Arduino Forum
Using Arduino => General Electronics => Topic started by: xl97 on Feb 14, 2019, 09:06 pm
Title: 4 x Button SD Key PCB questions (sum of resistance?)
Post by: xl97 on Feb 14, 2019, 09:06 pm
Question on how this hardware works/is set up..
I want to use this PRE-MADE 4 x switch, SD Key PCB:
ie: https://www.aliexpress.com/item/3-3V-5V-KC11B04-4-key-Analog-Buttons-AD-Keypad-Board-ADC-port-keyboard-for-Arduino/32710243294.html?spm=2114.10010108.1000023.4.44ae475aoKihoB
Image of the bottom of PCB so you can see resistor values and traces:
(https://ae01.alicdn.com/kf/HTB1ehfZLXXXXXcnXFXXq6xXFXXXf/3-3V-5V-KC11B04-4-key-Analog-Buttons-AD-Keypad-Board-ADC-port-keyboard-for-Arduino.jpg)
I want to use this in conjunction with a DFPlayer mini, in standalone mode  (ie:  not used along side an Arduino, like I normally use these)
Here is the 'chart' for the DFPlayer for reference..
(https://www.dfrobot.com/wiki/images/7/75/Adkey_control.png)
** right click  >> view image to see true (larger) size.. not sure why it does this?
My question is how these values are calculated and used with this PCB?
Regardless if I decide to use ADKey1 or ADKey2.....  (which really just dictates the audio file names)...
I see that each clip is triggered based on the resistance/value of the switch that was pressed.
0K (no resistor/resistance) = triggers clip 0 (or 1, not sure yet)...
3K = triggers clip 2
6.2K = triggers clip 3
etc..etc..
I would imagine I'll need to replace the resistors on this PCB,  to match that threshold value...  but I'm not clear on how this is calculated??
When I look at the bottom of the board and see the resistor values.. they all look to be the same?
So are they added up?
IE: button 1 has no resistor or 0K resistor..   button 2 has a 3k resistor on it..
button 3 then.... needs another addition 3.2k to make it equal >= the 6.2k threshold it is looking for to trigger clip #3?
Or do I just use the stated value on each 'button/switch'? as stated in the diagram/schematic?
ie: button 3 gets a 6.2k resistor, as it only takes that single value into the equation?
So Im not clear is the resistance accumulative? or stand alone?
Title: Re: 4 x Button SD Key PCB questions (sum of resistance?)
Post by: xl97 on Feb 15, 2019, 09:32 pm
^ bump..
I guess I can remove the resistors.. and temporarily use some thru-hole resistors to test this out.
