Arduino Forum
Using Arduino => Networking, Protocols, and Devices => Topic started by: Howwee on Sep 16, 2020, 09:22 pm
Title: simple modbus master
Post by: Howwee on Sep 16, 2020, 09:22 pm
Can anyone explain how the function 15
FORCE_MULTIPLE_COILS
Works
i have been running some test on this
and cant figure out how to use the
local_start_address
is this the data to read from
or
is it a pointer to another File
modbus_construct(&packets[PACKET1], 1, 15, 1, 8, 1021);
dec 8 = (no_of_registers = packet->data)  // number of coils
so frame 6 = 1 (frame[6] = no_of_bytes;) // number of bytes more
dec 1021 = (packet->local_start_address)
the dec 1021 and 65565 seams to work
but makes no sense to me in binary format ?
part of CPP file:
unsigned char construct_F15()
   // function 15 coil information is packed LSB first until the first 16 bits are completed
  // It is received the same way..
  unsigned char no_of_registers = packet->data / 16;
  unsigned char no_of_bytes = no_of_registers * 2;
  // if the number of points dont fit in even 2byte amounts (one register) then use another register and pad
  if (packet->data % 16 > 0)
    no_of_registers++;
    no_of_bytes++;
  unsigned char bytes_processed = 0;
  unsigned char index = 7; // user data starts at index 7
   unsigned int temp;
  for (unsigned char i = 0; i < no_of_registers; i++)
    temp = register_array[packet->local_start_address + i]; // get the data
frame[index] = temp & 0xFF;
    bytes_processed++;
    if (bytes_processed < no_of_bytes)
      frame[index + 1] = temp >> 8;
      bytes_processed++;
      index += 2;
   unsigned char frameSize = (9 + no_of_bytes); // first 7 bytes of the array + 2 bytes CRC + noOfBytes
   return frameSize;
Title: Re: simple modbus master
Post by: pylon on Sep 18, 2020, 10:47 am
What exactly is your question?
Most implementations call this "Write multiple coils" which explains much better what it actually does.
You posted a small excerpt of what probably is part of a library. But there is no link to the library and you didn't use code tags!
Post by: Howwee on Sep 22, 2020, 11:37 pm
i found it
it is the
 in the ccp file
its pointing to the wrong location.
supersized no one has noticed this as long as the simplemodbusmaster adruino
has been used ?
or i have a bad file ?
i have temp corrected this by replacing with
    // function 15 coil information is packed LSB first until the first 8 bits are completed
    unsigned char frameSize = 10;
    unsigned char temp;
    frame[6] = 1;
    frame[7] = packet->local_start_address ^ 0XFFFF;
    return frameSize;
works for a BYTE (0 - 255)
