Arduino Forum
Using Arduino => Motors, Mechanics, Power and CNC => Topic started by: 03david7069 on Oct 12, 2018, 05:21 am
Title: what happend if I connect 5V to VIN?
Post by: 03david7069 on Oct 12, 2018, 05:21 am
Hi, I have a question, what happend if I connect 5V to VIN?
I read that VIN works with 7-12V, but also I read that many people connect 5V to VIN, but if I do this, I will have a correct regulation (5 Volts on pin of 5V and 3.3 Volts on pin of 3V3) or i will have less volts of output?
Thanks.
PD: Sorry for mi English, I am learning. :D
Title: Re: what happend if I connect 5V to VIN?
Post by: pert on Oct 12, 2018, 06:25 am
Vin is connected to a voltage regulator. Voltage regulators have a dropout voltage. This means that if you provide 5 V to a 5 V voltage regulator with a 1.2 V dropout then it will only supply 3.8 V to the 5V pin and the microcontroller. That 3.8 V is supplied to the 3.3 V voltage regulator. In the case of the Uno, the 3.3 V regulator has a dropout of 0.3 V so actually it will still be able to supply 3.3 V to the 3V3 pin.
If it's a 3.3 V board, sure. Otherwise those many people don't know what they're doing and will end up having problems later. If you want to power a 5 V board with a 5 V supply, just skip the voltage regulator.
