Arduino Forum
Topics => Robotics => Topic started by: talpereczon on May 26, 2019, 02:47 am
Title: H-Block... HELP...full size go-kart RC.
Post by: talpereczon on May 26, 2019, 02:47 am
Hi, I'm building a RC go-kart, and i would like to do the windshield wiper motor for steering, great idea, but I'm having a problem, i tried the L298N, didn't work and the 43A BTS7960B DC Motor Driver Drive Module H-Bridge PWM Control Fast Braking, and nothing is happening, I did it just like all the videos iv'e seen, i don't know what I'm doing wrong, what does the voltage need to be on in 1 & 2, can i use any servo, my receiver works on 5v or 9.3v , tried both no difference, do these things need to be programmed before use or are they plug and play, cause I'm not playing, LOL, please help if you can, I'm using a spectrum DX5C... THANK YOU, Danny........
Title: Re: H-Block... HELP...full size go-kart RC.
Post by: sterretje on May 26, 2019, 06:26 am
Please post a link to the motor that you try to control.
Please post a schematic how everything is wired. A photo of a hand-drawn schematic is fine.
Please post your code.
"Installation and Troubleshooting" is not for problems with your project; I have asked a moderator if it can be moved.
PS
In case you haven't done so yet, read How to use this forum - please read. (https://forum.arduino.cc/index.php?topic=148850.0), specifically related to posting code using code tags and how to insert clickable links using the url tags.
Post by: Coding Badly on May 26, 2019, 08:07 am
@talpereczon, please do not hijack.  Please do not cross-post.  Other post removed.
Post by: talpereczon on May 26, 2019, 07:47 pm
Hi, I'm building a RC go-kart, and i would like to do the windshield wiper motor for steering, great idea, but I'm having a problem, i tried the L298N, didn't work and the 43A BTS7960B DC Motor Driver Drive Module H-Bridge PWM Control Fast Braking, and nothing is happening, I did it just like all the videos iv'e seen, i don't know what I'm doing wrong, what does the voltage need to be on in 1 & 2, can i use any servo, my receiver works on 5v or 9.3v , tried both no difference, do these things need to be programmed before use or are they plug and play, cause I'm not playing, LOL, please help if you can, I'm using a spectrum DX5C... THANK YOU, Danny........This is what I'm trying to do.
https://www.youtube.com/watch?v=n1nEr1FM19E
(https://forum.arduino.cc/index.php?action=dlattach;topic=617971.0;attach=309964;image)
Post by: zwieblum on May 26, 2019, 09:05 pm
Most likely you got the wiring wrong ...
Post by: slipstick on May 26, 2019, 09:47 pm
So what servo are you using? Were you able to modify it as shown in the video? What, if anything happens, when you try it? Does the servo move at all?
Personally I can't tell anything useful from that video so I'd guess that either you're using the wrong components or you've wired them wrong or you're not powering them correctly. Or perhaps the video missed out some essential information.
Steve
Post by: talpereczon on May 26, 2019, 10:57 pm
I'm using  mg996r servo, I plug in the board the same way like in the video, servo works but not the motor. when i put an LED instead of the motor it blinks when i turn left to right. has power for small scale but when i go up nothing happens.. Does the H-bridge need to be programmed before use?
Post by: talpereczon on May 26, 2019, 11:03 pm
Iv'e tried 2 different H-Bridge boards, and got the same result..
Post by: talpereczon on May 26, 2019, 11:35 pm
Steve
Post by: Coding Badly on May 27, 2019, 07:34 am
@talpereczon, stop cross-posting.  Last warning.
Post by: zwieblum on May 27, 2019, 09:05 am
Please post a wiring schematic or at least a photo of what you have built.
