Arduino Forum
Using Arduino => LEDs and Multiplexing => Topic started by: iyahdub on May 11, 2012, 06:18 am
Title: controlling the speed/rate with a shift register outs(kinda Larson scanner)
Post by: iyahdub on May 11, 2012, 06:18 am
Picking your brains and experience so i can apply to something i need.
I need to control a VCO using a shift register( lets say a 595).
On the outputs i can control the voltage with a resistive ladder(R2R),DAC style, so in that sense no doubts.
My doubt is this: Would the code below be the best way to have a control of its speed/rate ?! Is there a better, with better response way to do that ?! If so, can you lead me onto the right path, please ?!
Im developing a sound effects box, and despite already having achieved what id set myself to, id love to add more extras, and having a better control over it would be just brilliant to what i need .
 //Pin connected to ST_CP of stop
int latchPin = 8;
//Pin connected to SH_CP of stop
int clockPin = 12;
//Pin connected to DS of stop
int dataPin = 11;
int delayInput = 0;
int outDelay =0;
// Out to 74HC595 (Serial TO Parallel OUT)
void stopout(int numberToDisplay)
 // take the latchPin low so
 // the LEDs don't change while you're sending in bits:
 // digitalWrite(latchPin, LOW);
 // shift out the bits:
 shiftOut(dataPin, clockPin, MSBFIRST, numberToDisplay);
 //take the latch pin high so the LEDs will light up:
 digitalWrite(latchPin, HIGH);
 //set pins to output so you can control the shift register
 pinMode(latchPin, OUTPUT);
 pinMode(clockPin, OUTPUT);
 pinMode(dataPin, OUTPUT);
 pinMode(delayInput, INPUT);
 //Lets Clear the LEDs - just incase the 74HC595 'remembers' its last state after restart.
 stopout(B00000000);
 outDelay = analogRead (delayInput);
 stopout(B10000000);
 delay(outDelay);
 stopout(B01000000);
 delay(outDelay);
 stopout(B00100000);
 delay(outDelay);
 stopout(B00010000);
 delay(outDelay);
 stopout(B00001000);
 delay(outDelay);
 stopout(B00000100);
 delay(outDelay);
 stopout(B00000010);
 delay(outDelay);
 stopout(B00000001);
 delay(outDelay);
 stopout(B00000010);
 delay(outDelay);
 stopout(B00000100);
 delay(outDelay);
 stopout(B00001000);
 delay(outDelay);
 stopout(B00010000);
 delay(outDelay);
 stopout(B00100000);
 delay(outDelay);
 stopout(B01000000);
Title: Re: controlling the speed/rate with a shift register outs(kinda Larson scanner)
Post by: iyahdub on May 14, 2012, 11:26 pm
Njay was kind enough to note a nice way of doing it !
/*este e um caso basico para que possa perceber facilmente qualquer implementacao.
*Pino conectado ao ST_CP do stop*/
int latchPin = 8;
//Pino conectado ao SH_CP of stop
int clockPin = 12;
//Pino conectado ao DS do stop
int dataPin = 11;
int delayInput = 0;//pin para entrada analogica, neste caso um potenciometro
int outDelay =0;//O valor que vamos usar para converter  a leitura do pin analogico
                //do pot para usar como valor de delay entre accoes
// Saida para 74HC595 (Serial TO Parallel OUT)
  // baixar o latchPin para low para que
  // os LEDs nao mudem enquanto os bits sao enviados:
  // passar os bits:
  //mudar o latch pin para HIGH para que os leds acendam:
  //Configurar os pins para saida, para poder controlar o shift register
  pinMode(delayInput, INPUT);//Atribuir o pin a entrada analogicado potenciometro
  //Apagar qualquer memoria que o 74HC595 possa ter da ultima configuracao dos pins
  stopout(B00000000);
void loop ()
    for (unsigned char ctr = 0, mask = 0x80; ctr < 14; ctr++)
        stopout(mask);
        delay(outDelay);
        mask = (ctr < 7? mask >> 1: mask << 1);
Post by: chengmania on Jan 10, 2013, 03:05 am
Hello all,
I love the simplicity of this code.  However being a noob I have to ask:
can some one break this down for me?
Is it a short code for if...then...else?
thank you
Post by: fungus on Jan 10, 2013, 11:00 am
Yes, but it's not something you should try to emulate/use...
(it causes code readability problems like the one you're experiencing right now)
Post by: dhenry on Jan 10, 2013, 08:44 pm
Yes. It controls the direction of flow for the leds based on the value of ctr.
