Arduino Forum
Using Arduino => Installation & Troubleshooting => Topic started by: line_code on Aug 05, 2018, 10:35 pm
Title: ATMEGA328P U incompatible?
Post by: line_code on Aug 05, 2018, 10:35 pm
Hello everyone!
I've ran into a bit of a strange problem.  I am using ATMEGA328 chips as the microcontroller for a circuit board I designed.  I am using the ATMEGA328P-PU version like the uno uses.  I have purchased chips from both Mouser and Digikey and I've found that the ones I get from Mouser are labeled ATMEGA328P U and the ones from Digikey are labeled ATMEGA328P-PU like the ones in the uno.  I verified that I did indeed buy ATMEGA328P-PU from both suppliers.  I don't exactly care about the labeling, but I've noticed that the ATEMEGA328P U version doesn't function quite like it should after a little while of use until you start over by cycling the power.  What is the difference between ATMEGA328P U and ATMEGA328P-PU?  Why don't the two versions operate the same?  Is it possible to get them to operate the same?
I've attached pictures of the two versions for your reference.
Please let me know if you can help me.
Title: Re: ATMEGA328P U incompatible?
Post by: pert on Aug 05, 2018, 10:46 pm
line_code's pictures:
This is very strange because I've never seen an official mention of the "ATmega328P-U"
I have seen this topic on the forum before:
and on avrfreaks:
https://www.avrfreaks.net/forum/atmega328-chip-markings-initial-program-memory-and-flags-state-ids (https://www.avrfreaks.net/forum/atmega328-chip-markings-initial-program-memory-and-flags-state-ids)
But nowhere do I see a good conclusion on what the story is with this chip. I don't even see a listing on Mouser for the ATmega32P-U. I would contact Mouser customer service and ask them if they know why their chips are marked in a non-standard way.
Please explain exactly what you mean by "doesn't function quite like it should".
Post by: line_code on Aug 06, 2018, 04:09 am
I am using a modified version of the code on this (https://forum.arduino.cc/index.php?topic=218238.0) topic.  Its been modified to monitor some of the actual bits in the data stream and output them to some 74HC595's for external processing and analysis.  For whatever odd reason, the code works fine at first, but then after some random length of time(at the least probably 3 minutes and at the most maybe 10), the board will stop monitoring a random bit in the stream and turn off the respective output on the 595 until power is cycled.  I don't think that this anomaly occurs EVERY time, but it does happen probably 98% of the time.
Not sure if it matters, but I'm obviously writing the code in the Arduino IDE, but I am putting the code directly on the chip without the bootloader using a TL866CS.
The fuses I use are:
LOW: FF
HIGH: DE
EXTENDED: FD
LOCK: FF or FC depending on whether I want the code locked or not.
Post by: DrAzzy on Aug 06, 2018, 05:55 am
Are the chips properly decoupled? Process differences between individual chips/lots can render them more or less sensitive to improper or insufficient decoupling caps.
The P U chips are more recently produced, if I'm interpreting the date codes right. Maybe they got a die shrink or something?
Post by: line_code on Aug 08, 2018, 01:14 am
It seems I have forgotten a decoupling cap for the ATMEGA, but my other logic chips have them.  I have an abundance of 1uf 50V electrolytics.  Would those work?  Could I solder one of those to the bottom side of the board to the chip's socket?  If yes, which set of power pins should I use or should I use one pin from each?
Post by: pert on Aug 08, 2018, 01:57 am
You need 0.1 uF capacitor on each. You could try the 1 uF and it might work. Decoupling capacitors are a ballpark sort of thing. Your circuit board will act as a capacitor by itself. Some people even manage to get by without any at decoupling caps all but it's certainly not a good idea. Really you should just have a stock of 0.1 uF capacitors because they are always useful.
Post by: DrAzzy on Aug 08, 2018, 03:40 am
Electrolytic caps suck for decoupling. They have too much ESL and ESR. Ceramics are what you want (tants are ok too, but they cost several times as much and explode if you connect them backwards - I only use them in special situations, not run of the mill decoupling ). Buy a bag, you'll use more 0.1uF ceramic caps than any other single part.
Post by: line_code on Aug 10, 2018, 03:53 pm
Ok, so I buy a bunch of .1uF ceramic caps.  Then what?  Until I order a new revision board, I'm going to need to connect them to the board I have.  Should I solder one to the bottom of the board to one set of the Atmega's power pins?  On pin from each set of power pins?  Two capacitors total, one for each set of power pins?
Post by: DrAzzy on Aug 10, 2018, 11:05 pm
One on each side. And make sure that AVcc and Vcc are connected (I have seen tutorials where this isn't done).
Post by: line_code on Aug 15, 2018, 05:03 pm
Luckily it looks like I already did that.
I finally got some 0.1 uf ceramic capacitors.  Pretty soon I'll be testing the board with and without them to conclusively decide whether or not they fix the problem.
Post by: EmSerg on Aug 16, 2018, 01:46 pm
in IDE errors!
use https://github.com/MCUdude/MiniCore
all working !!! (Recommend turn on WDT & BOD for Vcc.)
Post by: line_code on Aug 16, 2018, 06:11 pm
The added caps didn't help.  I think I might try to contact Mouser and Atmel/Microchip to see what's up.
Post by: pert on Aug 16, 2018, 06:43 pm
Please let us know what they say about the ATmega328P-U marking.
Post by: line_code on Sep 25, 2018, 06:32 pm
I've tried emailing Mouser, but they didn't respond.  I was really wanting to email Atmel/Microchip, but I can't find a way to do that on their website.  Anyone know how I might be able to do that?
Also, Digikey is now selling the ATMEGA328P U chip instead of the ATMEGA328P-PU, but it looks different from the ATMEGA328P U I received from Mouser a while back.  (See photo).  The text on the chip looks almost printed instead of engraved and those little impressed circle things are bigger on the ones I just got from Digikey.  I haven't got a chance to test the new ones from Digikey yet, but I'm hoping they work like the ATMEGA328P-PU I used to be able to get.
Post by: BJHenry on Sep 25, 2018, 07:29 pm
Microchip's Support page. (http://www.microchip.com/technical-support/hot-topics)
Microchip's Contact page. (http://www.microchip.com/about-us/contact-us)
Post by: line_code on Sep 25, 2018, 09:42 pm
I did find those already, but I was really hoping to just email someone at the company.  I might just have to settle for using something on those pages.
Post by: line_code on Sep 30, 2018, 11:24 pm
Mouser finally emailed back.  They contacted Microchip for me who said this:
As part of Part marking change due to the migration from Atmel to Microchip, the package identifier has been removed from the device marking as this can be observed visually for different packages. This will be updated in the upcoming revisions of the device datasheet.  As per this new marking the ATMEGA328P U are valid devices without any process change.  Please provide more details on the application and nature of failure so that we can check this further.
That answers the question about the new marking. I'll respond to the email soon and explain the issues I have.
Post by: pert on Oct 01, 2018, 01:55 am
Thanks for the update! I guess they left the "U" because that's the indicator for some characteristic.
Post by: Dargoon on Oct 24, 2018, 02:18 pm
How to program that chip(Atmega 328p U) using arduino uno board mounted on it?
Arduino: 1.8.7 (Windows 7), Board: "Arduino/Genuino Uno"
Sketch uses 6760 bytes (20%) of program storage space. Maximum is 32256 bytes.
Global variables use 448 bytes (21%) of dynamic memory, leaving 1600 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x66
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x66
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x66
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x66
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x66
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x66
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x66
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x66
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x66
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x66
Invalid library found in C:\Program Files (x86)\Arduino\libraries\AMS: no headers files (.h) found in C:\Program Files (x86)\Arduino\libraries\AMS
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
I'm getting this msg after mounting the that chip.
Post by: Budvar10 on Oct 24, 2018, 02:30 pm
Did you upload the bootloader into the chip?
Post by: Dargoon on Dec 14, 2018, 06:42 am
line_code there is no difference between them the both controller are same and good to go i am also using the ATMEGA328P U controller its working absolutely fine.
