Arduino Forum
Using Arduino => Project Guidance => Topic started by: skyjumper on Sep 14, 2019, 03:31 am
Title: ESP32 and FreeRTOS and atomic updates
Post by: skyjumper on Sep 14, 2019, 03:31 am
Hi All...
I'm playing with an ESP32 card, which is 32 bit and my understanding is that its Arduino lib port is based on FreeRTOS.
If I have a data structure full of floats, like this:
typedef struct {
  float var1;
  float var2;
  float var3;
} tRawData;
and I then have an instance of this type:
tRawData rawData;
When I update the members, since floats are 32 bits wide and the ESP32 is a 32 bit processor, is it correct that the updates to these members are atomic? I realize that updates to the entire data type may not be atomic, but am I at least guaranteed that the update of any individual member is atomic?
I ask of course because I want to populate this type in one thread (task) and consume the data in another thread.
Thanks very much...
Title: Re: ESP32 and FreeRTOS and atomic updates
Post by: Idahowalker on Sep 14, 2019, 04:33 am
Going off this
Atomic operations in concurrent programming are program operations that run completely independently of any other processes.
. Your update task would be the only task or have the highest preemptive priority, for the moment, running on the assigned core. I would, also assign such a task to Core0. Hrrumph or is that Core1, I got it wrote down somewhere. Yup, I am correct, setup() and loop() are run on core1. So you'd run your task on core0.
If you are meaning that the ESP32 memory/register changes are done as a single 32 bit operation, then yes that is the case.
If you want to run freeRTOS on the ESP32 you'l need to include freeRTOS.
#include "esp_system.h" //This inclusion configures the peripherals in the ESP system.
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "freertos/timers.h"
#include "freertos/event_groups.h"
Post by: Idahowalker on Sep 14, 2019, 04:35 am
Using queues is the way to pass info from one task to another or from core to core.
Post by: skyjumper on Sep 14, 2019, 05:13 am
Yes I could use queues, or also semaphores / mutexes, but if 32 bit variables are updated atomically in this 32 bit processor that is unnecessary. That's what I'm trying to figure out.
Post by: skyjumper on Sep 14, 2019, 05:17 am
Going off this . Your update task would be the only task or have the highest preemptive priority, for the moment, running on the assigned core. I would, also assign such a task to Core0. Hrrumph or is that Core1, I got it wrote down somewhere. Yup, I am correct, setup() and loop() are run on core1. So you'd run your task on core0.
Okay I'll take a closer look at the xTaskCreate() function but I recall that I can assign a priority but not necessarily a core. It's good to know setup() and loop() run on core 1, thanks.
Yes so I expect the compiler generated code moves the variable through the register.
Interestingly, selecting the ESP32 in the Arduino dev environment, I was able to create tasks in my app, and run the samples, without including any of that. I don't know why.
Post by: Idahowalker on Sep 14, 2019, 05:42 am
xTaskCreatePinnedToCore( fSendSerialToBrain, "fSendSerialToBrain", TaskStack20K, NULL, Priority3, &xHANDLE_SendSerialToBrain, TaskCore0 );
Post by: czu001 on Sep 14, 2019, 05:50 am
Yes 32 bit operations are atomic.  But.. protecting shared data between tasks is a different matter.
Post by: skyjumper on Sep 14, 2019, 10:09 pm
Right at this point if I have atomic reads and writes then I won't run the risk of reading a variable while it is half updated. Thats good enough for now.
