Arduino Forum
Using Arduino => Introductory Tutorials => Topic started by: larryd on Aug 23, 2018, 07:51 pm
Title: Training and testing for new users.
Post by: larryd on Aug 23, 2018, 07:51 pm
The following posts challenge a new user's knowledge of Arduino coding and basic electronics.
Arduino questions with answers, based on an Arduino UNO:
1. When you are writing a sketch in the Arduino IDE, what happens to your sketch when you press Ctrl+T, Cmd+T?  Formats the code to make it more easily read.
2. If weird characters appear on the IDE serial monitor, what is likely wrong? You may need to match monitor baud rate to sketch baud rate.
3. What is a function? It is like a subroutine in BASIC, you can 'call' it from sections within the sketch.
4. What is the difference between global and local variables?  Global, access from anywhere, Local, access from with the module.
5. Where are global variables defined?  Outside of functions, normally at the top of the sketch.
6. What does const tell the compiler in this line of code?     const int myVariable = 13;   Variable will not change i.e. it is a constant, takes no SRAM.
7. What is wrong with this line of code?          #define counter = 0;      NO = and NO ;
8. What does  /*  and */  do to the lines of code that are written between these character pairs? Comments them out.
9. What does this line of code do?     return true;  The calling code gets a 'true' returned to it.
10.   If a variable has type float, how may bytes are set aside for the variable.      float foo = 0;      4
11. What does byte do in this line of code?    byte myFunction(int number) {  }     There is a returned variable, it is type byte.
12. Why is it important to use the smallest necessary type when you define your variables? Save SRAM
13. Why is it not recommended to use the delay() function in your sketches? delay() blocks sketch from running until the delay time is up.
14. What does this line of code do?    counter++;  counter is incremented by 1
15. What is SRAM?  Read write memory, where changeable/dynamic variables are.
16. What does the bootloader do? Loads the compiled code to static memory.
17. What two ways can you restart your Arduino? Power off and push the reset button
18. What does the millis() function return when it is called?   Current run time in milliseconds since last reset, it resets to 0 at ~49 days and starts incrementing again.
19. What is the range of numbers you can store in a variable of type byte?     0 - 255
20. What is the index of the letter F in this array?     char textMessage[] = "Have Fun with Arduino";   5, zero relative.
21. How many elements are in the above array?  22 including the null terminating character \0
22. How many iterations are we setting up in this line of code?
for( byte counter = 1; counter < 10;  counter++ );   9
23. Is there anything wrong with this line of code, if yes, what?
if(myVar = true) Serial.println("The light is ON"); = should be ==
24. What is the difference in these two lines of code?   Serial.println("Test");    Serial.print("Test"); println gives a CR, print does not.
25. What is the purpose of && in this line of code?     if( foo  >=  100  &&  foo <= 200); 'and', both conditions must be met.
26. Why is it important to comment your lines of code?  So you can 'easily' understand what is happening in your code.
27. What does the word static do in this line of code?   static int temperature = 0;  The variable's value is retained the next time it is accessed.
28. This error is displayed after compiling: 'temp' was not declared in this scope. Why?  temp is only available inside the for loop.
for(byte temp = 0; temp <=200; temp = temp +10) { Serial.println(temp); }
byte myVar = temp;
29. What is the value of foo when these lines of code are executed?      foo = 12;      foo = foo % 10;      2
30. Is there anything wrong with this line of code, if yes, what?
for( char counter = -10; counter < 10; counter++) It is okay, char # range is -128 to 127
31. If the A0 pin is connected to 2.5 volts, what is the value of foo?   unsigned int foo = analogRead(A0); 2.5V is ½ of 5V therefore since the range being 0-1023, value is 512/511
32. What is the range of numbers that can be used for num in this line of code.   analogWrite(13, num);  Can be 0-255
33. What does this line of code do?    temp = !temp;   compliments 'temp',  if temp was HIGH it is now LOW vv
34. What does INPUT_PULLUP do in this line of code?      pinMode(2, INPUT_PULLUP); Turns on the internal pullup resistor ~20-50K
35. What does the map() function do?  A function that maps/converts a value from one range to another range.
36. If you are told your code is blocking, what does this mean?   Code execution slows/stops, makes the sketch unresponsive.
37. What does a pull down resistor do to a floating input pin?   Ensures a logic LOW when the pin is hi Z
38. What does this line of code do?   tone(4, 750, 500);  A 750 Hz tone on pin 4 for ½ second
39. What is the value of foo after this line is executed?        unsigned long foo = 60*60*1000UL;   3,600,000 one hour
40. Describe what is happening in this line of code.         Serial.println (F("Program starting."));
The string is stored in static memory, not SRAM.
41. Why should variables, accessed outside in an interrupt service routine and modified in the ISR, be given the 'volatile' qualifier?  Making them volatile makes them reside in RAM. This prevents them from being placed in a 'Storage Register' where it could be inadvertently changed.
42. What do the functions noInterrupts( ) and interrupts( ) do?   'Disables' interrupts and 'Enables' interrupts. Prevents code between these two functions from being interrupted.
Title: Re: Training and testing new user's knowledge.
A user has connected the circuits below.
What is wrong with the circuits connected to the following pins? D2, D3, D4 and D5
D2 The LED needs a current limiting resistor ~220R
D3 5 volts will not turn on 3 series LEDs
D4 Switch needs a pulldown resistor OR connect the top of switch to GND and use INPUT_PULLUP.
D5 LED is shorted out the way it is shown.
Another User has connected a different circuit.
They cannot get the LED to flash, what is wrong with their circuit?
The power rails are separated in the middle, need to place jumpers to connect LHS to RHS.
A user has wired up an Arduino shield in the image below.
Which circuit below matches the wiring? A, B, C or NONE           B
Referring to the circuit below, when D2 is LOW, what will the voltmeters read?
Assume Vf for a red LED = 2V  therefore "A" will be ~1.5V   "B" will be -1.5V  and "C" will be 2V.
1. Identify what these components are and what function they serve:
Designation Component Name   What is its Function
R17 LDR Light causes a resistance change (detects light intensity)
R19 Resistor Input pull down resistor
R16 Resistor LED current limiting resistor
R14 Resistor Limits the pin D2 current while the gate capacitance charges
D10 Diode Kickback protection for the MOS FET
D9 LED Used as an indicator light
K1 Relay Provides isolation from the drive cct. Mechanical contacts. . .
Q4 N-MOS FET Provides drive current path to energize the realy
2. After this line of code executes, digitalWrite( 3 , HIGH );   will D8 be on or off?   OFF
3. Do you have to send a HIGH or a LOW to pin D4 to turn on D9?  HIGH
4. analogWrite(3 , 127); works, but analogWrite(4 , 127); doesn't work. Why is this?  Pin 4 is not for PWM.
5. What must the voltage rating of K1 be?  12V
6. If R17 is 20K what is the voltage at A0 on the UNO?  Rt = 30K therefore, 5V/3 = ~1.67V
7. If Q4 is turned on, what is the resistance between pin 1 and 3 of K1?  Zero ohms
A new user is trying to get a project working.  They have connected their circuit up exactly as seen in the schematic below.  Nothing works as it should.
Every time they plug in a new fuse into the motor circuit, the fuse burns out.
D6 is installed backwards, the drain and source on the MOS FET are swapped.
The LED does not turn on when the switch is pressed.
D7 is backwards.  Also, we need a pulldown resistor from D9 to GND, ~10K.
The IDE serial monitor is supposed to show what voltage is on input A0. The serial monitor displays a varying value without adjusting the pot.   You need to connect the battery negative to the Arduino GND.
What is wrong with these circuits?
For the image below, write a line of code to:
• read the voltage on A0.
int myVar = analogRead(A0);
• send the reading from A0 to the LED D5.
analogWrite(9 , myVar/4);
• turn the LED D4 off.
digitalWrite(10 , HIGH);
// Add comments to this sketch so a reader can easily follow what is happening.
// These comments must be more than just repeating what the line of code is doing.
#define LEDon  LOW
#define LEDoff HIGH
const byte redLED    = 7;
const byte greenLED  = 10;
const byte yellowLED = 13;
const byte Outputs[] = {7, 10, 13};
byte State;
const unsigned long redInterval    = 10000;
const unsigned long yellowInterval = 5000;
const unsigned long greenInterval  = 10000;
unsigned long LEDmillis;
  for (byte x = 0; x < sizeof(Outputs); x++)
    pinMode(Outputs[x], OUTPUT);
    digitalWrite(Outputs[x], LEDoff);
  digitalWrite(redLED, LEDon);
  LEDmillis = millis();
  State = 0;
  checkLEDs();
void checkLEDs()
  switch (State)
    case 0:
      if (millis() - LEDmillis >= redInterval)
        digitalWrite(redLED, LEDoff);
        digitalWrite(greenLED, LEDon);
        digitalWrite(yellowLED, LEDoff);
        State = 1;
      break;
    case 1:
      if (millis() - LEDmillis >= greenInterval)
        digitalWrite(greenLED, LEDoff);
        digitalWrite(yellowLED, LEDon);
        State = 2;
      break;
    case 2:
      if (millis() - LEDmillis >= yellowInterval)
        State = 0;
      break;
Post by: larryd on Aug 23, 2018, 07:52 pm
//What does this sketch do?
const int ledPin          = 13;
const int potentiometer   = A0;
unsigned long startTime;
  pinMode(ledPin, OUTPUT);
  int rate = analogRead(potentiometer);
  rate = map(rate, 0, 1023, 5000, 100);
  checkTime(rate);
void checkTime(int interval)
  static byte LEDstate = HIGH;
  if (millis() - startTime >= interval)
    startTime = millis();
    digitalWrite(ledPin, LEDstate);
    LEDstate = !LEDstate;
Future
Title: Re: Training and testing for new users.
Post by: ElectroDFW on Aug 27, 2018, 06:50 pm
Wow. Talk about throwing us in the deep end.
As a hardware technician just getting started with an Uno, 95% of those questions are Greek to me.
Also, the inline images of the circuit diagrams are missing in replies 2 through 6.
Regards,
David M.
Post by: larryd on Aug 27, 2018, 07:05 pm
Images are included and should be visible in your browser.
If you cannot see them, try a different browser.
All answers are in beige ink on white, included except post #7 and 8.
Post by: lastchancename on Aug 28, 2018, 12:17 am
PLEASE DONT POST YOUR ANSWERS WITHIN THIS THREAD !
It will be better if you discuss the problems offline, or in a new, different thread - so this topic remains 'clean', and doesn't confuse other newbies with incorrect 'guesses' that mislead others.
Nice work LarryD
Post by: westfw on Aug 28, 2018, 01:17 am
8. What does  /*  and *\ do to the lines of code that are written between these character pairs?
Is that a typo, or a trick question?
Post by: westfw on Aug 28, 2018, 01:18 am
(Ctrl-t doesn't do anything on MY Mac)
Post by: larryd on Aug 28, 2018, 01:23 am
Typo, now corrected.
What's a Mac ;)
Changed:   Ctrl+T, Cmd+T,
Post by: westfw on Aug 30, 2018, 03:49 am
Arduino questions
To be more useful online (or in general), you (we?) should design a set of "multiple choice" answers for each question.  A *good* set of multiple choice answers (which are harder to design than you might think.)
For additional usefulness, figure out how to randomize questions/answers so that if you take the test again, the answers will be different.
(Hmm.  Does anyone know of sites that let you generate and provide "online quizzes"?  I've seen some good quizzes on EdX and Coursera a similar, bit I'm pretty sure they don't allow just anyone to generate classes...)
Post by: GolamMostafa on Aug 30, 2018, 05:36 pm
Figure-1: Explaining the importance of internal pull-up, external pull-up, and external pull-down.
Consider bit-2 IO line of Port-D Register. When this IO line is configured to work as an input line, it takes over the symbolic name -- PIND2. The external button (K1) can be connected with this input line via DPin-2 (Digital Pin Connector) of Arduino UNO.
In Fig-1, there are there are three resistors (R1, R2, and Rp) around DPin-2. R1 is an external pull-down  resistor placed by the user; R2 is an external pull-up resistor placed by the user; Rp is an internal pull-up resistor placed by the designer of the ATmega329P Microcontroller. The resistors are associated with switches by which they could be connected or disconnected.
When all the switches are at opened condition, the input line assumes no definite voltage level. The voltage levle of DPin-2 could be 0V or 5V or in between or all the time changing. This is known as floating condition of the input line.
The insertion of the external pull-down resistor (R1) will propagate 0V from the GND-pin onto DPin-2; now, the DPin-2 is no more at the floating state. When button K1 is closed, the DPin-2 will assume LH state.
The insertion of the external pull-up resistor (R2) will propagate 5V from the 5V-pin onto DPin-2; now, the DPin-2 is no more at the floating state. At this condition, the 5V terminal of button K1 has to be connected to GND. When button K1 is closed, the DPin-2 will assume LL state.
The insertion of the internal pull-up resistor (Rp) will propagate 5V from the 5V-pin onto DPin-2; now, the DPin-2 is no more at the floating state. At this condition, the 5V terminal of button K1 has to be connected to GND. When button K1 is closed, the DPin-2 will assume LL state.
The execution of the pinMode(2, INPUT_PULLUP); function configures DPin-2 to work as input line along with the internal pull-up resistor connected. If we don't to connect the internal pull-up (sometimes, we don't need it because of very high value; it does not work for me with external interrupt lines), we execute the instruction pinMode(2, INPUT);. In this case, we have to connect the external pull-up or pull-down as per requirement/convenience to avoid floating condition of the input line.
Post by: GolamMostafa on Aug 30, 2018, 08:43 pm
Static Random Access Read Write Memory, [...].
When we say restart -- it specifically refers to 'again start when it is already in running condition' similar to a 're-trigger-able one-shot. The Arduino UNO can be restarted in two ways:
(a) by pressing/releasing the on-board RESET switch
(b) by re-invoking the Serial Monitor.
The variable foo will contain the bit pattern : 0000000111111111 (0x01FF)
Figure-1: Internal structure of ADC of ATmega328P Microcontroller
The analogRead(A0); command selects Ch-0 of the ADC and connects the 2.50V signal to the input of the 10-bit uni-polar ADC. After conversion, the 10-bit binary value is stored inside ADCL and ADCH Registers from which the value enters into user defined variable foo.
How does the value come up to:  000000111111111?
When the input to the ADC is equal to the VREF (the 5V -- called Full Scale value), the ADC value is all 1s (1111111111 = 1023)
When the input to the ADC is equal to VREF/2 (2.50V), the ADC value is (1023/5)*2.50 = 511 = 0111111111.
In Fig-1, we see that the upper 6-bit of the ADCH Register is always 0s; as a result, the value that enters into the variable foo is: 000000 0111111111 = 0x01FF.
Post by: lastchancename on Aug 30, 2018, 10:47 pm
Thise mentioned are 'HARDWARE resets' - there are several additional methods that will 'reset' your AVR microcontroller chip - all are just as important - as they often catch beginners unexpectedly.
AVR reset sources (http://web.engr.oregonstate.edu/~traylor/ece473/lectures/reset.pdf)
Possibly the most interesting is the Watchdog reset - read up on it...!
Post by: westfw on Aug 31, 2018, 01:13 am
I found ProProfs Quiz Maker (https://www.proprofs.com/quiz-school), which seems to do most of the things I wanted such a site to do.  It says it will add advertisements to quizzes after the "Free Trial Period" ends, unless I upgrade to a relatively expensive paid plan.  I'm not sure how obnoxious that will be.
And I might lose any images (currently I only have the Arduino Logo, but the various fritzing images might not work.   I'll have to see if they can be hosted elsewhere and still used.)
Here's a short (11 question) test based on some of LarryD's software-oriented questions.
Arduino Quiz #1: The Programming Language" (https://www.proprofs.com/quiz-school/story.php?title=mji2odqyngr2ye)
Post by: westfw on Aug 31, 2018, 01:52 am
Well, that's as it should be, right?  If you could get the correct answers even though you had very little experience with an Arduino, it wouldn't be very useful as a quiz, would it?  Tests should be guides to learning, not something that you can get 100% on at your first try (unless you're already an expert on the subject material.)
Post by: larryd on Aug 31, 2018, 02:11 am
@westfw   looks very good.
A step up from beige on white.  ;)
Edit:
If that website disappears, I guess you loose access to the quiz.
They are in control.
Hosting it here, keeps things local.
Post by: ChrisTenone on Oct 01, 2018, 10:35 am
I didn't find the ads excessive, but I did notice them.
There is a problem when representing code: the first letter of any answer is capitalized. This makes most of the "correct" answers of question 3 wrong actually. (counter++ does not increment the value of the variable Counter.)
Post by: ChrisTenone on Oct 01, 2018, 10:44 am
This test bank is impressive Larry! Bravo! What's your licensing agreement for those who teach this stuff in community college (for $900/semester load hour? Not me - my adjuncts. They will eat this stuff up!)
ps, beige on white is easily readable without highlighting by the colorblind.
Post by: westfw on Oct 01, 2018, 08:13 pm
Huh.  Fixed.  This actually occurs during the "rendering" of the question; I checked, and in the "source code" for the quiz, the capitalization was correct.  I finessed the issues my calling the variable "Counter" :-)
(and I submitted a "suggestion."  And another one for the "license" issue.)
Post by: westfw on Oct 01, 2018, 08:16 pm
Really?  That's interesting.  They never tell you that there are things that the colorblind can see BETTER.
Post by: lastchancename on Oct 02, 2018, 12:42 am
Curious - my score was marked out of 59, but the leaderboard was drawn from much higher possible scores... ?
OK - I missed the NULL termninator !  :-[
Post by: ChrisTenone on Oct 02, 2018, 01:42 am
Me too. And because of that, I didn't check my score!
Post by: ChrisTenone on Oct 02, 2018, 01:45 am
...What's a Mac ;)
:o It's a type of PC that runs Unix instead of DOS.
Post by: westfw on Oct 02, 2018, 01:48 am
They keep track?  Even though I'm not paying?
I think that originally I had the quiz evaluated as a percentage (0-100%), but when I wanted to add multi-part questions ("check all that apply") that had partial credit, that made it go to a n/m style score.  Strange that the top scores weren't reset.  I wonder if I can reset them manually?  (Nope; not without upgrading.)
(Hmm.  Something seems to have made the quizzes "private"; perhaps when my "free trial period" ended.  Fixed.)
Post by: lastchancename on Oct 02, 2018, 02:02 am
I like the test idea and format...
Perhaps 'Arduino' themselves might come to the party and support the platform - so the quizzes can be maintained semi-professionally.
The opportunity for real beginners to learn is phenomenal.
Thanks for getting this far
Post by: ChrisTenone on Oct 02, 2018, 02:35 am
"This far"?
I rarely see professional online testing that is this sophisticated, thorough or accurate. Especially the big publishing house quizzing services. "It marked me wrong for a correct answer" is the number 1 complaint I hear, followed closely by "It's incredibly slow".
So far this collection beats what I have sampled (sapling, mastering ..., OWL.)
I'd be afraid that, if Arduino LLC got involved, it would become a marketing tool, and feature the MKR boards and other hot items, for example.
Post by: westfw on Oct 02, 2018, 10:58 am
Here's a new one:  Arduino Quiz #n: History and Politics (https://www.proprofs.com/quiz-school/story.php?title=mji5nte0mwnyeo)
I, um, might have had a bit of fun with this one, and I recommend not drinking any liquids while taking the quiz...
(I did try to stay away from questions that were TOO opinion-based.)
(But ... who knew that Arduino had had quite that many crises!)
Hmmph.  One of the for-pay features at proprofs is apparently the "feedback per choice" (as opposed to "feedback per question.")   Rats.  I liked that one.
Post by: westfw on Oct 02, 2018, 11:18 am
It's easy to come up with a couple-dozen good questions (especially if you're rephrasing someone elses work!) and answer sets.  Coming up with the problem sets for a whole textbook, or even transcribing the questions/answers from the text to an online quiz system, would be a daunting task.   (I remember college: "the answers to odd-number problems are in the back.  Not all of them are correct.")
But thanks!  I've been through several "Pro" MOOCs now, and way too many "Facebook Quizzes", and I'm developing some definite opinions about how to do online quizzes (and how NOT to.)
Post by: ChrisTenone on Oct 03, 2018, 06:12 am
This "History and Politics" quiz is in the incredibly slow category. That said, it covers a good field. I only got the 5 easy ones right out of 16 questions. It's a little spoilery, but my favorite answer is:
ps, your quizzes are really nice West, I never have the patience to write them, but I know if I invested the time, I'd have it to use forever. But I stop being a teacher in about 14 weeks. :|
Larry's curated test bank is really amazing. Some software that could cull a subset of a database like that could auto-generate different quizzes, with a difficulty level that one could specify. I know the Sapling team did this with a huge collection of chemistry questions. They employed real chemists to fact-check the problems, and of all the commercial tests, I find it to be the most accurate. Nothing galls me more than wrong question/answers in an online resource that my students have to pay for.
By publishing here, Larry opened this up to the largest, most capable collection of Arduino engineers and technicians in this universe.
