Arduino Forum
Community => Gigs and Collaborations => Topic started by: electronicscrazy1996 on Mar 02, 2012, 09:35 pm
Title: arduino code
Post by: electronicscrazy1996 on Mar 02, 2012, 09:35 pm
Hi i'm asking for a big favour here i need a code for the following setup for my seafox rov:
arduino number 1 receives signals from ps2 controller on pins 13, 12, 11 and 10 and a current + voltage sensor on pins 0 and 1. once the signals from the ps2 controller have been decoded they need to be sent by serial to arduino number 2 which takes the signals so it can control 3 esc's (on pins 10, 9 and 6) and 3 relays (on pins 8, 7 and 4) (relays will be controlled with transistors).
Arduino number 2 also sends signals from a lm35 on pin 0 and 4 outputs from a digital compass on pins 4, 5, 6 and 7 which all need to be sent to arduino number 1 then onto a video overlay board as well as the signals from the current + voltage sensor.
esc's 1 and 2 will be forwarded by pushing the right joystick forward
esc's 1 and 2 will be reversed by pushing the right joystick backward
esc 1 will be forwarded by pushing the right joystick left
esc 2 will be forwarded by pushing the right joystick right
esc 3 will be forwarded by pushing the left joystick forward
esc 3 will be reversed by pushing the left joystick backward
relay 1 will be turned on when l1 is pressed and turned off when released
relay 2 will be turned on when r1 is pressed and turned off when released
relay 3 will be turned on when r2 is pressed and pressing r2 again will turn it off
all the readings from the sensors will be sent to the video overlay board
voltage + current sensor: http://www.coolcomponents.co.uk/catalog/product_info.php?products_id=433
video overlay board: http://www.coolcomponents.co.uk/catalog/product_info.php?products_id=723
digital compass: http://www.zagrosrobotics.com/shop/item.aspx?itemid=551
would really appreciate some help :)
Title: Re: arduino code
Post by: marcello.romani on Mar 02, 2012, 10:31 pm
Are you asking for a complete sketch (2 in fact) for this project ?   :smiley-eek:
Post by: electronicscrazy1996 on Mar 02, 2012, 11:07 pm
yes i would like a code that i can just upload straight to my arduino's
Post by: zoomkat on Mar 02, 2012, 11:17 pm
So how much of this complex project have you completed so far?
Post by: marcello.romani on Mar 02, 2012, 11:46 pm
How much are you willing to pay ?    ]:)
Post by: electronicscrazy1996 on Mar 03, 2012, 01:35 am
none so far
dont really know, however much it takes to make
Post by: marcello.romani on Mar 03, 2012, 03:13 pm
It's ok here (and with me) to ask for complete projects. I was puzzled because you initially posted the question in the "wrong" part of the forum. :-)
Post by: electronicscrazy1996 on Mar 03, 2012, 03:45 pm
i'm quite new to the forum so i didn't know quite where to put it
Post by: sbright33 on Mar 03, 2012, 05:57 pm
I can help you...
https://www.freelancer.com/users/3242859.html
Post by: electronicscrazy1996 on Mar 03, 2012, 10:00 pm
i've posted my requirements on freelancer for you to look at
Post by: electronicscrazy1996 on Jun 23, 2012, 09:28 pm
Just to say that i am still looking for someone to create my code so if your interested please contact me for updated requirements
