Arduino Forum
Using Arduino => Motors, Mechanics, Power and CNC => Topic started by: ampedimagery on Sep 16, 2020, 09:14 pm
Title: Stepper Motor Speed and Direction with one Potentiometer
Post by: ampedimagery on Sep 16, 2020, 09:14 pm
Looking for the best way to control speed and direction of a stepper motor using 1 pot
Title: Re: Stepper Motor Speed and Direction with one Potentiometer
Post by: Robin2 on Sep 16, 2020, 09:34 pm
Something like this ?
int potVal  = analogRead(potPin); // range 0-1023
potVal = potVal - 512; // range -512 to + 511
If (potVal < 0) {
  dirn = 'F';
else {
  dirn = 'R';
absPotVal = abs(potVal); // make sure it's positive
millisBetweenSteps = map(absPotVal, 0, 511, xx, mm) // xx = high value for slow speed, mm = low value for high speed
...R
Stepper Motor Basics (http://forum.arduino.cc/index.php?topic=284828.0)
Simple Stepper Code (http://forum.arduino.cc/index.php?topic=277692.0)
Post by: ampedimagery on Sep 16, 2020, 09:38 pm
I am very new to this and really dont know anything yet. This is my first arduino project. we are using a 12v nema 17 and eventually a 12v 12Nm Nema 34 to drive our machine. We are using 12v power supply, arduino, motor and l298n driver. i am wanting to change direction and speed in real time with a single pot
Post by: CrossRoads on Sep 16, 2020, 09:39 pm
potVal = potVal = 512; // range -512 to + 511
Typo perhaps?
Maybe this:
Post by: Robin2 on Sep 16, 2020, 10:40 pm
Typo perhaps?
Thanks for spotting that. I have corrected it.
...R
Post by: Robin2 on Sep 16, 2020, 10:41 pm
Have you carefully considered Reply #1 - does it meet your need?
...R
Post by: jremington on Sep 17, 2020, 01:40 am
Start with something simpler, like getting your stepper to work.
You need an Arduino, an appropriate motor power supply, wire the driver to the motor without using a breadboard (because the breadboard connectors will burn) and importantly, set the motor driver current limit properly. You will need a multimeter for that.
