Arduino Forum
Using Arduino => Audio => Topic started by: TheRebell on Aug 21, 2018, 06:21 pm
Title: Chord memory function with basspedal and midi-shield
Post by: TheRebell on Aug 21, 2018, 06:21 pm
Hello,
I have an arduino mega with the sparkfun midi-shield and an organ basspedal. And a Led Backpanel 16x8, also a lcd screen
On the digital pins are the 13 keys connected. Now i want assign different chords on different keys, then go out ont the output of midi-shield!
p.ex. i tap on the G key of the pedalboard and go out with a GMinor, Major or seven.
When that' work, i want that the chord will be shown in the ledpanel  !
I have tried with the gizmo.ino from eclab but without success.
Please help me!!!
Thanks
Greetings from Belgium
Marco
Here is the code for normal key assignment wich works fine:
#define DEBOUNCE 1500
struct key
    int pin;
    int midiKey;
    int debounce;
    int keySent;
struct key keys[] =
  { 22, 25, 0, 0 },  // Db red
  { 24, 26, 0, 0 },  // D  red
  { 26, 27, 0, 0 },  // Eb orange
  { 28, 28, 0, 0 },  // E  orange
  { 30, 29, 0, 0 },  // F  yellow
  { 32, 30, 0, 0 },  // Gb green
  { 34, 31, 0, 0 },  // G  green
  { 36, 32, 0, 0 },  // Ab blue
  { 38, 33, 0, 0 },  // A  blue
  { 40, 34, 0, 0 },  // Bb violet
  { 42, 35, 0, 0 },  // B  violet
  { 44, 36, 0, 0 },  // C  brown
  { 48, 24, 0, 0 },  // C  brown
  { 0, 0, 0, 0 }     // end of list marker
int keyOffset = 0;
int keyVelocity = 100;
  for(int i = 0; keys.pin != 0; ++i)
    pinMode(keys.pin, INPUT_PULLUP);
  //start serial with midi baudrate 31250
  Serial.begin(31250);
void Midi_Send(byte cmd, byte data1, byte data2)
  Serial.write(cmd);
  Serial.write(data1);
  Serial.write(data2);
void noteOn(int midiKey)
  Midi_Send(0x90, midiKey, keyVelocity);
void noteOff(int midiKey)
  Midi_Send(0x80, midiKey, keyVelocity);
  byte byte1;
  byte byte2;
  byte byte3;
  int value;
  //*************** MIDI THRU ******************//
  if(Serial.available() > 0)
    byte1 = Serial.read();
    byte2 = Serial.read();
    byte3 = Serial.read();
    Midi_Send(byte1, byte2, byte3);
  // Look for bass pedal key events
    value = digitalRead(keys.pin);
    if(keys.debounce == 0) // Key has been off
      if(value == LOW)        // Key is now on
        noteOn(keys.midiKey + keyOffset);      // Send the MIDI note on message
        keys.keySent = keys.midiKey + keyOffset;
        keys.debounce = DEBOUNCE;  // Set the note off debounce counter
    else                      // Key has been on
      if(value == HIGH)       // Key has gone off
        if(--keys.debounce == 0) // If Key has remained off for DEBOUNCE scans,
          noteOff(keys.keySent); // In case the offset has changed, send MIDI off for the right note
      else                    // Key has not gone off
        keys.debounce = DEBOUNCE;  // Reset debounce counter in case we got
                                      // a small number of key off scans
Title: Re: Chord memory function with basspedal and midi-shield
Post by: slipstick on Aug 21, 2018, 08:04 pm
How do you expect it to know whether to send Gmaj, Gm or G7?
But if you really want a pedal press to send a chord instead of a single note then basically you need to replace the noteOn() and noteOff functions with more complex versions that send several MIDI commands not just one. Since the notes in a chord are well structured it's not difficult to send e.g. for a minor chord key.midiKey, midiKey+3 and midiKey+7 etc.
You can sort out the display when you have that working.
Steve
Post by: TheRebell on Aug 21, 2018, 11:01 pm
Hi thanks for the quick reply!
p.ex I assign the c-key an C Major-chord, the a-key a A Minor, anotherone a 7-chord
That's only an example!
For a song different chords on different keys
That' it!
And on the midi-shield i can switch bank up and down for different songs (chord structures)
Post by: TheRebell on Aug 22, 2018, 01:23 pm
I want combine the Basspedal1.ino with
 This extract from Sean Luke' Gizmo Sketch:
Thru.cpp
#include "All.h"
#ifdef INCLUDE_THRU
void resetDistributionNotes()
    memset(local.thru.distributionNotes, NO_NOTE, NUM_MIDI_CHANNELS);
    local.thru.currentDistributionChannelIndex = 0;
void performThruNoteOff(uint8_t note, uint8_t velocity, uint8_t channel)
    // NOTE DISTRIBUTION OVER MULTIPLE CHANNELS
    if (options.thruNumDistributionChannels > 0)
        // turn off ALL instances of this note on ALL channels
        for(uint8_t i = 0; i <= options.thruNumDistributionChannels; i++)
            if (local.thru.distributionNotes[i] == note)
                uint8_t newchannel = (options.channelOut + i - 1) % NUM_MIDI_CHANNELS + 1;
                for(uint8_t i = 0; i <= options.thruExtraNotes; i++)            // do at least once
                    sendNoteOff(note, velocity, newchannel);
                local.thru.distributionNotes[i] = NO_NOTE;
        // NOTE REPLICATION
            sendNoteOff(note, velocity, channel);
    // CHORD MEMORY
    for(uint8_t i = 1; i < options.thruChordMemorySize; i++)  // Yes, I see the *1*.  We aren't playing the bottom note a second time
        uint8_t chordNote = options.thruChordMemory[i] - options.thruChordMemory[0] + note;  // can't overflow, it'll only go to 254 (127 + 127).
        if (chordNote <= 127)
            sendNoteOff(chordNote, velocity, channel);
void performThruNoteOn(uint8_t note, uint8_t velocity, uint8_t channel)
        // revise the channel
        channel = (options.channelOut + local.thru.currentDistributionChannelIndex - 1) % NUM_MIDI_CHANNELS + 1;
        // do I need to turn off a note?
        if (local.thru.distributionNotes[local.thru.currentDistributionChannelIndex] != NO_NOTE)
                sendNoteOff(local.thru.distributionNotes[local.thru.currentDistributionChannelIndex], 127, channel);
        // store the note and update
        local.thru.distributionNotes[local.thru.currentDistributionChannelIndex] = note;
        local.thru.currentDistributionChannelIndex++;
        if (local.thru.currentDistributionChannelIndex > options.thruNumDistributionChannels )  // yes, it's > not >= because options.thruNumDistributionChannels starts at *1*
    // NOTE REPLICATION
        sendNoteOn(note, itemValue, channel);
    // CHORD MEMORY
            sendNoteOn(chordNote, itemValue, channel);
void performThruPolyAftertouch(uint8_t note, uint8_t velocity, uint8_t channel)
    // We note here that although a NOTE ON can be filtered out,
    // its corresponding NOTE OFF will not, nor will any POLYPHONIC AFTERTOUCH.
    // I had considered storing the note on that was being filtered so
    // as to also filter out the later note off, but this has downsides,
    // namely if you have a bounce that gets filtered, but the note off hasn't
    // happened yet, then you get ANOTHER BOUNCE, it can't get filtered :-(
        // change ALL instances of this note on ALL channels
                // We do NOT send extra notes with poly aftertouch because it consumes
                // so much buffer space that we will block on output and then start missing
                // incoming messages
                //for(uint8_t i = 0; i <= options.thruExtraNotes; i++)            // do at least once
                    sendPolyPressure(note, itemValue, channel);
        // NOTE REPLICATION
    // CHORD MEMORY
      sendPolyPressure(chordNote, itemValue, channel);
Post by: TheRebell on Aug 22, 2018, 01:29 pm
void playThru()
    // here we check if it's time to submit a NOTE OFF
    if (local.thru.debounceState == DEBOUNCE_STATE_FIRST_NOTE_UP_IGNORED &&
        local.thru.debounceTime + ((uint32_t)options.thruDebounceMilliseconds) * 1000 <= currentTime)
        performThruNoteOff(local.thru.debounceNote, 127, options.channelOut);
        local.thru.debounceState = DEBOUNCE_STATE_OFF;
    if (!bypass && newItem && options.channelOut != CHANNEL_OFF &&
        (itemChannel == options.channelIn || options.channelIn == CHANNEL_OMNI || itemChannel == options.thruMergeChannelIn))
        uint8_t channel = options.channelOut;
        if (itemType == MIDI_NOTE_ON)
            if (options.thruDebounceMilliseconds == 0)          // if debounce is off, don't do any debounce stuff!
                performThruNoteOn(itemNumber, itemValue, channel);
            else if (itemNumber != local.thru.debounceNote ||
                local.thru.debounceState == DEBOUNCE_STATE_OFF ||
                    ((local.thru.debounceState == DEBOUNCE_STATE_FIRST_NOTE_UP_IGNORED) &&
                    local.thru.debounceTime + ((uint32_t)options.thruDebounceMilliseconds) * 1000 <= currentTime))
                if (itemNumber != local.thru.debounceNote && local.thru.debounceState == DEBOUNCE_STATE_FIRST_NOTE_UP_IGNORED)  // new note, kill the old one
                    performThruNoteOff(local.thru.debounceNote, itemValue, channel);
                if (options.thruDebounceMilliseconds != 0)
                    // set up state machine
                    local.thru.debounceState = DEBOUNCE_STATE_FIRST_NOTE_DOWN;
                    local.thru.debounceTime = currentTime;
                    local.thru.debounceNote = itemNumber;
                // Filter out, but we're pressing again, so:
        else if (itemType == MIDI_NOTE_OFF)
            // If the note is too short, and it's what we're holding down, hold off and wait
            if (options.thruDebounceMilliseconds > 0 &&
                local.thru.debounceState == DEBOUNCE_STATE_FIRST_NOTE_DOWN &&
                local.thru.debounceNote == itemNumber)
                if (local.thru.debounceTime + ((uint32_t)options.thruDebounceMilliseconds) * 1000 >= currentTime)
                    local.thru.debounceState = DEBOUNCE_STATE_FIRST_NOTE_UP_IGNORED;
                    performThruNoteOff(itemNumber, itemValue, channel);
            else            // we don't care about this one
        else if (itemType == MIDI_AFTERTOUCH_POLY)
            performThruPolyAftertouch(itemNumber, itemValue, channel);
        else if ((itemType == MIDI_AFTERTOUCH) ||
            (itemType >= MIDI_PROGRAM_CHANGE && itemType <= MIDI_RPN_DECREMENT))
            // Yes, I realize this is largely a copy of Control.sendControllerCommand()
            // but I can't modify that function without going over the Uno's memory limit,
            // so I'm unable to use it because I can't pass a channel in.  Maybe later if
            // we jettison the Uno.
            // this includes raw CC, note
// CC->NRPN Mapping.  We just retag CC as if it was NRPN here.
if (options.thruCCToNRPN && (itemType == MIDI_CC_7_BIT || itemType == MIDI_CC_14_BIT))
itemType = MIDI_NRPN_14_BIT;
                switch(itemType)
                    case MIDI_AFTERTOUCH:
                        MIDI.sendAfterTouch(itemValue, channel);
                    break;
                    case MIDI_PROGRAM_CHANGE:
                        MIDI.sendProgramChange(itemNumber, channel);
                    break;
                    case MIDI_PITCH_BEND:
                        MIDI.sendPitchBend((int)itemValue, channel);
                    break;
                    case MIDI_CC_7_BIT:
                        MIDI.sendControlChange(itemNumber, itemValue, channel);
                    break;
                    case MIDI_CC_14_BIT:
                        sendControllerCommand(CONTROL_TYPE_CC, itemNumber, itemValue, channel);
                    break;
                    case MIDI_NRPN_14_BIT:
                        sendControllerCommand(CONTROL_TYPE_NRPN, itemNumber, itemValue, channel);
                    break;
                    case MIDI_RPN_14_BIT:
                        sendControllerCommand(CONTROL_TYPE_RPN, itemNumber, itemValue, channel);
                    break;
                    case MIDI_NRPN_INCREMENT:
                        sendControllerCommand(CONTROL_TYPE_NRPN, itemNumber, CONTROL_VALUE_INCREMENT << 7, channel);
                    break;
                    case MIDI_RPN_INCREMENT:
                        sendControllerCommand(CONTROL_TYPE_RPN, itemNumber, CONTROL_VALUE_INCREMENT << 7, channel);
                    break;
                    case MIDI_NRPN_DECREMENT:
                        sendControllerCommand(CONTROL_TYPE_NRPN, itemNumber, CONTROL_VALUE_DECREMENT << 7, channel);
                    break;
                    case MIDI_RPN_DECREMENT:
                        sendControllerCommand(CONTROL_TYPE_RPN, itemNumber, CONTROL_VALUE_DECREMENT << 7, channel);
                    break;
            TOGGLE_OUT_LED();
Post by: PieterP on Aug 22, 2018, 04:23 pm
Is this close to what you want?
MIDI-Chord-Buttons.ino:
#include "MIDIButtonChord.hpp"
#include "Notes.hpp"
constexpr uint8_t channel = 1; // MIDI channel to send on
MIDIButtonChord buttons[] = {
  {Chords::Major,          2,  note(C, 4),  channel}, // Major C chord in the 4th octave, button between pin 2 and ground, MIDI channel 1
  {Chords::Minor,          3,  note(D, 4),  channel},
  {Chords::Minor,          4,  note(E, 4),  channel},
  {Chords::MajorFirstInv,  5,  note(F, 4),  channel},
  {Chords::MajorSecondInv, 6,  note(G, 4),  channel},
  {Chords::MinorSecondInv, 7,  note(A, 4),  channel},
  {Chords::Diminished,     8,  note(B, 4),  channel},
 * You can change the chords afterwards using
 *    buttons[0].setChord(Chords::MajorSeventh);
 * for example.
  MIDI.begin();
  for (MIDIButtonChord &button : buttons)
    button.begin();
    button.update();
Full code attached.
Pieter
Post by: TheRebell on Aug 24, 2018, 07:12 pm
Hello, perhaps it's the right thing!
What is to do? Combine ?
Like this or is something to change?
#include <Button.h>
#include <MIDI.h>
struct key
    int pin;
    int midiKey;
    int debounce;
struct key keys[] =
  { 22, 25, 0 },  // Db red
  { 24, 26, 0 },  // D  red
  { 26, 27, 0 },  // Eb orange
  { 28, 28, 0 },  // E  orange
  { 30, 29, 0 },  // F  yellow
  { 32, 30, 0 },  // Gb green
  { 34, 31, 0 },  // G  green
  { 36, 32, 0 },  // Ab blue
  { 38, 33, 0 },  // A  blue
  { 40, 34, 0 },  // Bb violet
  { 42, 35, 0 },  // B  violet
  { 44, 36, 0 },  // C  brown
  { 48, 24, 0 },  // C  brown
  { 0, 0, 0 }     // end of list marker
int keyOffset = 0;
  Serial.begin(9600);           // set up Serial library at 9600 bps
  Serial.println("Setup complete");
  Serial.print("Note On: ");
  Serial.println(midiKey);
  Serial.print("Note Off: ");
  int value;
        noteOn(keys.midiKey);      // Send the MIDI note on message
          noteOff(keys.midiKey);
Post by: PieterP on Aug 24, 2018, 08:02 pm
The code I posted plays a C major chord when you hit the first button, a D minor chord when you hit the second button, etc. You can customize all notes, pins, and chords.
I think that an object-oriented approach is much easier than your code where you're doing all the logic in your loop function. If you encapsulate all of that in classes, it's much easier to keep an overview of what's going on.
If you look at the code I posted, you'll see that the MIDIButtonChords class doesn't care about debouncing, it just uses button.getState(). The Button class handles debouncing behind the scenes, so once that code is written, you don't have to worry about it anymore.
Please use [code][/code] tags when posting code.
Post by: TheRebell on Sep 02, 2018, 01:29 pm
sorry, for my late reply, had alot to do the last week. Can you give me an example for the sketch in my case!?
My input note from the pedal knob for a low C is digital pin 48  on the arduino! What is to change in your
mid-chord-button.ino?
What and where do I have to add something for the remaining 12 buttons?
Please help me
Thanks
Greetings...
and many many thanks to you for the patience
Marco
Post by: PieterP on Sep 02, 2018, 04:39 pm
Just change the pin numbers on lines 7-14. You can add more chords to that list. Just specify the chord, the pin number, the note number and the channel for each entry.
Post by: TheRebell on Sep 03, 2018, 02:22 pm
Great!!!  :)  :)  :)  it works!
Thats for simple 3-4 notes chords but
Now, when i have more octaves, p ex 2 hands playing, what can i do?
Thanks, you're great, absolutely what i'm searching for!!!
Post by: PieterP on Sep 03, 2018, 07:17 pm
The chords are defined in Chords.hpp. Just add some more.
For example:
const Chord<4> MajorAndBass = {{M3, P5, -P8, -2*P8}};
This is a major chord (major third, perfect fifth), and two bass notes (one octave lower, and two octaves lower).
Post by: TheRebell on Sep 23, 2018, 04:21 pm
Thanks a lot PieterP,
now I want add more sequences of chords on different channels or banks
p.ex. channel 1:  C=Cmaj, C#=C#m, D=Dm7,...
channel/bank 2:  C=Cm, C#=C#m, D=Dmaj,...
with the buttons of the midi-shield to change
Is it possible?
Greetings
and thanks
Post by: TheRebell3110 on Feb 26, 2019, 09:35 am
Hello PieterP,
p.ex. midi channel 1:  C=Cmaj, C#=C#m, D=Dm7,...
midi channel 2:  C=Cm, C#=C#m, D=Dmaj,...
How can i do this Peter?
Please help me!!!
Greetings
and thanks
Post by: PieterP on Feb 26, 2019, 12:16 pm
In the file MIDIButtonChord.hpp, the class MIDIButtonChord has members "note" and "channel". Just remove the const, and add setters:
class MIDIButtonChord {
  public:
    void setChannel(uint8_t channel) { this->channel = channel; }
    void setNote(uint8_t note) { this->note = note; }
  private:
    uint8_t channel;
    uint8_t note;
There are some drawbacks with this approach, you can't update the note/channel while the button is pressed, for example.
If you want a better framework for banking MIDI buttons, see https://github.com/tttapa/Control-Surface/blob/master/src/MIDI_Outputs/Bankable/Abstract/MIDIButton.hpp (https://github.com/tttapa/Control-Surface/blob/master/src/MIDI_Outputs/Bankable/Abstract/MIDIButton.hpp)
I might add MIDIButtonChords to the library eventually, but I don't have too much time on my hands right now.
Post by: TheRebell3110 on Mar 01, 2019, 07:10 pm
That's fine!!!
When you have time you can help me with the exact programming!
Post by: TheRebell3110 on Mar 01, 2019, 07:20 pm
pinMode(<pin number>, INPUT_PULLUP);
ex. pinMode(D2, INPUT_PULLUP);        1-16 channel
digitalRead(<pin number>);
ex. digitalRead(D2);
and
ex. pinMode(D3, INPUT_PULLUP);        16-1 channel
ex. digitalRead(D3);
Post by: TheRebell3110 on Mar 26, 2019, 07:06 pm
Hello Pieter P,
it's me again, have you time to finish the last steps?
Greetings
Marco
Post by: TheRebell3110 on Apr 12, 2019, 08:31 pm
is this ok:
private:
    const IChord *chord;
    const IChord *newChord;
    Button button;
    const uint8_t note;
    const uint8_t channel;
changing in
private:
    Button button;
    uint8_t note;
    uint8_t channel;
and add a channel?
Thanks
Post by: PieterP on Apr 15, 2019, 11:58 pm
I've just merged a PR into my Control Surface (https://github.com/tttapa/Control-Surface) library that adds chord functionality.
(Incomplete) documentation can be found here: https://tttapa.github.io/Control-Surface/Doc/Doxygen/d8/d9d/classBankable_1_1NoteChordButton.html (https://tttapa.github.io/Control-Surface/Doc/Doxygen/d8/d9d/classBankable_1_1NoteChordButton.html)
and an example as well: https://tttapa.github.io/Control-Surface/Doc/Doxygen/db/d12/NoteChordButton_8ino-example.html (https://tttapa.github.io/Control-Surface/Doc/Doxygen/db/d12/NoteChordButton_8ino-example.html)
I'm still very busy at the moment, so I might have missed some bugs. Feel free to open an issue on GitHub in that case, because I don't visit the forum very often.
Pieter
