Arduino Forum
Development => Other Hardware Development => Topic started by: cweinhofer on May 02, 2019, 10:52 am
Title: ESP8266 style chipId for ESP32
Post by: cweinhofer on May 02, 2019, 10:52 am
This is not actually a question, but rather a solution I had previously tried searching this forum for and wanted to post for the benefit of other newbies like me.
I have been using ESP8266 boards (LOLIN D1 mini Pro's specifically) for a project and recently started using ESP32 boards (LOLIN D32 Pro's) as well in the same project. When I set up the project originally, I needed a way for the boards to self-identify and found a solution using ESP8266's ESP.getChipId() along with a switch...case. (You can read the background here (http://forum.arduino.cc/index.php?topic=571236.0).)
The chip ID works great for this because it is relatively unique, but still provides an easy to work with integer. However, when moving to the ESP32, I ran into a problem because it doesn't have getChipId. Fortunately, the chip ID for ESP8266 is just a decimal output of the last three bytes of the MAC address. So, you can extract those by truncating using a bitshift after calling the ESP32's MAC address with ESP.getEfuseMac(). You use a 40-bit shift because in the ESP32, the MAC address is defined as a 64-bit integer, but you just want to keep the last 24 bits (aka 3 bytes). Also, I believe ESP.getEfuseMac() is preferred over WiFi.macAddress(), because it's available even before starting the wifi.
Here's the code I came up with:
uint64_t macAddress = ESP.getEfuseMac();
uint64_t macAddressTrunc = macAddress << 40;
chipID = macAddressTrunc >> 40;
The code assumes you have 'uint32_t chipID;' defined in your universal variables at the beginning of the sketch.
If you want to load the same sketch code on both ESP8266s and ESP32s, you can use #ifdef
#ifdef ESP8266
 chipID = ESP.getChipId();
#endif
#ifdef ESP32
#endif
Title: Re: ESP8266 style chipId for ESP32
Post by: pert on May 03, 2019, 12:33 am
Thanks for sharing the solution you found cweinhofer!
Post by: Cicicok on Mar 20, 2020, 12:36 am
If somebody as me will be using this solution, it can lead to unexpected problems. To identify devices I'm using only last 4 bytes from efuseMac. But because the efuseMac address it's written in reverse order than reading it as Wifi MAC I ended up with 2 identical device trying to connect to Mqtt broker, which is big no no.
Just reverse the order and you'll be fine:
uint32_t id = 0;
for(int i=0; i<17; i=i+8) {
  id |= ((ESP.getEfuseMac() >> (40 - i)) & 0xff) << i;
Serial.printf("%08X\n", id);
Post by: cweinhofer on Mar 28, 2020, 03:10 pm
Thanks, Cicicok. You are indeed correct. I had just run into the same problem recently using my (incorrect) method and was trying to figure out what was going on. When I wrote my code, I didn't realize that EfuseMac uses little endian architecture (LSB comes first).
One question - you said you're using the last 4 bytes from efuseMac, but isn't it just the last 3 bytes?
