Arduino Forum
Topics => Home Automation and Networked Objects => Topic started by: mafa on Nov 26, 2011, 12:53 pm
Title: (ASK) RFID on Arduino
Post by: mafa on Nov 26, 2011, 12:53 pm
Hi All,
Is there anybody knows about how to connect RFID with arduino? what kind of RFID can read until 5 meters and can works with my arduino?
Thanks before
Title: Re: (ASK) RFID on Arduino
Post by: robtillaart on Nov 26, 2011, 03:47 pm
MOst RFID reades have a standard serial output that can be connected to Arduino (optionally convert voltages from 12 - TTL level - be careful)
Check - SParkfun.com for examples
5 Meters is quite a distance imho.
Post by: Grumpy_Mike on Nov 26, 2011, 04:39 pm
5 meters is impossible with a standard RFID, I am not even sure you can do it with a UHF system and these are very expensive.
In fact I don't think you can do it with an active tag either, although this would give you the maximum range.
Post by: mafa on Nov 27, 2011, 01:43 am
thanks for your info
oh, so my project is impossible?
Post by: Grumpy_Mike on Nov 27, 2011, 10:59 am
Well you haven't said what your project is it is hard to say. But if it requires a 5 meter range then sorry no.
Post by: tkbyd on Nov 27, 2011, 09:12 pm
To get an Arduino to "see" something 5m away, DCDWireless would be good...
http://DCDWireless.com
We're getting closer to releasing the units out into the wild. Not there yet, but getting closer.
Or, you could put something together using the same RF modules.
Forget for a moment HOW you are going to do "it"... Tell us WHAT do you want "it" to do?
Post by: maniacbug on Nov 28, 2011, 03:34 am
You can see here for one example: 125Khz RFID Module RDM630 (http://maniacbug.wordpress.com/2011/10/09/125khz-rfid-module-rdm630/).  I've never heard of 5m for RFID, though.
Post by: mafa on Nov 30, 2011, 03:23 pm
ok. thanks for sharing Guys
