Arduino Forum
Using Arduino => Audio => Topic started by: Celteek on Mar 29, 2011, 07:08 pm
Title: Whistle detection
Post by: Celteek on Mar 29, 2011, 07:08 pm
Hello everyone!
I'm working on a robotic project, and I'd like my robot to detect when I whistle. But I'm not that good in electronics... :( Do you know how I can do that? I thought of amplifying the sound with an amplificator and then look for the frequency using the arduino. But is ths possible?
Maybe I should use a frequency-voltage converter? But I want the electronic to be as simple as possible...
Thanks a lot for your help! :)
(Remember I'm a noob :D)
Title: Re: Whistle detection
Post by: RuggedCircuits on Mar 29, 2011, 07:19 pm
A simple way to do it is with a small microphone and amplifier circuit, like the one on our Gadget Shield (http://ruggedcircuits.com/html/gadget_shield.html) or a stand-alone module like this one (http://www.sparkfun.com/products/9964).
The question is are you just looking for a sound/no-sound decision or are you actually trying to measure the frequency of the whistle and only want to respond to a certain whistle frequency? Selecting a single frequency is a little bit more work, though there have been some Arduino FFT projects recently that can help with this (searching for "Arduino FFT" will give lots of results).
The Rugged Motor Driver (http://ruggedcircuits.com/html/rugged_motor_driver.html): two H-bridges, more power than an L298, fully protected
Post by: Big Oil on Mar 29, 2011, 07:46 pm
FYI I tried to hack a small 'lost car-key finder' device that would beep when you whistle, but the thing broke before I could get it to talk to the Arduino.
Post by: Grumpy_Mike on Mar 30, 2011, 07:19 pm
There is a chip that will do the whistle detection for you.
The UM3763 contains a signal amplifier and frequency detector and is housed in a small 8 pin package.
Other chips are here:-
http://uk.farnell.com/jsp/search/results.jsp?N=500006+1004414&Ntk=gensearch_001&Ntt=tone+decoder&Ntx=mode+matchallpartial&isGoback=false&displaytext=&isRedirect=false (http://uk.farnell.com/jsp/search/results.jsp?N=500006+1004414&Ntk=gensearch_001&Ntt=tone+decoder&Ntx=mode+matchallpartial&isGoback=false&displaytext=&isRedirect=false)
Post by: Celteek on Apr 02, 2011, 07:14 pm
Do you think a LM567 can work?
Post by: Magician on Apr 02, 2011, 07:49 pm
Regular piezo buzzer is a whistle detector due it extra nonlinear frequency response.
Probably, operational amplifier thats all you need to get sensitivity level .
Post by: Grumpy_Mike on Apr 04, 2011, 02:56 pm
Yes that would work.
