Arduino Forum
Using Arduino => Microcontrollers => Topic started by: carlosserious on Jan 22, 2020, 08:33 am
Title: ATMEGA328p Power 3.3v boost?
Post by: carlosserious on Jan 22, 2020, 08:33 am
I currently have a circuit I'm working on that runs on a 'barebones' arduino. I want to power it with a 3.3v input, like 3 aa batteries(I know it's 4.5, close enough), as it drains below 2.7v, the circuit will cut off.
Is it worth adding a boost module to get more life out of the batteries and establish a consistent 3.3v operation?
Title: Re: ATMEGA328p Power 3.3v boost?
Post by: srnet on Jan 22, 2020, 09:11 am
If its a bare bones Arduino set the BOD level to 1.8V.
Post by: ShermanP on Jan 22, 2020, 07:17 pm
I don't think a boost regulator makes sense.  By the time the AAs are down to .9V each, they will be pretty close to being fully discharged.  And if you add a regulator, you will inevitably lose some efficiency - maybe 10-15%.  It's not at all certain that adding the regulator would increase battery life.  It might reduce it.
Post by: DrAzzy on Jan 22, 2020, 08:30 pm
Agree. If you use sleep to reduce power consumption, it definitely will, because the quiescent current of the regulator will continue no matter what (this is even true of a linear regulator, where the quiescent current is much lower than a boost regulator; it's easy to forget just how low the current drawn by a sleeping microcontroller can be).
