Hello,
I want to use an PIR (cheap china PIR) to detect motion and light some LEDs. I am using an Arduino Uno (cheap china as well. We need a lot of them for a festival).
The motion detection itself works fine. When a motion gets detected it changes color (currentDefaultMotionColor), and when there is no motion anymore, it changes back to the color before (currentDefaultColor).
BUT now I want to change the used default colors after a certain period of time to make it more interesting - so I added code for that. And there the problem starts
The motion sensor works fine until the program first executes the function changeDefaultColors. After that the motion sensor goes on and off without any reason.
I got noooo clue where the problem is maybe someone can help...
#include <Adafruit_NeoPixel.h>
#define MATRIX_PIN 7 // Matrix
#define PIR_PIN 6 // Bewegungsmelder
#define NUMPIXELS 64
#define COLOR_CHANGE_FREQUENCE 300 // Sekunden
#define COLOR_QUANTITY 6
Adafruit_NeoPixel pixels(NUMPIXELS, MATRIX_PIN, NEO_GRB + NEO_KHZ800);
const uint32_t RED = pixels.Color(255, 0, 0);
const uint32_t GREEN = pixels.Color(0, 255, 0);
const uint32_t MAGENTA = pixels.Color(255, 0, 255);
const uint32_t YELLOW = pixels.Color(255, 255, 0);
const uint32_t WHITE = pixels.Color(255, 255, 255);
const uint32_t BABYBLUE = pixels.Color(0, 255, 255);
const uint32_t COLORS [COLOR_QUANTITY] = {RED, GREEN, MAGENTA, YELLOW, WHITE, BABYBLUE};
volatile uint32_t currentDefaultColor = RED;
volatile uint32_t currentDefaultMotionColor = GREEN;
int pirState = LOW; // we start, assuming no motion detected
int val = 0; // variable for reading the pin status
unsigned long previousMillis = 0; // last time update
unsigned long currentMillis = 0;
long interval = 30000; // interval at which to do something (milliseconds)
SETUP
randomSeed(analogRead(3)); //use random analog pin noise as seed for random generator
pixels.begin(); // INITIALIZE NeoPixel strip object (REQUIRED)
pinMode(PIR_PIN, INPUT); // declare sensor as input
long getRandomNumber() {
long randNumber = random(COLOR_QUANTITY); // 9 is the size of COLORS
Serial.println(randNumber);
return randNumber;
uint32_t chooseRandomCurrentlyUnusedColor() {
Serial.println("chooseRandomCurrentlyUnusedColor");
uint32_t newColor = COLORS[getRandomNumber()];
while (newColor == currentDefaultColor || newColor == currentDefaultMotionColor) {
return newColor;
void udpateColor(uint32_t color) {
for (int i = 0; i < NUMPIXELS; i++) { // For each pixel...
pixels.setPixelColor(i, color);
pixels.show(); // Send the updated pixel colors to the hardware.
void changeDefaultColors() {
Serial.println("changeDefaultColors");
uint32_t newCurrentDefaultColor = chooseRandomCurrentlyUnusedColor();
currentDefaultColor = newCurrentDefaultColor;
uint32_t newCurrentDefaultMotionColor = chooseRandomCurrentlyUnusedColor();
currentDefaultMotionColor = newCurrentDefaultMotionColor;
LOOP
currentMillis = millis();
if (currentMillis - previousMillis > interval) {
Serial.println("interval is over");
previousMillis = currentMillis;
changeDefaultColors();
delay(50);
val = digitalRead(PIR_PIN); // read input value
if (val == HIGH) { // check if the PIR input is HIGH
udpateColor(currentDefaultColor);
if (pirState == LOW) { // we have just turned ON
Serial.println("Motion detected");
pirState = HIGH; // We only want to print on the output change, not state
udpateColor(currentDefaultMotionColor);
if (pirState == HIGH) { // we have just turned OFF
Serial.println("Motion ended");
pirState = LOW; // We only want to print on the output change, not state
Motion detected
Motion ended
Motion detected
Motion ended
interval is over
changeDefaultColors
3
2
Motion detected
Motion ended
Motion detected
Motion ended
Motion detected
Motion ended
Motion detected
Motion ended
Motion detected
Motion ended
UPDATE:
I tried to change the colors pretty lame using a switch statement - and that seems to work. So I guess there is some mistake in my "random color change alrorithms".
