Arduino Forum
Using Arduino => General Electronics => Topic started by: DucksandCo on Jun 14, 2019, 12:37 am
Title: Circuit Symbol
Post by: DucksandCo on Jun 14, 2019, 12:37 am
Hello all,
I am currently making a sprinkler system that waters its plants when the soil is dry enough. My teacher has drew in this diagram regarding how I should hook up my transistor. I dont really know what symbol this really is.
http://Resistor https://imgur.com/gallery/qd8FBSI
This is the actual arduino setup.
http://Ard
https://imgur.com/gallery/YCkygPm
Thank you.
Title: Re: Circuit Symbol
Post by: dl324 on Jun 14, 2019, 12:56 am
(https://imgur.com/gallery/qd8FBSI)
(https://imgur.com/gallery/YCkygPm)
I've found posting pictures on this forum to be somewhat cumbersome.  I see what appears to be two images, but nothing is visible.
EDIT: fiddling with images...
(https://forum.arduino.cc/index.php?action=dlattach;topic=621313.0;attach=312597)
No clue what your teacher is referring to.  We need to know the part number because there are three different pinouts for TO-92 transistors (2N, BC, and 2S).  Since one pin in grounded, I'm guessing it's an NPN transistor with the emitter grounded.
Post by: Southpark on Jun 14, 2019, 02:05 am
Adequate information is required in order to make sense of a circuit diagram. In this case --- not enough information. Device details (eg. transistor model etc) is needed. Also - intended purpose --- ie. what is required for it to do --- should be understood in advance as well.
In this case, there's not enough details. More details are required.
Post by: larryd on Jun 14, 2019, 02:11 am
Boy oh boy, looks like - GND to Emitter, + to maybe a solenoid then maybe the Collector, Dout from an Arduino to the Base.
Post by: dl324 on Jun 14, 2019, 03:37 am
After looking at your second picture, I could see that you're using a transistor in TO-220.
This is the pinout:
(https://forum.arduino.cc/index.php?action=dlattach;topic=621313.0;attach=312612)
Your teacher should have drawn the schematic this way:
(https://forum.arduino.cc/index.php?action=dlattach;topic=621313.0;attach=312614)
Post by: Southpark on Jun 14, 2019, 07:18 am
Could it be a logic level mosfet too?
Post by: larryd on Jun 14, 2019, 07:23 am
Forgot to include a kickback diode.
Post by: Paul__B on Jun 14, 2019, 02:31 pm
Oh dear, pictures (clickable)!
(https://i.imgur.com/rpwBhlq.jpg) (https://i.imgur.com/rpwBhlq.jpg)
(https://i.imgur.com/RrM4ALr.jpg) (https://i.imgur.com/RrM4ALr.jpg)
(https://i.imgur.com/6gCjXVJ.jpg) (https://i.imgur.com/6gCjXVJ.jpg)
Post by: dl324 on Jun 14, 2019, 04:51 pm
If your response was regarding my post, I redrew what the teacher drew, not what it should have been.
Post by: dl324 on Jun 14, 2019, 05:30 pm
The resistor on the lead marked Dout wouldn't be necessary and a resistor from gate to source would have been included so the gate wouldn't float when the GPIO port wasn't active.
Post by: larryd on Jun 14, 2019, 05:35 pm
No, I was looking at the teachers image.
Post by: Southpark on Jun 14, 2019, 11:43 pm
This is all based on assumptions, which is why it can be a time-wasting exercise if there's inadequate details to begin with.
Additionally, if you assume a BJT, then the input could become floating under those conditions you mentioned too maybe, right?
Also ----- using series resistor for gates of mosfets is not uncommon.
It may well be a BJT. And all I'm saying is - if there's not enough information to start with - then it's like a goose chase.
Post by: Southpark on Jun 15, 2019, 11:10 am
Make sure your breadboard connections are correct too. Example..... hole j1 has an orange wire..... but the purpose of it is unclear. Same for hole c1.
