Arduino Forum
Topics => Device Hacking => Topic started by: datKonny on May 25, 2019, 12:00 pm
Title: OKI Microline 390FB parallel interface with Arduino - messed up prints
Post by: datKonny on May 25, 2019, 12:00 pm
Hello, first time posting on here.
I've taken a look at an older post about connecting an Arduino UNO to older parallel/centronics printers (https://forum.arduino.cc/index.php?topic=74776.0). As I don't want to post on dead posts from over four years ago, I made this one.
The printer does actually print some characters, but it looks like the baudrate (does that exist on parallel interfaces like that?) doesn't match. There's an picture of the printed text attached. Playing around with the settings didn't help either; the printer has a few emulation modes (EPSON LQ, IBM PPR..) and Language sets (ASCII, Multilingual, and then at least one for nearly every language).
Is there anything that I'm missing?
Title: Re: OKI Microline 390FB parallel interface with Arduino - messed up prints
Post by: Riva on May 25, 2019, 06:56 pm
What code are you using to talk to the printer and how is it wired up.
The printer port data speed is controlled by the clock signal but you must also read and act on the busy signal from the printer.
Post by: datKonny on May 25, 2019, 07:19 pm
I'm using the code and connections that were used in the original post by sentryGun53.
The original code is as follows:
const int startup_charsPerLine = 80;
const int startup_num_lines = 2;
byte startup_message[startup_num_lines][startup_charsPerLine] = {
  "This is the startup message. It prints whenever",
  "the Arduino is reset.",
const int charsPerLine = 80;   // this is the max # of chars per line
const int num_lines = 10;
byte message[num_lines][charsPerLine] = {
  "    ",   // blank line
  "This is the normal message. It prints whenever",
  "you connect pin 14 (analog 0) to GND.",
  "  ",  // blank line
  "------------------------------------------------------------------------------",   // a spiffy line
  "1) More message content",
  "II) you can have up to about 80 chars per line ",
// parallel port pin# = arduino pin#
const int nStrobe = 2;
const int data_0 = 3;
const int data_1 = 4;
const int data_2 = 5;
const int data_3 = 6;
const int data_4 = 7;
const int data_5 = 8;
const int data_6 = 9;
const int data_7 = 10;
const int nAck = 11;
const int busy = 12;
const int strobeWait = 2;   // microseconds to strobe for
  pinMode(nStrobe, OUTPUT);      // is active LOW
  digitalWrite(nStrobe, HIGH);   // set HIGH
  pinMode(data_0, OUTPUT);
  pinMode(data_1, OUTPUT);
  pinMode(data_2, OUTPUT);
  pinMode(data_3, OUTPUT);
  pinMode(data_4, OUTPUT);
  pinMode(data_5, OUTPUT);
  pinMode(data_6, OUTPUT);
  pinMode(data_7, OUTPUT);
  pinMode(nAck, INPUT);     // is active LOW
  pinMode(busy, INPUT);
  pinMode(13, OUTPUT);
  pinMode(14, INPUT);   // analog pin 0 on duemilanove and uno
  digitalWrite(14, HIGH); // enable pull-up
  resetPrinter();
  printStartupMessage();
  resetPrinter();
  Serial.println("Delay for 5 sec");
  delay(5000);
  Serial.println("Startup complete");
while(digitalRead(14) == HIGH) {
   // wait
  resetPrinter();
  printMessage();
  resetPrinter();
void printByte(byte inByte) {
  while(digitalRead(busy) == HIGH) {
    // wait for busy to go low
  int b0 = bitRead(inByte, 0);
  int b1 = bitRead(inByte, 1);
  int b2 = bitRead(inByte, 2);
  int b3 = bitRead(inByte, 3);
  int b4 = bitRead(inByte, 4);
  int b5 = bitRead(inByte, 5);
  int b6 = bitRead(inByte, 6);
  int b7 = bitRead(inByte, 7);
  digitalWrite(data_0, b0);        // set data bit pins
  digitalWrite(data_1, b1);
  digitalWrite(data_2, b2);
  digitalWrite(data_3, b3);
  digitalWrite(data_4, b4);
  digitalWrite(data_5, b5);
  digitalWrite(data_6, b6);
  digitalWrite(data_7, b7);
  digitalWrite(nStrobe, LOW);       // strobe nStrobe to input data bits
  delayMicroseconds(strobeWait);
    // wait for busy line to go low
void resetPrinter() {
  Serial.println("Reseting printer...");
  printByte(27); // reset printer
  printByte('E');
  Serial.println("Printer Reset");
void printMessage() {
  digitalWrite(13, HIGH);
  for(int line = 0; line < num_lines; line++) {
    for(int cursorPosition = 0; cursorPosition < charsPerLine; cursorPosition++) {
      byte character = message[line][cursorPosition];
      printByte(character);
      delay(1);
    printByte(10); // new line
    printByte(13); // carriage return
  digitalWrite(13,LOW);
void printStartupMessage() {
  Serial.println("Print start-up mssage");
  for(int line = 0; line < startup_num_lines; line++) {
    for(int cursorPosition = 0; cursorPosition < startup_charsPerLine; cursorPosition++) {
      byte character = startup_message[line][cursorPosition];
      //      delay(1);
    Serial.print("Line ");
    Serial.print(line);
    Serial.println(" printed.");
  Serial.println("Startup message printed");
With the original pin config being this:
nStrobe -> Pin 2
data_0 -> Pin 3
data_1 -> Pin 4
data_2 -> Pin 5
data_3 -> Pin 6
data_4 -> Pin 7
data_5 -> Pin 8
data_6 -> Pin 9
data_7 -> Pin 10
nAck -> Pin 11
busy -> Pin 12
Post by: Riva on May 26, 2019, 11:59 am
The code is written for an HP printer and your printer cannot emulate an HP, it can do Epson & IBM.
Change the control codes in the sketch to suit the escape codes for an Epson printer and then set your printer to Epson emulation mode.
This (https://www.oki.com/printing/download/42089405EE2_ML390T_PH_63086.pdf?id=42089405EE) document will help in getting the correct escape codes you need.
