Arduino Forum
International => India => Topic started by: mohammadakter_hossain on Sep 11, 2018, 09:11 am
Title: Two program execution sequentially
Post by: mohammadakter_hossain on Sep 11, 2018, 09:11 am
I am a new user of arduino. I need some suggestion or assist to complete my program. I am using arduino mega 2560, stepper motor and analog sensor.
Goal: Run the stepper motor for a particular distance in mm range and then it will stop for a while. Within this stopped time the sensor will take analog data. Then again do the same task in a loop.
#include <Stepper.h>
#define STEPS 100
Stepper stepper(STEPS, 8, 9, 10, 11);
// Analog input pins
int sensor1 = 0;
int sensor2 = 1;
int sensor3 = 2;
int sensor4 = 3;
int sensor5 = 4;
int sensor6 = 5;
int value1 = 0;
int value2 = 0;
int value3 = 0;
int value4 = 0;
int value5 = 0;
int value6 = 0;
long duration;
float distance;
  stepper.setSpeed(30); // set the speed of the motor to 30 RPMs
  Serial.begin(19200);
void readSensor() {
  value1 = analogRead(sensor1);    // read the value from the sensor
  value2 = analogRead(sensor2);    // read the value from the sensor
  value3 = analogRead(sensor3);    // read the value from the sensor
  value4 = analogRead(sensor4);    // read the value from the sensor
  value5 = analogRead(sensor5);
  value6 = analogRead(sensor6);
//Display sensor digital value
  Serial.print(value1);  Serial.print(";");  Serial.print(value2);  Serial.print(";");  Serial.print(value3);  Serial.print(";");  Serial.print(value4);  Serial.print(";");  Serial.print(value5);  Serial.print(";");  Serial.println(value6);
void motor() {
  for(int i = 0; i < 30; i++)
    stepper.step(STEPS);
void loop () {
// I am not sure how to execute motor and sensor command in loop
Title: Re: Two program execution sequentially
Post by: sibin_lal on Jan 09, 2019, 05:44 am
Use millis(); to multitask your Arduino . :)
https://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
https://www.google.co.in/amp/s/www.baldengineer.com/millis-ind-on-off-times.html/amp
