Arduino Forum
Products => Arduino GSM Shield => Topic started by: rakeshscetic on Apr 15, 2019, 07:23 am
Title: Arduino GSM interface does not receive the SMS though it send SMS
Post by: rakeshscetic on Apr 15, 2019, 07:23 am
Dear Friends,
 I am trying to receive the SMS to A6 IoT GSM module, and try to read that sms over serial port. I am not able to receive the data over the serial port..
I am using this GSM module: https://www.aliexpress.com/item/mini-A6-GPRS-GSM-Kit-Wireless-Extension-Module-Board-Antenna-Tested-Worldwide-Store-for-SIM800L/32710017861.html
 The code is as per below:
#include <SoftwareSerial.h>
#define GSM_RX  2  // Arduino pin 2 to UTX
#define GSM_TX  3  // Arduino pin 3 to URX
SoftwareSerial mySerial(GSM_RX, GSM_TX);
//char msg;
String msg;
   pinMode(4, OUTPUT);
  mySerial.begin(115200);   // Setting the baud rate of GSM Module
  //mySerial.print("AT+CMGF=1r"); // set SMS mode to text
  mySerial.print("AT+CMGF=1\r");  // set SMS mode to text
  delay(200);
   Serial.println("AT+CSMS=1\r");
   delay(200);
   mySerial.println("AT+CNMI=2,2,0,0,0"); // AT Command to receive a live SMS
   //mySerial.print("AT+CNMI=2,2,0,0,0\r");
  //mySerial.print("AT+CNMI=1,2,0,0,0\r"); // AT Command to receive a live SMS
  delay(100);
  Serial.println("Ready");
  if (mySerial.available()>0)
//    digitalWrite(4, HIGH);
    msg=mySerial.readString();
    delay(20);
    Serial.print(msg);
Please help on this..
Thanks
Rakesh Patel
Title: Re: Arduino GSM interface does not receive the SMS though it send SMS
Post by: rakeshscetic on Apr 15, 2019, 05:14 pm
It seems arduino nano is not able to fetch the data from the GSM module.. if i connect GSM module with TTL to USB converter.. i received the perfect string.. But with arduino no luck.
Post by: KASSIMSAMJI on Apr 25, 2019, 06:50 pm
try to reduce 115200   to 9600
Post by: rakeshscetic on May 13, 2019, 06:07 am
I did but no luck.. and other thing is the module is communicate on 115200 baud rate.
Post by: SupArdu on Jun 01, 2019, 08:58 pm
hi,
the example codes seems to me too simple. I have no experience with SIM800 but only with SIM900. The library code for receiving SMS with a SIM900 is like in the attachment.
As you can see there is much more commanding and checking.
Are you sure that your code is sufficient?
Post by: rakeshscetic on Jun 04, 2019, 09:06 am
Its seems this is the library API.
I have installed the library. I wanted to test the Arduino code for SMS receiving application.
