Arduino Forum
Products => Arduino Due => Topic started by: simonwright on Feb 04, 2019, 07:35 pm
Title: Using ERASE button as PIO on Due
Post by: simonwright on Feb 04, 2019, 07:35 pm
(Apologies if you've already seen this question on StackExchange)
I'm working on a demo program for which I want to use minimal resources: all I need is one LED and one pushbutton.
I'd very much like to use on-board resources. The user LED (PB27) is fine (I'd have liked one more, but there it is).
I read in the datasheet that the ERASE button can be used as an input (PC0) provided that I clear the SYSIO12 bit in the System I/O Configuration Register CCFG_SYSIO.
I find that if I do this I can push the ERASE button without erasing flash (!), but PC0 always reads as 0 (even if I enable pullup; ought to be already enabled, you'd think).
I should add that PC1 works just fine.
Has anyone else got ERASE => PC0 to work? is there documentation I've missed? (in ASF, some of the other boards in sam/applications/getting_started/ disable the ERASE button, but not this one).
Title: Re: Using ERASE button as PIO on Due
Post by: ard_newbie on Feb 04, 2019, 08:14 pm
Did you power PIOC in your code ?
Post by: simonwright on Feb 05, 2019, 12:59 pm
Yes (as I said, PC1 works as expected).
(I don't think I can usefully post the code, since it's in Ada: however, if interested, see here (https://github.com/simonjwright/coldframe/blob/master/examples/arduino/Digital_IO.Arduino.impl/digital_io-arduino_support.adb#L137))
Post by: ard_newbie on Feb 05, 2019, 03:26 pm
When PC0 is used as a GPIO, you have to clear SYSIO12 bit in CCFG_SYSIO.
  PMC->PMC_PCER0 = PMC_PCER0_PID13;    // PIOC power ON
  MATRIX->CCFG_SYSIO = 0;              // PC0 used as GPIO
  PIOC->PIO_PUDR = ~0UL;
  PIOC->PIO_PUER = PIO_PUER_P0;        // PC0 pull up enable
  // You can't use attachinterrupt() with PC0 since PC0 has no pin number
  uint32_t status;
  status = PIOC->PIO_PDSR;
  if ((status & 1ul) == 0)
    // Do something if Erase button is pressed
Note that once you have cleard SYSIO12 in CCFG_SYSIO, you can't upload a new sketch for 5 minutes. Before uploading a new sketch, power down your board for 5 minutes.
Post by: simonwright on Feb 05, 2019, 07:15 pm
Thanks for that, but that's what I'm already doing, and as I said it (not the SYSIO12 part, of course) works for PC1.
Except I don't disable pullup on all the PC pins (PIOC->PIO_PUDR = ~0UL;) - is it necessary?
Where does the 5 minutes come from? This might be the explanation for my troubles.
