Arduino Forum
Using Arduino => Audio => Topic started by: elifrederick on Apr 10, 2019, 08:28 pm
Title: One piezo buzzer with two buttons and two melodies
Post by: elifrederick on Apr 10, 2019, 08:28 pm
Hello. First time posting. Beginner.
I was just wondering if anyone could help me program one piezo buzzer to play two different melodies triggered by two different buttons, one is Halloween theme and the other is Star Wars theme. I'm also a little unsure of how exactly to build the circuit. Right now, it starts immediately playing the Star Wars theme when the code is sent over without buttons being pressed.
Thanks to anyone who can help.
Photo of the circuit (https://drive.google.com/file/d/0B3rM6D4gSiSWRDVQdkRFUktrZjRzN3JySEFWYXhSOW51R1Y0/view?usp=sharing)
  Melody
  Plays a melody
  circuit:
  - 8 ohm speaker on digital pin 8
  - push button on digital pin 2
  - push button on digital pin 7
  created 21 Jan 2010
  modified 30 Aug 2011
  by Tom Igoe
  This example code is in the public domain.
  http://www.arduino.cc/en/Tutorial/Tone
#include "pitches.h"
// notes in the melody:
int hallomelody[] = {
  NOTE_CS5, NOTE_FS4, NOTE_FS4, NOTE_CS5, NOTE_FS4, NOTE_FS4, NOTE_CS5, NOTE_FS4, NOTE_D5, NOTE_FS4, NOTE_CS5, NOTE_FS4, NOTE_FS4, NOTE_CS5, NOTE_FS4, NOTE_FS4, NOTE_CS5, NOTE_FS4, NOTE_D5, NOTE_FS4
int starmelody[] = {
  NOTE_G3, NOTE_G3, NOTE_G3, NOTE_D4, NOTE_G4, NOTE_E4, NOTE_D4, NOTE_C4, NOTE_C5, NOTE_G4, NOTE_E4, NOTE_D4, NOTE_C4, NOTE_C5, NOTE_G4, NOTE_F4, NOTE_E4, NOTE_F4, NOTE_D4
int halloween = 2;
int starwars = 7;
// note durations: 4 = quarter note, 8 = eighth note, etc.:
int noteDurations[] = {
  6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6, 6
int counterDurations[] = {
  6, 6, 6, 1, 1, 6, 6, 6, 1, 2, 6, 6, 6, 1, 2, 6, 6, 6, 1
void setup(){
  //make the button's pin input
  pinMode(halloween, INPUT);
  pinMode(starwars, INPUT);
  //read the input pin
  int buttonState = digitalRead(halloween);
  //if the button is pressed
  if (buttonState == 1) {
    //iterate over the notes of the melody
    for (int thisNote=0; thisNote <20; thisNote++) {
      //to calculate the note duration, take one second. Divided by the note type
      int noteDuration = 1000 / noteDurations [thisNote];
      tone(8, hallomelody [thisNote], noteDuration);
      //to distinguish the notes, set a minimum time between them
      //the note's duration +30% seems to work well
      int pauseBetweenNotes = noteDuration * 1.30;
      delay(pauseBetweenNotes);
      //stop the tone playing
      noTone(8);
  int buttonState = digitalRead(starwars);
    for (int thisNote=0; thisNote <19; thisNote++) {
      int noteDuration = 1000 / counterDurations [thisNote];
      tone(8, starmelody [thisNote], noteDuration);
      noTone(8);
Title: Re: One piezo buzzer with two buttons and two melodies
Post by: slipstick on Apr 10, 2019, 10:30 pm
You're creating two variables both called buttonState. Not a good idea. Instead of that just use digitalRead(halloween) or digitalRead(starwars) directly in the if statements. Also the } to end your two for loops are in the wrong places. Each loop should just play its notes and then end.
How are your buttons wired? Pull up or pull down resistors fitted?
Steve
Post by: elifrederick on Apr 15, 2019, 07:33 pm
Thank you so much, Steve. Got it working!
I'm using pull-down resistors. I fixed the brackets and threw in digitalRead in place of buttonState and that fixed everything.
Thank you.
Final product:
  Two melodies on two buttons and one speaker
  Plays a melody determined by button pushed
  circuit:
  created 21 Jan 2010
  by Tom Igoe
int halloweenMelody[] = {
int starwarsMelody[] = {
int halloween = 2;
int starwars = 7;
void setup(){
  if (digitalRead(halloween) == 1) {
      tone(8, halloweenMelody [thisNote], noteDuration);
      noTone(8);
  if (digitalRead(starwars) == 1) {
      tone(8, starwarsMelody [thisNote], noteDuration);
      noTone(8);
Post by: GRAVY on Jan 08, 2020, 11:41 pm
I typed in this code, but it just keeps going on with out pressing the button. can someone please fix this code. Thankyou
  circuit:
  created 21 Jan 2010
  by Tom Igoe
int halloween = 2;
int starwars = 7;
void setup(){
      noTone(8);
      noTone(8);
Post by: slipstick on Jan 09, 2020, 12:19 am
How exactly are your buttons wired? Not with pull-down resistors I'd guess.
Steve
Post by: GRAVY on Jan 09, 2020, 11:04 pm
How exactly should I hook up the buttons, can you sent a picture of it?
Thank you so much if you can help
Post by: slipstick on Jan 09, 2020, 11:12 pm
You've already hooked up the buttons and I asked you how. If you can't be bothered answering my question why would I want to bother with yours?
Steve
Post by: GRAVY on Jan 10, 2020, 10:59 pm
I hooked up one button with GND and 2, and another one at 5V and 7, and a pull up resister between these two connecting the two push button
