Arduino Forum
Topics => Robotics => Topic started by: donnovan on Sep 05, 2012, 12:03 pm
Title: Problem reading I2C
Post by: donnovan on Sep 05, 2012, 12:03 pm
Hi everyone,
I'm trying to read the i2c bus(SRF08-sensor) of the arduino UNO, while i'm using the pwm to control 2 dc motor(RfRobot motorshield) . But it seems that using these together. interferes with reading the i2c bus. is there something i can do about this?
this is how my code looks like
void Forwards()
static int sensorReading = 0;
do
  // set units, gain, and range location for reading out distance
MySonar.setUnit(CommandRegister, New_Address, unit, GainRegister, RangeLocation);
// pause
delay(time);
// set register for reading
MySonar.setRegister(New_Address, ResultRegister);
// read data from result register
sensorReading = MySonar.readData(New_Address, 2);
// print out distance
Serial.print("Distance: ");
Serial.print(sensorReading);
Serial.print(" units");
Serial.println();
analogWrite(E1, 255); //PWM Speed Control
analogWrite(E2, 255); //PWM Speed Control
delay(30);
digitalWrite(M1, HIGH);
digitalWrite(M2, HIGH);
if(sensorReading < 10)
//Serial.print("Distance: is smaller than 10:  ");
//Serial.print(sensorReading);
//Serial.println();
Stop();
break;
 }while(true);
Title: Re: Problem reading I2C
Post by: PaulS on Sep 05, 2012, 12:15 pm
do
  }while(true);
A complete misuse of the do/while statement. A while statement would be better.
delay(30);
Is this part of your problem? No? Why did you post it, then?
Where is the rest of your code? What is a MySonar?
Some proof would be useful. What does "seems to interfere" mean? What pins is the motor shield using? PWM output on digital pins should have no impact on any analog pins, where I2C occurs.
Post by: donnovan on Sep 05, 2012, 03:22 pm
the problem is de code below yes. E1 = pin 5 of pwm, E2 = pin 6 pwm en digital pin 7 en 4 are M1 and M2
delay(30);
the SRF08 is connected to analog pin A5(SCL) en A4(SDA) of the arduino uno. It seems to be interfering because when i read the sensor without using above pwm code it works fine  :~
MySonar is the class to read the srf08.
Post by: PaulS on Sep 05, 2012, 04:28 pm
So, the obvious question is why you are using PWM when you want a 100% duty cycle. digitalWrite(E1, HIGH) achieves the same result without the timer.
Post by: donnovan on Sep 07, 2012, 02:17 pm
thanx PaulS. my toughlesscoding  :smiley-sweat:
I sloved the problem added some extra AAA battery's  and ik works fine now :)
