This is BroHogan's code from the playground Arduino Playground - MultiplexMAX72xx modified to use the TimerOne library Arduino Playground - Timer1 . Thanks to BroHogan for commenting the code well enough to make it easy to transition from Timer2 to Timer1.
Note that using TimerOne breaks analogWrite() for digital pins 9 and 10 on Arduino.
// http://www.arduino.cc/playground/Main/MultiplexMAX72xx
/* RG Matrix Example v.2 8/1/08 BroHogan
* Demos 2 color 8x8 matrix driven by 2 MAX7821's
// 12/29/2011 transfinite modified to use TimerOne
#include "WProgram.h" // needed to compile with Rel. 0013 WHY?!
#include "LedControl.h" // to drive the matrix
#include <TimerOne.h>
// #define ISR_FREQ 210 //190=650Hz // Sets the speed of the ISR - LOWER IS FASTER
// prescaler is /128 - 125,000/ISR_FREQ+1 (i.e 249=500Hz, 190=650Hz)
// Tweaked depending on the overhead in the ISR & and other factors in the sketch
// Display will be slow if too FAST. Sketch will hang on delay() if way too fast!
#define T1FREQ 1538 // 1538 ms = 650Hz
#define GREEN 0 // The address of the MAX7221 for the green leds
#define RED 1 // The address of the MAX7221 for the red leds
int maxInShutdown=GREEN; // tells which MAX7221 is currently off
// unsigned long ISRTime; // DEBUG to test how long in ISR
// LedControl lc=LedControl(10,9,8,2); // pins 10=DataIn, 9=CLK, 8=LOAD + 2 MAX7221s
LedControl lc=LedControl(10,9,5,2); // pins 10=DataIn, 9=CLK, 5=LOAD + 2 MAX7221s
lc.setIntensity(GREEN,15); // 0 = dim, 15 = full brightness
lc.setIntensity(RED,12); // red needs less brightness
// setISRtimer(); // setup the timer
// startISR(); // start the timer to toggle shutdown
Timer1.initialize(T1FREQ); // set a timer of length 1538 microseconds (or 650Hz)
Timer1.attachInterrupt( timerIsr ); // attach the service routine here
// Simple demo, but gives 2 colors a pretty good workout
SkipRows();
ClearMatrix();
/////////////////////////////ISR Timer Functions ///////////////////////////
// ISR(TIMER2_COMPA_vect) { //This ISR toggles shutdown between the 2MAX7221's
void timerIsr() {
if(maxInShutdown==RED){
lc.shutdown(GREEN,true); // The order here is critical - Shutdown first!
lc.shutdown(RED,false); // . . . Then restart the other.
else {
lc.shutdown(RED,true);
lc.shutdown(GREEN,false);
maxInShutdown=RED;
void startISR(){ // Starts the ISR
Timer1.resume();
void stopISR(){ // Stops the ISR
Timer1.stop();
void setISRtimer(){ // setup ISR timer controling toggleing
TCCR2A = 0x02; // WGM22=0 + WGM21=1 + WGM20=0 = Mode2 (CTC)
TCCR2B = 0x05; // CS22=1 + CS21=0 + CS20=1 = /128 prescaler (125kHz)
TCNT2 = 0; // clear counter
OCR2A = ISR_FREQ; // set TOP (divisor) - see #define
TCNT2 = 0; // clear counter (needed here also)
TIMSK2|=(1<<OCIE2A); // set interrupts=enabled (calls ISR(TIMER2_COMPA_vect)
TIMSK2&=~(1<<OCIE2A); // disable interrupts
//////////////////////// simple LED display routine /////////////////////////////
void SkipRows() { // 1st pass alternates green & red, 2nd adds green to red making orange
byte greenOn = true; // flag for lighting green for orange
for(int row=0;row<8;row++) {
for(int col=0;col<8;col++) {
if (greenOn == true) SetLed(GREEN,row,col,true);
else SetLed(RED,row,col,true);
greenOn = !greenOn;
delay(500); // only so you can see the first pass
greenOn = !greenOn;
delay(4); // only so you can see the update
greenOn = !greenOn;
///////// Wrappers for LedControl functions . . . //////////
void SetLed(byte Color, byte Row,byte Col, byte State){
stopISR(); // disable interrupts - stop toggling shutdown when updating
lc.setLed(Color,Row,Col,State);
startISR(); // enable interrupts again
void SetRow(byte Color, byte Row, byte State){
lc.setRow(Color,Row,State);
void SetColumn(byte Color, byte Col, byte State){
lc.setColumn(Color,Col,State);
void ClearMatrix(){
lc.clearDisplay(GREEN);
lc.clearDisplay(RED);
