Arduino Forum
Using Arduino => Programming Questions => Topic started by: sdzafar on Mar 23, 2019, 02:47 pm
Title: mm to cm or inches
Post by: sdzafar on Mar 23, 2019, 02:47 pm
This IS code (credit https://youtu.be/d7VzVV2itAo  and  https://youtu.be/Zejn2yLxjUs).
Please anybody can explain to me how to change wire length mm to cm or inches.
(already try to replace "mm" to "cm" but not working, stepper motor take steps in mm)
//------------------------------- librarys ----------------------------------
#include <LiquidCrystal.h>
#include <Servo.h>
//------------------------------- lcd ----------------------------------
LiquidCrystal lcd(12, 11, 2, 3, 4, 5);
//------------------------------- stepper ----------------------------------
#define stepPin 7
#define dirPin 8
//------------------------------- servo ----------------------------------
Servo snippers;
#define servo 10
#define openAngle 180
#define closedAngle 0
//------------------------------- input ----------------------------------
#define leftButton 14
#define rightButton 9
#define upButton 15
#define downButton 6
//------------------------------- user settings ----------------------------------
unsigned int wireLength = 0;
unsigned int wireQuantity = 0;
//------------------------------- system settings ----------------------------------
int state = 0;
int incrementSpeed = 1;
int previousWireLength = 0;
int previousWireQuantity = 0;
float mmPerStep = 0.18096;
  lcd.begin(16, 2); //LCD columns and rows
  pinMode(upButton, INPUT_PULLUP);
  pinMode(downButton, INPUT_PULLUP);
  pinMode(leftButton, INPUT_PULLUP);
  pinMode(rightButton, INPUT_PULLUP);
  pinMode(stepPin,OUTPUT);
  pinMode(dirPin,OUTPUT);
  snippers.attach(servo);
  snippers.write(openAngle);
  if (!digitalRead(rightButton)){
    if(state == 5){
      state = 0;
    else{
      state += 1;
    delay(200);
    lcd.clear();
  if (!digitalRead(leftButton) && state > 0 && state < 4){
    state -=1;
    delay(200);
    lcd.clear();
  switch (state){
    case 0:
      homeScreen();
      break;
    case 1:
       chooseWireLength();
       break;
    case 2:
      chooseWireQuantity();
      break;
    case 3:
      confirm();
      break;
    case 4:
      currentlyCutting();
      break;
    case 5:
      finishedCutting();
      break;
void homeScreen(){
  lcd.setCursor(0, 0);
  lcd.print("WIRE CUTTER");
  lcd.setCursor(11, 1);
  lcd.print("NEXT>");
  delay(100);
void chooseWireLength(){
  wireLength = changeValue(wireLength);
  //clear LCD if required
  if(previousWireLength != wireLength){
    lcd.clear();
    previousWireLength = wireLength;
  //Display information on LCD
  lcd.print("LENGTH:" + (String)wireLength + "mm");
  displayNavigation();
void chooseWireQuantity(){
  wireQuantity = changeValue(wireQuantity);
  if(previousWireQuantity != wireQuantity){
    lcd.clear();
    previousWireQuantity = wireQuantity;
  lcd.print("QUANTITY:" + (String)wireQuantity);
void confirm(){
  lcd.print((String)wireLength + "mm x " + (String)wireQuantity + "pcs");
  lcd.setCursor(0, 1);
  lcd.print("<BACK");
  lcd.setCursor(10, 1);
  lcd.print("START>");
  delay(100);
void currentlyCutting(){
  lcd.print((String)0 + "/" + (String)wireQuantity);
  lcd.print("???s");
  int stepsToTake = (int)wireLength/mmPerStep;
  for(int i = 0; i < wireQuantity; i++){
    unsigned long timeForOneCycle = millis();
    digitalWrite(dirPin,HIGH);
    for(int x = 0; x < stepsToTake; x++) {
      digitalWrite(stepPin,HIGH);
      delayMicroseconds(500);
      digitalWrite(stepPin,LOW);
    lcd.print((String)(i+1) + "/" + (String)wireQuantity);
    snippers.write(closedAngle);
    delay(600);
    delay(600);
    unsigned long timeRemaining = ((millis() - timeForOneCycle)*(wireQuantity - (i+1)))/1000;
    lcd.print((String)timeRemaining + "s    ");
  wireLength = 0;
  wireQuantity = 0;
  state = 5;
void finishedCutting(){
  lcd.clear();
  lcd.print("CUTTING COMPLETE");
  lcd.print("NEXT>");
  delay(100);
int changeValue(int currentValue){
  if (!digitalRead(upButton)) {
    delay(100);
    currentValue += incrementSpeed;
  if (!digitalRead(downButton)) {
    if(currentValue - incrementSpeed >= 0){
      delay(100);
      currentValue -= incrementSpeed;
    else{
      currentValue = 0;
  if (!digitalRead(downButton) && !digitalRead(upButton)){
    incrementSpeed = 1;
  return currentValue;
void displayNavigation(){
  lcd.print("<BACK");
  lcd.print("NEXT>");
  delay(100);
Title: Re: mm to cm or inches
Post by: septillion on Mar 23, 2019, 03:04 pm
Hi, welcome. Please read How to use the forum. Especially the part about code tags and what YOU have tried so far.
But as an answer:
cm = mm / 10
Post by: sdzafar on Mar 23, 2019, 03:23 pm
But as an answer:
cm = mm / 10
Thanks for reply
I want to convert mm to cm in code.
Post by: septillion on Mar 23, 2019, 03:26 pm
So, what makes that difficult in code?
cm = mm / 10;[/code
is completely valid code.
So start by changing you post to have code tags. Next, tell us what you tried an why you think that did not work.
Post by: UKHeliBob on Mar 23, 2019, 03:30 pm
Given a measurement in mm how would you convert it to cm using pencil and paper, or even a calculator ?
Post by: david_2018 on Mar 23, 2019, 03:35 pm
Are you wanting to have the length in whole cm / inches, or do you want to allow fractional amounts?
If only whole numbers, just change all the display text from "mm" to the appropriate "cm" or "in",
then in the wire cutter section, change the line that calculates the stepper motor steps:
//original code
 int stepsToTake = (int)wireLength / mmPerStep;
//code for wireLength in cm
 int stepsToTake = (int)((wireLength * 10) / mmPerStep;)
//code for wireLength in inches
 int stepsToTake = (int)((wireLength * 25.4) / mmPerStep;)
Post by: JaBa on Mar 23, 2019, 05:10 pm
The US has been "converting to the metric system within 10 years" for 50 years now and we have to explain how to convert mm to cm...  But everyone is expected to know how many feet are in a mile?
Post by: Robin2 on Mar 23, 2019, 05:19 pm
The official definition of an inch is 25.4 mm
...R
Post by: JCA79B on Mar 24, 2019, 06:56 am
But its really closer to:
1 / 0.03937 = 25.400050800102   :smiley-grin:
Post by: Robin2 on Mar 24, 2019, 08:49 am
Not according to my Physics text book
1 inch = 2.54 centimetres (exactly)
...R
Post by: sdzafar on Mar 24, 2019, 09:21 am
//original code
Thank you for quick understanding, and thanks for your help it perfectly works.
   just one thing is here, an input value is 2inch, output wire size is 1.9inch (as an attachment image)
Post by: TomGeorge on Mar 24, 2019, 09:29 am
Your wireLength variable is an int,
Try this, it may fix the problem.
 int stepsToTake = (int)(((float)wireLength * 10.0) / mmPerStep;)
 int stepsToTake = (int)(((float)wireLength * 25.4) / mmPerStep;)
Tom... :)
Post by: david_2018 on Mar 24, 2019, 10:01 am
Tom... :)
If that does not fix the problem, did you try the original program to verify the length using mm?  Its possible your value for mmPerStep may need to be adjusted.  The picture showed two slightly different lengths of wire, if you are getting inconsistent lengths the wire may be slipping in the feeder.
Post by: yapos12345 on Jan 14, 2020, 08:56 am
Here i can explain you how to change wire length mm to cm or inches(millimeter to inches (https://mm-to-inches.net/)) check this.
Post by: lastchancename on Jan 14, 2020, 10:27 am
FFS
This is grade 4 maths in any conversation.
