Arduino Forum
Topics => Device Hacking => Topic started by: janvb on Nov 14, 2012, 02:24 pm
Title: Serial port
Post by: janvb on Nov 14, 2012, 02:24 pm
I am a new user to the Arduino R3 My upload is successful but I get no signal out of my ser monitor I am on com 3
I am researching the signal from the neurosky mindwave headset I hacked the T pin and sent it to rx on the Arduino to see what comes out on the serial port in csv but no data coming out
can someone advice
Title: Re: Serial port
Post by: PaulS on Nov 14, 2012, 03:20 pm
can someone advice
Sure. I can advise you that this post has nothing to do with the Arduino web site. It has nothing to do with the forum. So, clearly it is in the wrong place.
When you do figure out where you should have posted (Programming or Project Guidance or Gigs and Collaboration are all more appropriate), some links would be useful.
What does "I hacked the T pin" mean, anyway? Which wire from the T pin did you connect to the RX pin? What other wires did you connect to the Arduino? What makes you think that the device is sending serial data? How do you expect to share the serial port with that device and the PC? What is running on the PC to collect serial data anyway?
Post by: robtillaart on Nov 15, 2012, 06:11 pm
Have you some specifications about that headset?
What sites have you searched (googled?)
I recall seen something on instructables, not sure?
