Hi guys;
I just finish my code to multiplex 3 digit 7 segments display. First, I built the circuit, test the circuit, install the 74HC595, re-test doing a test program and do a multiplex code do count up from 0 to 999. The display will stay for 1 second ( about ) and count up.
Anyway, here the test code.
tested code for checking and display 0 to F
on each digit at a time.
const byte digitpin[3]={10,11,12};
const byte datapin=9;
const byte enablepin=8;
const byte latchpin=7;
const byte clockpin=6;
// 7 segment data to display 0,1,2,3,4,5,6,7,8,9,A,B,C,D,E,F
byte numbers[16]={252,96,218,242,102,182,190,224,254,246,238,62,156,122,158,142};
pinMode(datapin, OUTPUT);
pinMode(enablepin, OUTPUT);
pinMode(latchpin, OUTPUT);
pinMode(clockpin, OUTPUT);
for (int i=0;i<3;i++)
pinMode(digitpin[i],OUTPUT);
digitalWrite(enablepin, LOW);
digitalWrite(digitpin[i],HIGH);
delay(2000);
for (int j=0;j<3;j++)
digitalWrite(digitpin[j], LOW);
for (byte i=0;i<16;i++)
displaynumbers(i);
digitalWrite(digitpin[j], HIGH);
delay(2000);
void displaynumbers(byte data)
digitalWrite(latchpin, LOW);
shiftOut(datapin, clockpin, LSBFIRST, numbers[data]);
digitalWrite(latchpin, HIGH);
And here the multiplex code.
Byte : 1596
Version 1.0
Counting from 0 to 999 - Multiplex 7 segment display
Using 3 digit 7 segment display
Commun Anode using a ULN2804 driver
with 3 PNP transistor for digit select
and the use of 74HC595 serial-to-parallel
Program by Serge J Desjardins
aka techone / tech37
Toronto, Ontario Canada
Compiled and Tested
byte storage;
byte dataone;
byte datatwo;
byte datathree;
byte numbers[10]={252,96,218,242,102,182,190,224,254,246};
delay(2000);
for (int counting=0;counting<1000;counting++)
BCDconverter(counting);
for (int looping=0;looping<100;looping++)
storage=dataone;
digitalWrite(digitpin[0], LOW);
digitalWrite(digitpin[1], HIGH);
digitalWrite(digitpin[2], HIGH);
displaynumbers(storage);
storage=datatwo;
delay(5);
digitalWrite(digitpin[0], HIGH);
digitalWrite(digitpin[1], LOW);
delay(5);
storage=datathree;
digitalWrite(digitpin[2], LOW);
delay(5);
void BCDconverter(int todisplay)
// Isolated Hundrens, tens and units
dataone=byte(todisplay % 10);
datatwo=byte((todisplay%100)/10);
datathree=byte(todisplay/100);
And I want you critique my code and if you see room for improvement, please go ahead.
And I hope my code will help others.
