Arduino Forum
Using Arduino => Microcontrollers => Topic started by: unielli95 on Jul 12, 2020, 11:36 am
Title: Issues with led stip and nodemcu
Post by: unielli95 on Jul 12, 2020, 11:36 am
Hi!
i'm facing strange problems using the nodemcu (with the esp8266) and the led stip WS2812B: at the moment i'm trying to turn the led stip on by jsut connecting the red and white wires to the V- and V+ or this https://www.amazon.it/gp/product/B01LZF6NK6/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1 (i have bought this one because the led stip wants DC5V and 0.60mA for each led, so more or less 18A)
I'm not wiring the green wire (the data one) because i just want to test the stip.
The result is that my led stip is not turning on. Is the stip faulty? do i have to connect the green wire too?
In order to connect the strip i have connected only the red and white wires (like thi https://www.info4blog.it/wp-content/uploads/2020/01/Schema_Striscia.png)
I also tried to connect the nodemcu to the power supply with the Vin and GN (using 5V) but without succes.
Title: Re: Issues with led stip and nodemcu
Post by: DrAzzy on Jul 12, 2020, 04:27 pm
WS2812-and-similar individually addressable LEDs are controlled by the data sent by the microcontroller (on that third wire, which is apparently green in your case - the colors aren't standardized). If you do not send any data, they won't turn on - you haven't told them to! They're obediently waiting for data to be sent down that dangling wire (it would be really bad if they did turn on of their own accord, because then you'd always need a power supply that could handle all of the LEDs being on at full power; it's quite common to use a smaller power supply if you know your code won't ever turn them all on at once)
Post by: groundFungus on Jul 13, 2020, 04:04 am
If you search for "nodemcu ws2812" there are many pages and videos.
Post by: unielli95 on Jul 13, 2020, 11:13 am
Thank you! adding the data wire did the trick.
i have searched but did not find the information i was looking for, "if the led strip would have worked without the data wire" but thanks to DrAzzy i got it to work.
thank you guys =)
