Arduino Forum
Using Arduino => Programming Questions => Topic started by: aimmet on Feb 11, 2020, 03:40 am
Title: value j not increment properly
Post by: aimmet on Feb 11, 2020, 03:40 am
Hello all, I noticed when im trying to incrememnt j every 100 milliseconds using the Millis(); function, I realized j is not going up by 1. it just stays at 0. Whats the proper way to get the j to increment by 1 every 100 milliseconds? (Ill only post the part of the code where its happening to make reading more simple)
  int i;
  static int j = 0;
  unsigned long interval = 100;
  unsigned long currentMillis = millis();
  unsigned long previousMillis;
  if (currentMillis - previousMillis >= interval)
            j + 1;
            previousMillis = currentMillis;
              if (j == 256)
                  j = 0;
    for(i=0; i< 2; i++) {
      strip.setPixelColor(i, j, j, j);
    strip.show();
    Serial.println(j);
Title: Re: value j not increment properly
Post by: sterretje on Feb 11, 2020, 04:14 am
Use on of the below
j++;
j+=1;
j=j+1;
Post by: vaj4088 on Feb 11, 2020, 05:18 am
Code snippets are not very helpful.
j+1 does not store its result anywhere.  j++ does.
Post by: aimmet on Feb 13, 2020, 04:03 am
I replaced it with both j+=1 and j== yet the value still remains zero. is it an issue with the millis counter?
Post by: gfvalvo on Feb 13, 2020, 04:06 am
No, it's an issue with your code that we can't see. Show us this latest attempt.
Post by: vaj4088 on Feb 13, 2020, 04:08 am
No one said to try j==.
Please post good code that does not increment j.  The whole thing please, not just a snippet.  There is a good chance that the problem is in the part that we cannot see.
Post by: boolrules on Feb 13, 2020, 07:14 am
If this is in loop( ) you could likely be setting currentMillis( ) faster than 100mS.
You also have a block for maybe no good reason.
Why do you have so many spaces in your code?
Post by: aimmet on Feb 17, 2020, 04:47 am
Sorry, heres the entire code, the j incrementing happens in rainbowcycle function
#include <Adafruit_NeoPixel.h>
#define NUM_LEDS 3
#define BRIGHTNESS 75
#define PIN A0
//const int LED = A0;
const int Xs = 9;// pins the buttons are attached too
const int A = 4;//
const int B = 5;//
const int X = 8;//
const int Y = 7;//
const int DL = 6;//
int lastButtonState;
int buttonState;
double long aPressed; // values to insert millis value
double long bPressed;
double long xPressed;
double long yPressed;
double long dlPressed;
double long xsPressed;
byte R; // byte variables
byte G;
byte V;
int zero = 0;
unsigned long previousMillis = 0;
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, PIN, NEO_GRB + NEO_KHZ800);
  int a = digitalRead(A); //read digital inputs into integers
  int b = digitalRead(B);
  int x = digitalRead(X);
  int y = digitalRead(Y);
  int dl = digitalRead(DL);
  int xs = analogRead(Xs); // 0-360-728
  pinMode(A, INPUT);
  pinMode(B, INPUT);
  pinMode(X, INPUT);
  pinMode(Y, INPUT);
  pinMode(DL, INPUT);
  pinMode(Xs, INPUT);
  strip.setBrightness(BRIGHTNESS);
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
  byte Wheel = 0;
  static int pattern = 0, lastReading;
  double long Millis = millis();
  //------------------------CONDITIONS BEGIN HERE------------------------------------------//
  if (b == 0) //when pressed, turn on LEDs to RED
      strip.clear();
      bPressed = Millis;
      strip.setPixelColor(2, 255, 0, 0);
      strip.show();
      strip.setPixelColor(1, 255, 0, 0);
      strip.show();
      strip.setPixelColor(0, 255, 0, 0);
      strip.show();
      strip.clear();
  else if (30 + bPressed > Millis) // bPressed will be higher than Millis momentarily, execute color fade
      uint16_t ib, jb;
      for (jb = 255; jb > 0; jb--) {
        for (ib = 0; ib < 2; ib++) {
        strip.setPixelColor(ib, jb, 0, 0);
      strip.show();
      //Serial.println(j);
      strip.clear();
  if (x == 0)
      xPressed = Millis;
      for (int ixx=0; ixx<3; ixx++)
      strip.setPixelColor(ixx, 0, 255, 255);
      strip.show();
  else if (30 + xPressed > Millis)
      uint16_t ix, jx;
      for (jx = 255; jx > 0; jx--) {
        for (ix = 0; ix < 2; ix++) {
        strip.setPixelColor(ix, 0, jx, jx);
      strip.show();
      strip.clear();
     else if (x == 1)
       for (int I = 0; I < 2; I++)
       strip.setPixelColor(I, 0, 0, 0);
       strip.show();
     strip.clear();
      if ((a && b && x && y && dl && (xs == 360 || xs == 361)) == 1)
        rainbowCycle();
 // functions for future use
void rainbowCycle() {
  byte *c;
  int i;
  static int j = 0;
            j++;
            if (j == 256)
              j = 0;
    strip.show();
    Serial.println(j);
byte * Wheel(byte WheelPos) {
  static byte c[3];
  if(WheelPos < 85) {
   c[0]=WheelPos * 3;
   c[1]=255 - WheelPos * 3;
   c[2]=0;
  } else if(WheelPos < 170) {
   WheelPos -= 85;
   c[0]=255 - WheelPos * 3;
   c[1]=0;
   c[2]=WheelPos * 3;
   WheelPos -= 170;
   c[0]=0;
   c[1]=WheelPos * 3;
   c[2]=255 - WheelPos * 3;
  return c;
Post by: evanmars on Feb 17, 2020, 05:10 am
When do you ever update currentMillis?
Post by: aimmet on Feb 18, 2020, 05:52 am
its at the top when defining the terms.
Post by: vaj4088 on Feb 18, 2020, 05:59 am
currentMillis is declared at the top and given an initial value but it never changes after that.  Does it need to get a fresh value at the top of the loop() function?
