Arduino Forum
Using Arduino => LEDs and Multiplexing => Topic started by: Wolfiesden on Jun 04, 2012, 10:59 am
Title: Web Server with graphical UI to set LED color
Post by: Wolfiesden on Jun 04, 2012, 10:59 am
I banged up this sketch tonight to set a LED using a full color presentation from a web page.
This requires a RGB color LED attached to D5,6,9 (configurable at top of script).  It also requires the Ethernet board and appropriate libraries.
Use a web page to set a RGB LED to the selected color
Converted to analog write commands and removed BlinkM
Also removed simple text box page and used code from
http://www.colorpicker.com/ to pick the LED color.
Mike Audleman
Jun 3, 2012
Prior Header
// Small Arduino Webserver --- for BlinkM
// by Andreas Cahen ---** updated for Arduino 0021 - by PsycleSam and Co. 20101219 tested on arduino uno with updated ethernet shield
// Used libraries and examples:
// Arduino Ethershield, server.pde
// Blinkm Library, BlinkMfuncs.h +++**SPI Library, SPI.h
// ---** no longer used - TextString Library, WString.h
#include <SPI.h>
#include <Ethernet.h>
//#include <WString.h>
#include <Wire.h>
//#include <BlinkM_funcs.h>
#define maxLength 25
//#define blinkm_addr 0x09
// Sets circuit for LED.
// 0 for LED tied to ground
// 1 for LED tied to v+
int LEDInvert = 1;
byte mac[] = {
  0x12, 0x12, 0x12, 0x12, 0x12, 0x12 }; //Set your own MAC
// Using DHCP
//byte ip[] = {
//  192, 168, 0, 200 };
String inString = String(maxLength);
int val;
int r = 0;
int g = 0;
int b = 0;
char colorBuff[4];
int LEDr = 5 ;//LED Red pin
int LEDg = 6 ;//LED Green pin
int LEDb = 9 ;//LED Blue pin
EthernetServer server(80);
Setup configuration.
  Ethernet.begin(mac);
  server.begin();
  pinMode(LEDr, OUTPUT);
  pinMode(LEDg, OUTPUT);
  pinMode(LEDb, OUTPUT);
  // Init Testing of the LED
  SetAll( 0 );
  RampPin( LEDr );
  RampPin( LEDg );
  RampPin( LEDb );
  SetAll( 255 );
  delay(100);
  SetAll( 0 );
Main Logic Loop
  int bufLength;
  if (client) {
    boolean current_line_is_blank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        if (inString.length() < maxLength) {
          //inString.append(c);
          inString += c;
        if (c == '\n' && current_line_is_blank) {
          if (inString.indexOf("?") > -1) {
            int Pos_CC = inString.indexOf("k=")+2;
            int End_CC = inString.indexOf("&", Pos_CC);
            if(End_CC < 0){
              End_CC =  inString.length() + 1;
            String ColorHex = inString.substring(Pos_CC,End_CC);
            Serial.println( "Received Hex String " + ColorHex );
            r = CheckRange( HexToDec(ColorHex.substring(0,2)) );
            g = CheckRange( HexToDec(ColorHex.substring(2,4)) );
            b = CheckRange( HexToDec(ColorHex.substring(4,6)) );
            SetLED( LEDr, r );
            SetLED( LEDg, g );
            SetLED( LEDb, b );
          ShowWebPage (client);
          break;
        if (c == '\n') {
        else if (c != '\r') {
          current_line_is_blank = false;
    delay(1);
    inString = "";
    client.stop();
Simply ramps the specific pin
void RampPin( int dPin ) {
  // fade in from min to max in increments of 5 points:
  for(int fadeValue = 0 ; fadeValue <= 255; fadeValue +=5) {
    SetLED( dPin, fadeValue );
    delay(10);
  // fade out from max to min in increments of 5 points:
  for(int fadeValue = 255 ; fadeValue >= 0; fadeValue -=5) {
    delay(10);
Sets all colors to set value (used for all on/all off)
void SetAll( int value ) {
  SetLED( LEDr, value );
  SetLED( LEDg, value );
  SetLED( LEDb, value );
Sets the LED pin and accounts for positve or negative wired LED
void SetLED( int dPin, int value ) {
  if (LEDInvert){
    analogWrite(dPin, (255-CheckRange( value )));
  else {
    analogWrite(dPin, CheckRange( value ));
Validates the passed value 0 > val > 255
int CheckRange( int val ) {
  int tmpVal = val;
  if ( tmpVal > 255 ){
    tmpVal=255;
  if ( tmpVal < 0 ){
    tmpVal=0;
  return tmpVal;
Displays the web page
void ShowWebPage (EthernetClient theClient) {
  String t = "";
  theClient.println("HTTP/1.1 200 OK");
  theClient.println("Content-Type: text/html");
  theClient.println();
  theClient.println("<html>");
  t = "<script type='text/javascript'";
  theClient.println("<head><base href='http://www.colorpicker.com/'><link rel='stylesheet' href='css/colorpicker.com.css' type='text/css'>");
  theClient.print(t);
  theClient.println(" src='js/mootools-1.2.4-core.js'></script>");
  theClient.print(t);
  theClient.println(" src='js/colorpicker.com.js'></script></head>");
  theClient.println("<body>");
  theClient.println("<div><div style='position:absolute;top:0px;left:0px;width:430px'><div id='colorDiv' style=display:none;>.</div><div id='colorBoxes'></div></div>");
  theClient.println("<center><div id='colorWidgetDiv' style='position:relative;padding-left:100px;width:450px;height:340px;margin-top:70px;'></div></center></div>");
  theClient.println("<form method=get onSubmit='SE();'>");
  theClient.println("<input type='hidden' id='k' name='k'value='0'>");
  theClient.println("<input type='submit' id='H' name='H' value='Submit'>");
  theClient.println("<input type='hidden' id='cc' name='colorcode' value='0'>");
  theClient.println("</form>");
  theClient.println("<script language='javascript'>");
  theClient.println("function SE(){var s = $$('input[class^=ColorPicker_com_colorSlider_rgbCode]');var c = s.get('value');c = c.toString(c); ");
  t = "').set('value',c); ";
  theClient.print("$('k");
  theClient.println(t);
  theClient.print("$('cc");
  theClient.println("}");
  theClient.println("</script>");
  theClient.println("</body></html>");
Converts a single hex character to a byte
int hex2dec(byte c) {
  if (c >= '0' && c <= '9') {
    return c - '0';
  } else if (c >= 'A' && c <= 'F') {
    return c - 'A' + 10;
Converts a 2 byte hex string to an int
int HexToDec(String c) {
  int Digit1 = hex2dec( c.charAt(0) ) * 16;
  int Digit2 = hex2dec( c.charAt(1) );
  return Digit1 + Digit2;
Enjoy,
Wolfie
Title: Re: Web Server with graphical UI to set LED color
Post by: Wolfiesden on Jun 08, 2012, 01:45 am
Per a request, I am posting a very simple script that looks for only one text box and sets an LED on Pin 9 to the brightness.  This script does NOT use BlinkM I only used that script as a starter for this one.
// Based on
// Modified for single text box for brightness
// Jun 7 2012 - Mike Audleman
#include <SPI.h>
#include <Wire.h>
byte mac[] = {
  0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA };
char colorBuff[4];
int val;
  server.begin();
  int bufLength;
  if (client) {
          inString += c;
            int Pos_L = inString.indexOf("L");
            int End = inString.indexOf("H", Pos_L);
            if(End < 0){
              End =  inString.length() + 1;
            bufLength = ((Pos_L) - (Pos_L+2));
            if(bufLength > 4){  //dont overflow the buffer
              bufLength = 4;
            inString.substring((Pos_L+2), (End-1)).toCharArray(colorBuff, bufLength);  //transfer substring to buffer
            val = atoi(colorBuff);
            Serial.print("LED = ");
            Serial.println( val );
            analogWrite(9, val);
          client.println();
          client.println("<html><head></head><body>");
          client.println("<h1>LED - enter values 0 to 255</h1>");
          client.print("<form method=get>LED:<input type=text size=3 name=L value=");
          client.print(val);
          client.print(">&nbsp;<input name=H type=submit value=submit></form>");
          client.println("</body></html>");
          break;
        if (c == '\n') {
    delay(1);
    inString = "";
    client.stop();
Post by: Ray4720 on Jun 13, 2012, 01:16 am
Hi Wolfiesden,
Thanks for your demo code.
This is just what i have been looking for, well nearly!
I am very new to the Arduino and C and and trying to run before I can walk, like most newbies :-)
My ambition is to have a Web server running on the Arduino, my problem is that I want to change a graphic on the client when an input is switched on or off. e.g an LED switching from RED to Green.
To further complicate the issue i would like to have a couple of JPG or PNG pictures on web screen as well.
So far i have been able to call a web page (INDEX.HTM), with JPG and PNG graphics being called from a SD card on the Ethernet shield.  This give me the rich look i want.
I have many examples of writing to the client directly from the program, as in your example, what i cant figure out is how to combine the two.
The issue I keep on hitting is the that the WEB server libraries cannot serve PNG or JPG file to the client.
I have found the TinyWebServer.H library which almost does what i want but being a newbie i find it difficult to see how to fully use it.
I am looking at using JAVA script to possible help solve the issue but this is adding to an already steep learning curve.
Any pointers on how to crack this would be greatly appreciated.
Many Thanks in advance
Ray
PS keep up the good work :-)
Post by: AndrewStone on Jun 13, 2012, 03:50 pm
Put the pictures on a completely different web site -- like a photo sharing site, and then just reference them from your http code on the ArduinoULN2803A
Just like you do to embed a photo in this newsgroup...
Post by: cmiyc on Jun 14, 2012, 10:32 pm
Important note: JAVA and JavaScript have nothing in common.  They are completely different languages with entirely different implementations.
Post by: TriB on Jul 19, 2012, 03:58 pm
Hi everybody,
I was searching for something similar and just have coded a simple solution for me.
There is a little slider with 3 Images (red.gif, green.gif & blue.gif) just 1x1 pixel.
<html>
<head>
<script type="text/javascript">
function Slider(i,c)
//Get last resized Image
im = c + document.getElementById(c).value
d=document.all[im];
d.height=20;
//Set Textbox to value
document.getElementById(c).value = i;
//Resice actual Image to 1
im = c + i;
d=document.all[im];
d.height=1;
//Set <hr color=""> to Hexcode
document.getElementById('color').color = '#'+document.all.r.value.toString(16)+document.all.g.value.toString(16)+document.all.b.value.toString(16);
</script>
<title>
Arduino Colorpicker 1.0
</title>
<meta content="width=480" />
</head>
<body>
<input type="text" id="r" size="2">
for (i=0;i<=255;i++)
document.write("<img src='red.gif' height=20 width=1 onMouseOver='Slider(" + i + ",\"r\")' id='r" + i + "'>");
</script>
<br>
<input type="text" id="g" size="2">
document.write("<img src='green.gif' height=20 width=1 onMouseOver='Slider(" + i + ",\"g\")' id='g" + i + "'>");
</script>
<br>
<input type="text" id="b" size="2">
document.write("<img src='blue.gif' height=20 width=1 onMouseOver='Slider(" + i + ",\"b\")' id='b" + i + "'>");
</script>
<br>
<hr color="#ffffff" size="20" width="15" id="color"></hr>
</body>
</html>
So you can put the three Input boxes into a <form> and send them to your EthernetShield by POST or what ever :)
I´d love to transfer it "live" to the Arduino, but there would be a POST-Action by JavaScript needed, I think :-/
Post by: TriB on Jul 20, 2012, 10:21 am
Hey,
yesterday I was animated to do the Color-Picker right.
There were some changes to the Version above:
(http://imageshack.us/photo/my-images/404/colorpicker.png)
<html>
<head>
//Get last Image
d=document.all[im];
switch (c)
case "r":
d.bgColor = "#ff0000";
break;
case "g":
d.bgColor = "#00ff00";
break;
case "b":
d.bgColor = "#0000ff";
break;
//Hide actual Image
im = c + i;
d=document.all[im];
d.bgColor = "#000000";
var r,g,b;
r = Math.round((document.all.r.value*255)/31);
g = Math.round((document.all.g.value*255)/31);
b = Math.round((document.all.b.value*255)/31);
document.getElementById('color').color = '#'+r.toString(16)+g.toString(16)+b.toString(16);
document.getElementById('action').value = 'color'+document.all.r.value+'-'+document.all.g.value+'-'+document.all.b.value;
function submitformColor()
var oRequest = new XMLHttpRequest();
var sURL  = '/?action='+document.getElementById('action').value;
oRequest.open("GET",sURL,false);
oRequest.setRequestHeader("User-Agent",navigator.userAgent);
oRequest.send(null)
if (oRequest.status==200)
   //Get Answer
   //var txt = oRequest.responseText;
   //document.write(txt);
   //Stay on actual Site
   return false;
  document.write('Error!');
//   document.forms["myform"].submit();
</script>
<title>Arduino Webserver 1.0 - Color</title>
</head>
<body bgcolor='#444444'  text="#c0c0c0" OnLoad="ReadCookie()">
<table border='0' width='480' cellpadding='5'>
<tr><td>
<br><hr/>
<h2><div align='center'><font color='#2076CD'>Arduino Webserver 1.0</font></div></h2>
<hr/><br>
<div align='left'><font face='Verdana' color='#FFFFFF'>Colorpicker</font></div>
<br>
<table border='1' width='460' cellpadding='5'>
<tr bgColor='#222222'>
<td align='center' bgcolor='#222222'>
<table border="0" cellspacing="0" cellpadding="0">
<tr>
<td><input type="text" id="r" size="2" value="0"></td>
for (i=0;i<=31;i++)
  document.write("<td bgcolor='#ff0000' height=40 width=10 onMouseOver='Slider(" + i + ",\"r\")' id='r" + i + "'></td>"); </script>
</tr>
</table>
<tr>
<td><input type="text" id="g" size="2" value="0"></td>
for (i=0;i<=31;i++)
  document.write("<td bgcolor='#00ff00' height=40 width=10 onMouseOver='Slider(" + i + ",\"g\")' id='g" + i + "'></td>");
</script>
</tr>
</table>
<tr>
<td><input type="text" id="b" size="2" value="0"></td>
for (i=0;i<=31;i++)
  document.write("<td bgcolor='#0000ff' height=40 width=10 onMouseOver='Slider(" + i + ",\"b\")' id='b" + i + "'></td>");
</script>
</tr>
</table>
</td></tr>
<tr><td  align='center' bgcolor='#222222'>
<hr color="#ffffff" size="50" width="50" id="color"></hr>
</td></tr>
<form id="myform" action="../?" onsubmit="return submitformColor();">
<input type='hidden' name='action' id="action">
<input type="submit" name="btn" value="Change">
</form>
</td>
</tr>
</table>
<br>
</td></tr>
</table>
<a href="INDEX.HTM">Back</a>
</body></html>
So I hope someone can use it for his purpose :)
Post by: TriB on Nov 19, 2012, 12:04 pm
While I was answering another Post, I´ve refered to this solution. I was shocked a little, how obsolet my post was  :smiley-eek:
So here is my current solution, how to create a Color-Picker, which constantly stays on the site and workes quite fast.
The JS-File is outsourced to possibly put it on a different webspace. It also can be re-included in the main page.
HTML-File (Color.htm):
<html>
<head>
<meta name="viewport" content="width=device-width, initial-scale=1, maximum-scale=1">
<link rel="icon" href="favicon.ico" type="image/x-icon">
<link rel="shortcut icon" href="favicon.ico" type="image/x-icon">
<script type="text/javascript" src="color.js"></script>
</head>
<body bgcolor='#444444'  text="#c0c0c0">
<tr><td>
<br><hr/>
<hr/><br>
<br>
<tr>
<td><input type="hidden" id="r" size="2" value="0"></td>
for (i=0;i<=31;i++)
</tr>
</table>
<tr>
<td><input type="hidden" id="g" size="2" value="0"></td>
for (i=0;i<=31;i++)
</script>
</tr>
</table>
<tr>
<td><input type="hidden" id="b" size="2" value="0"></td>
for (i=0;i<=31;i++)
</script>
</tr>
</table>
</td></tr>
</td></tr>
Password: <input type="password" name="pw" id="pw">
<br>
</form>
</td>
</tr>
</table>
<br>
</td></tr>
</table>
<a href="INDEX.HTM">back</a>
</body></html>
JavaScript-File (color.js):
d=document.all[im];
switch (c)
case "r":
break;
case "g":
break;
case "b":
break;
im = c + i;
d=document.all[im];
var r,g,b;
sURL += '&pw='+document.getElementById('pw').value;
sURL += '&btn=Change';
oRequest.send(null)
   return false;
  document.write('Error while sending!');
Arduino Code:
(A working Ethernet Shield is mandatory & some knowlodge where to paste the code required)
char pw[21] = "&pw=MySecurepassword&btn=Change";
  if(strstr(filename,"?action=") !=0)
    filename = filename + 8; // look behind "?action=" (8 chars)
    if(strstr(filename,pw) !=0)
      //Delete Password stuff
      (strstr(filename, pw))[0] = 0;
      if(strstr(filename, "color") != 0)
          All(LP.color(0,0,0));
          client.println("Color:<br>");
          filename = filename + 5; //Remove "color"
          client.println(filename);
          String str = filename;
          char theName[3];
          str = str.substring(0,str.indexOf('-'));
          str.toCharArray(theName, 3);
          Serial.println(theName);
          r = atoi(theName);
          str = filename;
          str = str.substring(str.indexOf('-')+1,str.lastIndexOf('-'));
          g = atoi(theName);
          str = filename;
          str = str.substring(str.lastIndexOf('-')+1);
          b = atoi(theName);
          All(LP.color(r,g,b));
This string conversations are quite ugly and should be redesigned...
The Password-Thing is just a little unsecure solution, but there werent high confidential data on my arduino. So it is just to avoid people to turn my livingroom into a disco  :)
And this is how it looks like:
(http://www.imagesup.net/dm-313533227542.png) (http://www.imagesup.net/pm-313533227542.png)
