Arduino Forum
Using Arduino => Installation & Troubleshooting => Topic started by: jlargentaye on Jan 31, 2012, 08:22 pm
Title: Arduino Ethernet: ethernet.upload.protocol "stk500" vs "arduino" ?
Post by: jlargentaye on Jan 31, 2012, 08:22 pm
tl;dr: Succesfully troubleshooted sketch upload to an Arduino Ethernet, but why did I have to change in boards.txt ethernet.upload.protocol=stk500 to arduino?
(This is verbose in the hopes of providing hints for other people having problems)
I got a new Arduino Ethernet (http://arduino.cc/en/Main/ArduinoBoardEthernet) this week. I already have a FTDI-USB (https://www.adafruit.com/products/70) cable from Adafruit, as well as their USBTinyISP (https://www.adafruit.com/products/46) programmer. That Ard'Ethernet page is pretty lacking in instructions on how to program it :(
I'm on Ubuntu Linux, after the usual driver trouble (remember to modprobe ftdi_sio for the cable if it's not loaded automatically, remember to add the udev rules for usbtinyisp so that you don't need to be root to run avrdude), I can read from the arduino [1]. The output is at the end of this post.
I got the new boards.txt file from the bottom of the Arduino Ethernet page, I assumed the new version it provided for 1.0Beta also applied to 1.0 full. Was I wrong? Anyhow, I noticed that it changed the ethernet.upload.protocol between "arduino" and "stk500" for a number of boards (sometimes setting it to stk500, sometimes arduino).
Though I had selected "Arduino Ethernet (with USB2Serial module)" and the right serial port (/dev/ttyUSB0), I couldn't upload to the arduino as I was getting this error:
Binary sketch size: 14246 bytes (of a 32256 byte maximum)
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
Eventually I thought of replacing the ethernet.upload.protocol setting in boards.txt from "stk500" to "arduino", and it finally worked. But why did I have to do that? Why is the setting in the website-supplied file wrong? What is the advantage of the stk500 uploader?
Extra info:
This is the output of checking the Arduino through the USB-FTDI cable (yay bootloader!):
avrdude -c arduino -p m328p -P /dev/ttyUSB0 -v
avrdude: Version 5.10, compiled on Mar 23 2010 at 15:05:31
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/etc/avrdude.conf"
         User configuration file is "/home/jlargentaye/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/ttyUSB0
         Using Programmer              : arduino
         AVR Part                      : ATMEGA328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65     5     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 3
         Firmware Version: 4.4
         Vtarget         : 0.3 V
         Varef           : 0.3 V
         Oscillator      : 28.800 kHz
         SCK period      : 3.3 us
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f
avrdude: safemode: lfuse reads as 0
avrdude: safemode: hfuse reads as 0
avrdude: safemode: efuse reads as 0
avrdude: safemode: Fuses OK
avrdude done.  Thank you.
And this is the output through USBtinyISP:
avrdude -c usbtiny -p m328p -v
         Using Port                    : /dev/parport0
         Using Programmer              : usbtiny
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Programmer Type : USBtiny
         Description     : USBtiny simple USB programmer, http://www.ladyada.net/make/usbtinyisp/
avrdude: programmer operation not supported
avrdude: Using SCK period of 10 usec
Reading | ################################################## | 100% 0.01s
avrdude: safemode: lfuse reads as FF
avrdude: safemode: hfuse reads as DE
avrdude: safemode: efuse reads as 5
[1] I was afraid I damaged the board by misplugging the ISP connector: the red line must be oppposite to the SDCard connector. I had missed the teensy dot on the board. I was also very confused for a while how to connect the FTDI cable, and resorted to checking the board to identify which pin went to the ground plane, I had missed the tiny "blk" writing. The silkscreening could afford to be more obvious, as I've had similar issues with other boards such as the power connector for ArduinoBT.
Title: Re: Arduino Ethernet: ethernet.upload.protocol "stk500" vs "arduino" ?
Post by: jlargentaye on Feb 01, 2012, 08:42 pm
I've also just found that this was logged as a bug and fixed in the final version of the arduino IDE:
http://code.google.com/p/arduino/issues/detail?id=649
This means that the Arduino Ethernet page is unclear and outdated.
