Arduino Forum
Using Arduino => Networking, Protocols, and Devices => Topic started by: mamw on Sep 11, 2020, 04:33 pm
Title: Serial monitor shows squares
Post by: mamw on Sep 11, 2020, 04:33 pm
hi,
I have an arduino nano that connected to sim800l. the problem is that when i try to print data coming from gsm the serial monitor shows squares but when I write to serial monitor it show what i am typing.
my baud rate both are 9600 and in the serial monitor is the same. The code was working good but now it is not.
here is the code  I am using
#include <SoftwareSerial.h>
//Create software serial object to communicate with SIM800L
SoftwareSerial mySerial(2, 3); //SIM800L Tx & Rx is connected to Arduino #3 & #2
  //Begin serial communication with Arduino and Arduino IDE (Serial Monitor)
  //Begin serial communication with Arduino and SIM800L
  mySerial.begin(9600);
  Serial.println("Initializing...");
  mySerial.println("AT"); //Once the handshake test is successful, it will back to OK
  updateSerial();
  mySerial.println("AT+CSQ"); //Signal quality test, value range is 0-31 , 31 is the best
  updateSerial();
  mySerial.println("AT+CCID"); //Read SIM information to confirm whether the SIM is plugged
  updateSerial();
  mySerial.println("AT+CREG?"); //Check whether it has registered in the network
  updateSerial();
 updateSerial();
void updateSerial()
  while (Serial.available())
    mySerial.write(Serial.readString());//Forward what Serial received to Software Serial Port
  while(mySerial.available())
    Serial.write(mySerial.read());//Forward what Software Serial received to Serial Port
I just copy it from https://lastminuteengineers.com/
(https://forum.arduino.cc/index.php?action=dlattach;topic=704645.0;attach=381392;image)
Title: Re: Serial monitor shows squares
Post by: ieee488 on Sep 12, 2020, 04:28 am
take a look at http://www.martyncurrey.com/hc-05-with-firmware-2-0-20100601/#AT-Command-Mode (http://www.martyncurrey.com/hc-05-with-firmware-2-0-20100601/#AT-Command-Mode) which is similar to what you are doing except for the different baud rate
Post by: GolamMostafa on Sep 12, 2020, 01:59 pm
Try the following line:
Serial.print(mySerial.read());//Forward what Software Serial received to Serial Port
Or
Serial.write((char)mySerial.read());//Forward what Software Serial received to Serial Port
Post by: mamw on Sep 16, 2020, 10:08 pm
thanks for your reply,
the first line shows 255255255255255255255...
the second shows squares
Post by: cattledog on Sep 17, 2020, 01:35 am
What changed?
