 6   // set pins for led
TM1637Display display1(CLK1, DIO1);
// The amount of time (in milliseconds) between tests
#define TEST_DELAY   1000
const float  OffSet = 0.5 ;
float V, P;
float L1; //Pressure sensor reading
float T1;  //Temp sensor reading
int pinCS = 53; // Look this up for SD card  - Pin 10 on Arduino Uno
int Sec;
      //for loop rtc function
      //String Sec = "";    // string to hold input
      //int Sec1;
int Y; //for finding previous value
  Serial.begin(9600);        // open serial port, set the baud rate to 9600 bps
  Serial.println("/** Water pressure sensor demo **/");
  //ADS1115 code
  ads1115.begin();  // Initialize ads1115 188uV/bit
  // for temp sensor
    Wire.begin();
    sensor.init();
 /* //Part of the rtc code
   while (!Serial) {
    delay(1);  // for Leonardo/Micro/Zero
 // Serial.begin(57600);
  if (! rtc.begin()) {
    Serial.println("Couldn't find RTC");
    while (1);
  if (! rtc.initialized()) {
    Serial.println("RTC is NOT running!");
    // following line sets the RTC to the date & time this sketch was compiled
    //rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
    // This line sets the RTC with an explicit date & time, for example to set
    // January 21, 2014 at 3am you would call:
    // rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
  // SD Card Initialization
  pinMode(pinCS, OUTPUT);
  if (SD.begin())
    Serial.println("SD card is ready to use.");
  } else
    Serial.println("SD card initialization failed");
    return;
  rtc.begin();
 // rtc startup
     DateTime now = rtc.now();
Sec = ((now.second()));
//Sec1=(Sec.toInt());
if ((Sec)==00||Sec==10||Sec==20||Sec==30||Sec==40||Sec==50)
  int k;
  int16_t adc0, adc1, adc2, adc3; //create int for adc0 used later
  uint8_t data[] = { 0xff, 0xff, 0xff, 0xff };
  display.setBrightness(1); // set the level of brightness
  display1.setBrightness(1);//sets brightness of small (second) LED display
  adc0 = ads1115.readADC_SingleEnded(0); // read data from ads1115
//Temp Sensor info
  sensor.read();
  T1=sensor.temperature();
//Connect sensor to Analog 0
  V = (adc0 * 0.1875)/1000;         //adc0 * ((4.0 / 32768));     //Sensor output voltage  32767 in the max division for 15bits
  P = (V - OffSet);             //account for 0.5v sensor gives a 0psi
  L1 = (P*374);                    // pressure read by sensor 150psi/4v=37.4
 //  Serial.print(" Pressure:");
 // Serial.print(L1);
 // Serial.println(" psi");
 //Serial.println();
// Show decimal numbers with/without leading zeros
  bool lz = false;             //true all digits on, false only digits used on
    //display.showNumberDec((L1),lz);
    display.showNumberDecEx((L1*10), (0x80 >> 0), lz);   // this statement adds a decimal point (0x80>>1) sets the decimal point location, change "1" to move it
    display1.showNumberDecEx((T1*10), (0x80 >> 2), lz);  // Temp sensor info on second LED
 // This section is for storing values to SD card
  myFile = SD.open("Nautilus.txt", FILE_WRITE);
  if (myFile) {
    myFile.print(now.day(), DEC);
    myFile.print('/');
    myFile.print(now.month(), DEC);
    myFile.print('/');
    myFile.print(now.year(), DEC);
    myFile.print(' ');
    myFile.print(now.hour(), DEC);
//    myFile.print(':');
    myFile.print(now.minute(), DEC);
    myFile.print(now.second(), DEC);
    myFile.print(" ");
    myFile.print(float(T1));
    myFile.print(' ');
    myFile.println(float(L1));
    myFile.close(); // close the file
  // if the file didn't open, print an error:
  else {
    Serial.println("error opening test.txt");
  //Part of rtc code
    Serial.print(now.year(), DEC);
    Serial.print('/');
    Serial.print(now.month(), DEC);
    Serial.print('/');
    Serial.print(now.day(), DEC);
    Serial.print(" (");
    Serial.print(daysOfTheWeek[now.dayOfTheWeek()]);
    Serial.print(") ");
    Serial.print(now.hour(), DEC);
    Serial.print(':');
    Serial.print(now.minute(), DEC);
    Serial.print(':');
    Serial.print(now.second(), DEC);
    Serial.println();
    Serial.print("Temperature: ");
    Serial.print(T1);
    Serial.println(" deg C");
    Serial.print("Pressure: ");
    Serial.println(float(L1*10));
    Serial.println("---");
DateTime past (now-TimeSpan(0,0,30,6));
//X = myFile.seek(1);
myFile.readStringUntil(195830);
myFile.find("123");
Serial.println(    );
   delay(TEST_DELAY);
Title: Re: Compare logged data on SD card to current reading - £25 for working answer
Post by: wvmarle on Jul 17, 2018, 06:15 pm
When storing data on your sd card, don't use a human readable time (year, month, day, etc.). ZThat's very hard for a computer to work with - better use the unix timestamp, normally you can get that through Time.now(). That's an unsigned long, seconds since epoch. Now a 24-hour period is simply a difference of 24*60*60 = 86400 seconds. Later when you import that file in a spreadsheet application it's trivial to have those dates converted into something human readable again for you, while the seconds representation makes processing/graphing easier.
Now as you log every 10 seconds, that's 8,640 lines per day. So the record of 24 hours ago should be 8,640 lines before the current line in the file.
But now, how to get to a certain line? There's no line search function, just a position function. So you have to make sure every line is of identical length, so you can simply calculate where you have to go. Here the sprintf() function comes in play. This can guarantee you to write a single line of exactly the same length every time, making searching for an entry in the file easy.
Your file writing section becomes something like this:
  if (myFile) {
    char line[26]; // 25 characters plus null terminator
    char temp[7];
    dtostrf(T1, 6, 2, temp); // Convert float to string.
    char press[8];
    dtostrf(L1, 7, 2, press);
    sprintf(line, "%10d %6s %7s", now.unixtime(), temp, press);
    myFile.println(line); // writes a 25-character string plus a \n so 26 characters to the file - that's one line.
This way every line will be 26 characters long, and it becomes easy to read back the parts with temperature and pressure (use
strncpy(dest, src + beginIndex, endIndex - beginIndex);), and convert it back into float using atof(). The line of 24 hours ago starts 8640 * 26 = 224,640 characters ago.
For comparison: floats are never exactly the same, use an interval. So:
if (abs(yesterdayTemp - todayTemp) < 0.5) {
  // Less than 0.5° difference = equal.
Post by: GadgetCanyon on Jul 17, 2018, 06:53 pm
Hi wvmarle,
thank you for the help its really appreciated. Currently going through your answer and I have a few questions
1:  Can you explain this part of the code, i get sprintf() from your explination however the parts inside the brackets i'm not sure how each works. sprintf(line, "%10d %6s %7s", now.unixtime(), temp, press);
2: I'm really sorry however i'm not sure on the second part of your answer
This way every line will be 26 characters long, and it becomes easy to read back the parts with temperature and pressure (use strncpy(dest, src + beginIndex, endIndex - beginIndex);), and convert it back into float using atof(). The line of 24 hours ago starts 8640 * 26 = 224,640 characters ago.
Post by: wvmarle on Jul 17, 2018, 07:15 pm
[/code]
sprintf() helps formatting string.
line is the destination
then the format string: 10 characters digits; 6 characters string; 7 characters string.
And the parameters: the timestamp (seconds since epoch), temperature, pressure.
More reference on sprintf here (http://www.cplusplus.com/reference/cstdio/sprintf/), and details on the format string here in this printf reference (http://www.cplusplus.com/reference/cstdio/printf/). Note that printf() as such is not available on Arduino, and also the f parameter is not implemented on Arduino, hence the workaround.
I fixed the smiley face already...
After reading a line from your file in a char array, you can use that function to distil the appropriate parts.
char line[26]; // Line of data goes in this char array.
char temp[7]; // Store the temperature as string in here.
strncpy(temp, *line + 11, 6); // Read 6 characters from line starting at the 12th character and copy this into char array temp.
float T = atof(temp);
Post by: GadgetCanyon on Jul 17, 2018, 07:46 pm
Hi wvmarle,
Ok I am nearly there, so far i have this for writing and then reading the SD card.
  if (myFile) {
    char temp[7];
    char press[8];
// This section is for reading from the SD card
  if (myFile) {
not sure how to implement this exactly?
Thank you again for all your help and patience
Post by: wvmarle on Jul 17, 2018, 08:04 pm
Basically, get the current file size, deduct that number, and do a seek() to point the cursor at that position and start reading. This should do the job:
File f; // The file with your data in it.
uint32_t fileSize = f.size(); // The total file size.
f.seek(fileSize - 224640); // Go to the start of yesterday's record.
char[27] oldRecord;
f.read(oldRecord, 26); // Read 26 bytes.
oldRecord[26] = 0; // Null termination (may not be needed).
strncpy(temp, *oldRecord + 11, 6); // Read 6 characters from line starting at the 12th character and copy this into char array temp.
That should do. As long as I counted all string lengths correctly :-) If not it'll be off. Just do a Serial.print() of the string to make sure it's got the correct record and positions.
Post by: GadgetCanyon on Jul 17, 2018, 08:20 pm
One error, i have marked when it is in the code
char[27] oldRecord; // Error highlights here
Error
 Not used: C:\Users\Brigh\OneDrive\Documents\Arduino\libraries\SD-master
exit status 1
expected unqualified-id before '[' token
Post by: wvmarle on Jul 17, 2018, 08:26 pm
Oops
char oldRecord[27];
Post by: GadgetCanyon on Jul 17, 2018, 09:41 pm
Right i have nearly got it using the following from what you have said
  if (myFile) {
    char temp[7];
    char press[8];
f.seek(fileSize - 52); // Go to the start of yesterday's record. 60sec ago 6*26=156
char oldRecord [26];
//oldRecord[26] = 0; // Null termination (may not be needed).
//char temp[7]; // Store the temperature as string in here.
strncpy(temp, *oldRecord + 20, 6); // Read 6 characters from line starting at the 12th character and copy this into char array temp.
T = atof(temp);
Serial.print("20 sec ago: ");
    Serial.println(T);
The SD card has the following on it:
    21906          21.00
    21916          21.00
    21926          21.00
    21936          21.00
    21946          21.00
    21956          21.00
    21966          21.00
    21976          21.00
    21986          21.00
    21996          21.00
I have used the Serial.println(T) to show if its reading anything. So far i keep getting 0.00. any ideas?
Post by: wvmarle on Jul 18, 2018, 05:09 am
I thought there should be three values per line: the time, temperature (T1) and pressure (L1) values. The pressure is missing from your output.
After the sprintf() do add
Serial.println(line); to see what is actually written to the SD card, make sure that's correct.
Likewise after the strncpy() add
Serial.println(temp); again to makes sure it contains the correct values. atof() returns 0 when the string is incorrectly formatted and it can't make sense of it.
One problem that I see: you're trying to read the line from character 20, which is where the pressure value should be (I don't see it in your output, so it'll be a string of spaces or so, meaning atof() will return 0). The temperature should be starting at character 11.
Post by: GadgetCanyon on Jul 18, 2018, 07:06 pm
right i have narrowed down the issue
  if (myFile) {
    char line[26]; // 25 characters plus null terminator 26
    //char time1[11];
    //dtostrf(now.unixtime(),10,2,time1);
    char temp[7];
    char press1[8];
    dtostrf((L1*10), 7, 2, press1);
    sprintf(line, "%10d %10s %6s %7s", now.unixtime(), temp, press1);
    Serial.println(now.unixtime());
I edited one of your line "sprintf(line, "%10d %10s %6s %7s", now.unixtime(), temp, press1);" to see if it would make any difference (I added %10s). that is when i started getting -32516  M~1 below. Before i added %10s that first part of the code did not print out.
this is what i can see on the serial monitor
    -32516    M~1     23.96   36.70
    -32506    M~1     23.92   34.59
    -32496    M~1     23.88   36.00
    -32486    M~1     23.83   34.59
    -32476    M~1     23.76   33.89
    -32466    M~1     23.71   33.89
    -32456    M~1     23.67   31.79
    -32446    M~1     23.62   34.59
    -32436    M~1     23.58   35.30
    -32426    M~1     23.55   29.69
    -32416    M~1     23.51   34.59
    -32406    M~1     23.48   34.59
    -32396    M~1     23.45   33.19
    -32386    M~1     23.42   31.79
    -32376    M~1     23.41   34.59
    -32366    M~1     23.39   33.19
and the following is on the SD card
    -32356    M~1     23.37   34.59
    -32346    M~1     23.35   33.89
    -32336    M~1     23.32   31.09
    -32326    M~1     23.28   33.19
    -32316    M~1     23.24   34.59
    -32306    M~1     23.21   33.19
From what i can tell there seem to be an issue with the time being added.
Post by: wvmarle on Jul 18, 2018, 07:35 pm
Yes, there are serious issues. Multiple. I've been fighting more with sprintf, never been able to get it right the first time.
The line is much longer than expected (due to the extra %10s part). The number for time should be positive, not negative. Have to use u instead of d in the formatting string to make it unsigned.
 sprintf(line, "%10u %6s %7s", now.unixtime(), temp, press1);
This ought to work but there's something odd with the now.unixtime() function - as shown by the output on the Serial monitor.  Instead of a number, you get --- printed. Can you give me a link to the rtc library you use? I can probably quite quickly see what's going on there. There appears to be a type problem there. I'm expecting to get a timestamp as unsigned long, but it appears that's not the case here.
Post by: GadgetCanyon on Jul 18, 2018, 07:42 pm
Changed it to sprintf(line, "%10u %6s %7s", now.unixtime(), temp, press1); as requested, now getting:
     35430         21.97
     35440         21.99
     35450         22.00
     35460         22.00
     35470         22.01
     35480         22.02
     35490         22.02
     35500         22.02
the rtc lis this https://learn.adafruit.com/adafruit-pcf8523-real-time-clock/rtc-with-arduino (https://learn.adafruit.com/adafruit-pcf8523-real-time-clock/rtc-with-arduino)
and the library is this https://github.com/adafruit/RTClib (https://github.com/adafruit/RTClib)
Post by: el_supremo on Jul 18, 2018, 07:42 pm
unixtime presumably returns an unsigned long integer. The %d format in sprintf implies an 'int' which on UNO/NANO/etc is a 16-bit integer.
Use %ld.
P.S. There is a warning message from the compiler about this - for example:
C:\Users\Peter\AppData\Local\Temp\arduino_modified_sketch_136698\sketch_jul18a.ino:11:45: warning: format '%d' expects argument of type 'int', but argument 3 has type 'uint32_t {aka long unsigned int}' [-Wformat=]
   sprintf(tmp,"Long integer warning %d\n",ul);
Pete
Post by: GadgetCanyon on Jul 18, 2018, 09:57 pm
ok so changing the line to the below has worked
sprintf(line, "%10ld %6s %7s", now.unixtime(), temp, press1);
I have now tried to see the filesize using
File Nautilus; // The file with your data in it.
uint32_t fileSize = Nautilus.size(); // The total file size.
Nautilus.seek(fileSize - 52);
//  Serial.print(Nautilus.size());
  //  Serial.println("---");
I have tried a few different combinations of the above however none of them have producing anything only "0"
1531947710  21.57   56.33
1531947710
Post by: wvmarle on Jul 19, 2018, 05:28 am
That snippet won't work as you don't actually open any file.
File Nautilus = SD.open("Nautilus.txt"); // The file with your data in it.
This will work a lot better.
Post by: cedarlakeinstruments on Jul 19, 2018, 05:26 pm
So, after working with GadgetCanyon on this for a while it turns out to be a deceptively complex project.
I originally said I'd do it because at first glance it seemed like a simple 10-minute project, and on a PC recording continuously, it would be. However after asking a few questions about usage, the complexity became evident.
If this were continuous data capture on a PC, it would be pretty much dead simple. You have a stream of data being logged every 10 seconds, and after 24 hours of logging (8640 records), you can start to index a pointer that always points 24 hours behind in time and you can read the data at that point in the stream and compare it to the current reading. The memory usage on a modern PC would be trivial. In and done in 15 minutes!
But this is an Arduino and we can't keep 24k of data in RAM and the file manipulation libraries are not as fully-implemented as we'd like. The easy way to do this would be to follow the concept above: keep a pointer in the SD card data and index it forward as needed. Even on a PC this is a bit tricky when working with files, as opposed to memory streams. Due to how the FILE* methods work, I ended up having to open the file in write mode, save the data, close the file and then re-open it in read mode. This was because of limitations on how the seek() and related API calls work.
Even so, this doesn't meet all the requirements. One of the problems is that the logger can be turned on and off at some times, so you're not guaranteed  that between now and 24 hours ago, you would have 8,640 records. Therefore the only thing that will work properly, without changing the logging time to use Unix epoch time, or getting involved in complex calculations involving leap years (what happens if yesterday was February 29?), is searching through the data. Easiest is searching from the beginning, but the time becomes O(n) as the file grows. So ideally, we want to search backwards in time, since the maximum search distance is bounded regardless of file length.
I should probably have done that, since in retrospect it would have been simpler, but hindsight and all that...
@GadgetCanyon: As I mentioned, I wasn't able to test it as much as I'd like, so let me know if you have any issues integrating the code I sent into your main sketch.
Post by: wvmarle on Jul 19, 2018, 07:40 pm
In a spreadsheet application the date/time may be shown in human readable format in the cells, the underlying storage is always in UNIX time format, as that's easy to work with for a computer. It's just much more hidden from the user than when working with an Arduino - and that's part of the fun of working with such microcontrollers.
For your search problem, you can of course just start searching line by line from either end of the file until you get to the one you need, but it's not exactly efficient.
If there is indeed the possibility of a gap in the data, what will work a lot more efficient is to take the data 8,640 records ago (where you expect it). If you have been running for the past 24 hours you'll see the exact time stamp you expect, and you're done searching. If not, check the difference between the time you see now, and the time you expect, calculate how many records you are off, adjust your seek position, and try again. Within a few iterations you'll have the required record.
Then, as it's a continuous thing and you want to find yesterday's record every 10 seconds: keep that search position (store it in a global variable). 10 seconds later, you simply read the next record, it's most likely the one you need. If it's suddenly much later a time than you expect, just keep the position and return an error or whatever you think appropriate. It simply means there's a gap in the data, and you will catch up. You will have to account for the difference to not be exactly a multiple of 10 seconds as well, of course.
I'm about to start a similar logging battle - but with SPIFFS (ESP8266 internal), and with monthly logging, so at least a lot less records. But enough work to be done on them, as it's got to be handling data of up to 246 nodes :-)
Post by: cedarlakeinstruments on Jul 20, 2018, 02:31 am
That's an interesting algorithm and it's certainly worth considering. In case like this, though unless there's a need for the performance, I'd probably just go with a binary or even linear search. Honestly if it didn't seem so dead simple at first glance, I would probably have just done that and gotten it over with.
That's the thing with one-off applications: since software dev time has such a high cost, it's usually worthwhile to just go with the simplest, brute-force approach that works.
Post by: wvmarle on Jul 20, 2018, 06:45 am
You have to search 8,640 records at least - assuming you start from the end of the file. From the start of the file it gets worse, fast.
A quick search on SD card read speeds gives me a read speed of about 6 µs per byte, that would suggest an SPI speed of >1 MHz. At this speed those 8,640 lines of 26 characters each take 1.35 seconds to read. That is not including any access overhead. Other posts give me a speed of 250 kB/s - that would come to 0.9 seconds.
If this is done every 10 seconds, that'd mean you're spending 10% of the time searching! That'd be acceptable only if it has to be done once (upon startup), after that better keep the pointer and just advance it line by line, pausing when there's a gap in the data. No need to search over and over again, as you know the next record you need is either the next one in the file, or not there.
