Arduino Forum
Products => MKR Boards => MKRZero => Topic started by: Calebar on May 13, 2019, 12:24 am
Title: Sketch not working when only battery powered
Post by: Calebar on May 13, 2019, 12:24 am
Hello everyone,
I'm a complete newbie at this but I made this code, which is supposed to detect 5 colors and play a sound from a micro SD card based on which color is detected.
 This reads a wave file from an SD card and plays it using the I2S interface to
 a MAX08357 I2S Amp Breakout board.
 Circuit:
 * Arduino/Genuino Zero, MKRZero or MKR1000 board
 * SD breakout or shield connected
 * MAX08357:
   * GND connected GND
   * VIN connected 5V
   * LRC connected to pin 0 (Zero) or pin 3 (MKR1000, MKRZero)
   * BCLK connected to pin 1 (Zero) or pin 2 (MKR1000, MKRZero)
   * DIN connected to pin 9 (Zero) or pin A6 (MKR1000, MKRZero)
 created 15 November 2016
 by Sandeep Mistry
#include <SD.h>
#include <ArduinoSound.h>
#include "Wire.h"
#include "Adafruit_TCS34725.h"
Adafruit_TCS34725 tcs = Adafruit_TCS34725(TCS34725_INTEGRATIONTIME_50MS, TCS34725_GAIN_1X);
//button logic
int inPin = 5;         // the number of the input pin
int reading;           // the current reading from the input pin
int previous;    // the previous reading from the input pin
// the follow variables are long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long time = 0;         // the last time the output pin was toggled
long debounce = 200;   // the debounce time, increase if the output flickers
// filename of wave file to play
const char SHEEP[] = "SHEEP2.WAV";
const char HORSE[] = "HORSE2.WAV";
const char ROOSTER[] = "ROOSTER2.WAV";
const char DOG[] = "DOG2.WAV";
const char PIG[] = "PIG2.WAV";
// variable representing the Wave File
SDWaveFile waveFile;
  if (!SD.begin(SDCARD_SS_PIN)) {
    return;
  pinMode(inPin, INPUT);
 uint16_t clearcol, red, green, blue;
 float average, r, g, b;
 tcs.getRawData(&red, &green, &blue, &clearcol);
 average = (red+green+blue)/3;
 r = red/average;
 g = green/average;
 b = blue/average;
if (r > 1.2) {
  if (r > 1.75){
  waveFile = SDWaveFile(HORSE);
  AudioOutI2S.volume(80);
  }else if(r > 1.45){
  waveFile = SDWaveFile(PIG);
  }else{
  waveFile = SDWaveFile(DOG);
  AudioOutI2S.volume(50);
 }else if ((r < 0.95) && (g > 1.2) && (b < 0.9)) {
  waveFile = SDWaveFile(SHEEP);
 else if ((r < 0.8) && (g < 1.2) && (b > 1.2)) {
  waveFile = SDWaveFile(ROOSTER);
  AudioOutI2S.volume(60);
  reading = digitalRead(inPin);
  // if the input just went from LOW and HIGH and we've waited long enough
  // to ignore any noise on the circuit, remember
  // the time
  if (reading == LOW && previous == HIGH && millis() - time > debounce) {
   time = millis();
   AudioOutI2S.play(waveFile);
   delay(2500);
  previous = reading;
It works when I have the MKRZero connected by USB but not when I use a 3.7V 2000mAh battery I got from Micro Center. The color sensor I'm using is the Adafruit TCS34725. I used some sketch I found online and it said the voltage my battery supplied was 4.3 V at full charge.
Anyone know what might be preventing my code from working on battery power?
Thanks
Title: Re: Sketch not working when only battery powered
Post by: sandeepmistry on May 13, 2019, 08:03 pm
How are you powering the TCS34725?
In battery mode the 5V pin won't be supplied by the MKR.
