Arduino Forum
International => Español => Topic started by: flico on Aug 20, 2011, 10:00 am
Title: Conectar celula de carga usando un CS5532 (info)
Post by: flico on Aug 20, 2011, 10:00 am
No se quien me pregunto hace tiempo por privado el como se podia conectar una celula de carga al arduino. Hasta ahora lo que se me podia ocurrir era usar un operacional tipo INA125 junto con ADC de 24 bit. Pues bien otra solucion seria usar un CS5532 con interfaz SPI.
Os dejo el datasheet y ejemplo de uso.
#include <SPI.h>
const byte CHANNELREG011 = 0b00110000;
const byte CHANNELREG012 = 0b01000000;
const byte CHANNELREG013 = 0b00000000;
const byte CHANNELREG014 = 0b00000000;
const byte CHANNELREG021 = 0b01110000;
const byte CHANNELREG022 = 0b01000000;
const byte CHANNELREG023 = 0b00000000;
const byte CHANNELREG024 = 0b00000000;
const byte CONFIGREG11 = 0b00000010;
const byte CONFIGREG12 = 0b00000000;
const byte CONFIGREG13 = 0b00000000;
const byte CONFIGREG14 = 0b00000000;
const byte READ01 = 0b10000000;
const byte READ02 = 0b10001000;
const byte CONF_RESET1 = 0b00100000;
const byte CONF_RESET2 = 0b00000000;
const byte CONF_RESET3 = 0b00000000;
const byte CONF_RESET4 = 0b00000000;
const byte COMMAND_CONFGREG = 0b00000011;
const byte COMMAND_CHANNELREG1 = 0b00000101;
const byte COMMAND_CHANNELREG2 = 0b00010101;
const byte COMMAND_READCONF = 0b00001011;
byte CONF_READED = 0;
byte CONF_READED2 = 0;
byte CONF_READED3 = 0;
byte CONF_READED4 = 0;
byte CONF_TMP1 = 0, CONF_TMP2 = 0, CONF_TMP3=0;
void ADreset(){
//digitalWrite(SS,LOW);
for(int i = 0;i<15;i++){
 SPI.transfer(0xFF);}
SPI.transfer(0xFE);
delay(50);
 SPI.transfer(COMMAND_CONFGREG);
 SPI.transfer(CONF_RESET1);
 SPI.transfer(CONF_RESET2);
 SPI.transfer(CONF_RESET3);
 SPI.transfer(CONF_RESET4);
 SPI.transfer(COMMAND_READCONF);
 CONF_READED2 = SPI.transfer(0x00);
 CONF_TMP1 = SPI.transfer(0x00);
 CONF_TMP2 = SPI.transfer(0x00);
 CONF_TMP3 = SPI.transfer(0x00);
 CONF_READED2 = CONF_READED2 << 8;
 CONF_READED = CONF_READED2 | CONF_TMP1;
 CONF_READED = CONF_READED << 8;
 CONF_READED = CONF_READED | CONF_TMP2;
 CONF_READED = CONF_READED | CONF_TMP3;
 Serial.println(CONF_READED,BIN);
 //  CONF_READED = CONF_READED << 8;
// CONF_READED = CONF_READED | CONF_TMP;
//  CONF_TMP = SPI.transfer(0x00);
// digitalWrite(SS,HIGH);
void ADConfig(){
// digitalWrite(SS, LOW);
 SPI.transfer(CONFIGREG11);
 SPI.transfer(CONFIGREG12);
 SPI.transfer(CONFIGREG13);
 SPI.transfer(CONFIGREG14);
 delay(10);
 SPI.transfer(COMMAND_CHANNELREG1);
 SPI.transfer(CHANNELREG011);
 SPI.transfer(CHANNELREG012);
 SPI.transfer(CHANNELREG013);
 SPI.transfer(CHANNELREG014);
 delay(10);
 SPI.transfer(COMMAND_CHANNELREG2);
 SPI.transfer(CHANNELREG021);
 SPI.transfer(CHANNELREG022);
 SPI.transfer(CHANNELREG023);
 SPI.transfer(CHANNELREG024);
 delay(10);
// digitalWrite(SS, HIGH);
 CONF_READED2 = SPI.transfer(COMMAND_READCONF);
 CONF_READED = CONF_READED2 << 8;
 CONF_READED = CONF_READED | CONF_TMP1;
 Serial.println(CONF_TMP1,BIN);
 Serial.println(CONF_TMP2,BIN);
// pins used for the connection with the sensor
// the other you need are controlled by the SPI library):
 // start the SPI library:
 SPI.begin();
 SPI.setClockDivider(SPI_CLOCK_DIV16);
 SPI.setDataMode(SPI_MODE2);
 // initalize the  data ready and chip select pins:
 ADreset();
 ADConfig();
 delay(100);
int SerialRead = 0;
int SerialTMP = 0;
int incomingByte = 0;
Serial.println("AD CS5532 - Programa de teste ");
Serial.println("Para ler canal AD 01, precione 1 ");
Serial.println("Para ler canal AD 02, precione 2 ");
Serial.println("Para ler REG_CONF, precione 3 ");
while(SerialRead == 0){
//Serial.println(SerialTMP);
if (Serial.available() > 0) {
SerialRead = Serial.read();
Serial.print("I received: ");
Serial.println(SerialRead, DEC);
switch(SerialRead){
case 49:
readAD1();
delay(100);
break;
case 50:
readAD2();
delay(100);
break;
case 51:
Serial.println(CONF_READED2,BIN);
break;
SerialRead = 0;
//Read from or write to register from the SCP1000:
unsigned int readAD1() {
 byte inByte = 0;           // incoming byte from the SPI
 unsigned int result = 0;   // result to return
 unsigned int result_blank = 0;   // result to return
 Serial.print("Comando Enviado: ");
 Serial.println(READ01, BIN);
 SPI.transfer(READ01);
 // send a value of 0 to read the first byte returned:
 result_blank = SPI.transfer(0x00);
 // decrement the number of bytes left to read:
 result = SPI.transfer(0x00);
 // if you still have another byte to read:
 for(int i = 0;i<2;i++) {
   // shift the first byte left, then get the second byte:
   result = result << 8;
   inByte = SPI.transfer(0x00);
   // combine the byte you just got with the previous one:
   result = result | inByte;
 // take the chip select high to de-select:
 //digitalWrite(SS, HIGH);
 // return the result:
 Serial.print("Valor recebido: ");
 Serial.println(result,BIN);
 return(result);
unsigned int readAD2() {
 Serial.println(READ02, BIN);
 SPI.transfer(READ02);
 // decement the number of bytes left to read:
 return(result);
Saludos.
Title: Re: Conectar celula de carga usando un CS5532
Post by: Heke on Aug 20, 2011, 07:39 pm
Flico
Una pregunta, Celula de carga ¿es un medidor de presion?
Post by: flico on Aug 21, 2011, 12:26 am
Una célula de carga es un traductor que convierte la fuerza que le aplicas en una tensión proporcional a ella, siendo esta unos pocos milivoltios de hay que haya que usar operacionales para amplificar en nivel de señal.
(http://www.antistaticbar.org/products/images/pl-series-load-cell-kck.jpg)
Internamente las celulas de carga son varias galgas extensiometricas y varias resistencias de carbón configuradas en puente.
En resumidas cuentas una celula de carga es la pieza principal de una bascula electrónica.
En este enlace viene las diversas formas de adaptar los niveles de tensión.
http://www.national.com/en/industrial/sensing/pressure_load.html (http://www.national.com/en/industrial/sensing/pressure_load.html)
Saludos.
Post by: curro92 on Aug 21, 2011, 05:02 am
Hola flico,
Gracias, algún día tengo pensado aplicar un medidor de peso a una colmena de abejas, para ver la evolución de la cosecha. Seguro que me servirá.
No te olvides de añadir (info) en el 'Subject'
Title: Re: Conectar celula de carga usando un CS5532 (info)
Post by: maxid on Sep 19, 2012, 05:01 am
Hola, @flico, voy a recibir unas muestras del cs5534 para usar 2 celdas de carga, me podrias contar con el ad de arduino mide bien? tengo que pesar 400kg con un error maximo de 1kg
Post by: flico on Sep 19, 2012, 03:32 pm
Al final lo hice con un INA125, porque el CS5532 no lo localice. Ya nos contaras.
Post by: maxid on Sep 19, 2012, 09:56 pm
Me suscribi a Cirrus logic y me envias 5 muestra de ese sin cargo, tambien pedi de texas unos ina125.
Pregunto porque necesito leer una celdas con arduino para hacer un pequeno sistema de dosaje y mezclado, tengo experiencia en el tema pero no de la parte electronica con AD. Donde trabajaba hice un sistema de dosje de cemento. Ahora intento hacerlo por mi cuenta pero algo muy simple y especifico.
Post by: maxid on Sep 26, 2012, 01:55 am
podrias contarme como conectaste el ina125, tengo 2 celdas de 1000kg que tengo que usar y no se como conectaqrlas sumadas o en paralelo como se deba hacer.
Post by: flico on Sep 26, 2012, 04:14 pm
Para conectar dos celulas de carga se usan cajas de sumas pero tampoco se mucho.
http://www.sensocar.com/web.asp?mod=cataleg&idProducte={AADBA671-95AE-41B4-9886-CB0B67D68C70} (http://www.sensocar.com/web.asp?mod=cataleg&idProducte={AADBA671-95AE-41B4-9886-CB0B67D68C70})
Post by: jose_francisco on Sep 28, 2012, 10:39 pm
Una cosa...
  el CS5532 es dificil de soldar, ¿no? ¿Como lo has hecho?
Un saludo.
Post by: flico on Sep 28, 2012, 10:58 pm
Ya tengo respuesta.
Todos los pines van en paralelo. El positivo de alimentacion de cada celula pasa por un potenciometro de  50ohm
Post by: flico on Sep 28, 2012, 11:32 pm
Hay una libreria que se podria usar con arduino.
Post by: maxid on Sep 29, 2012, 02:12 am
bien, el hilo se pone interesante!!!.
@Jose Francisco: Tengo una estacion de soldadura con aire caliente, y con punta bien fina, aun no hice la placa, y nunca he soldado mas de SOIC, pero para soldar se usa flux y pasta de soldadura, o con un estaño muy fino, una lupa muy grande y tremenda paciencia.
Cuando tenga el circuito para soldar pongo mi experiencia.
Les parece si armamos entre todos una placa amplificadora de celdas? tengo cs5534 para 4 celdas.
Post by: jose_francisco on Sep 30, 2012, 08:55 pm
Una interfaz de células de carga es uno de mis proyectos pendientes.
Post by: maxid on Oct 01, 2012, 06:02 am
lo tomo como un si?
Soy de Córdoba/Argentina
Post by: maxid on Oct 03, 2012, 07:36 pm
Aca les dejo un esquema de conexion con una sola celda pero es cuestion de duplicar la etapa de filtrado.
Pronto subo el pcb en eagle de esto.
Post by: flico on Oct 03, 2012, 09:16 pm
Las dos celdas de carga es porque quieres pesar dos cosas
Post by: maxid on Oct 04, 2012, 04:14 am
la idea de una interfaz de celdas es tener varias entradas aprovechando todo el conversor, yo tengo muestras del cs5534 de 4 canales
