Arduino Forum
Community => Gigs and Collaborations => Topic started by: digitalfa on Jan 12, 2013, 12:07 am
Title: Iron man helmet faceplate and LED
Post by: digitalfa on Jan 12, 2013, 12:07 am
Hey guys i'm new to the Arduino and i have a Arduino Uno and i don't know how to write the code.
Can some pro please write me a simple code which turn 180 to open up the faceplate and LED turn off with a press of a button, then if press again it will turn back 180 counter clock wide to close the faceplate then turn on the LED.
Title: Re: Iron man helmet faceplate and LED
Post by: johnwasser on Jan 12, 2013, 12:28 am
const int servoPin = 2;
const int buttonPin = 3;
const int LEDPin = 4;
#include <Servo.h>
Servo visorServo;
  visorServo.write(0);  // Initial position
  visorServo.attach(servoPin);
  pinMode(buttonPin, INPUT_PULLUP);  // Connect button between pin and GROUND. LOW when pushed.
  pinMode(LEDPin, OUTPUT);
  digitalWrite(LEDPin, LOW);  // LED off
  static unsigned long lastPushedTime = 0;
  static boolean visorClosed = true;
  static boolean lastButtonState = HIGH;
  boolean newButtonState = digitalRead(buttonPin);
  // If the button is down and it has been a while since it was last down...
  if (newButtonState  == LOW && lastButtonState == HIGH && millis() - lastPushedTime > 100) {
    lastPushedTime = millis();
    if (visorClosed) {
      visorServo.write(180); // Open visor
      visorClosed = false;
      digitalWrite(LEDPin, HIGH); // Turn on light
    else {  // Viso is open
      visorServo.write(0); // Close visor
      visorClosed = true;
      digitalWrite(LEDPin, LOW); // Turn off light
  lastButtonState = newButtonState;
Post by: PeterH on Jan 12, 2013, 12:29 am
Turn *what* 180 degrees?
Post by: johnwasser on Jan 12, 2013, 12:33 am
I'm guessing a servo.
Post by: tcengs on Feb 08, 2014, 09:45 pm
thread back from the dead, i am starting a similar project and the code provided works wonders , however i am trying to include a 2nd servo that moves in the opposite position as the 1st servo. i am new an dont know where to start. didnt mean to high jack
Post by: johnwasser on Feb 09, 2014, 02:19 am
It's not hard to add a second servo:
const int servo1Pin = 2;
const int servo2Pin = 5;
#include <Servo.h>
Servo visorServo1;
Servo visorServo2;
 visorServo1.write(0);  // Initial position
 visorServo1.attach(servo1Pin);
 visorServo2.write(180); // initial position
 visorServo2.attach(servo2Pin);
   if (visorClosed) {
     visorServo1.write(180); // Open visor
     visorServo2.write(0);
     visorServo1.write(0); // Close visor
     visorClosed = true;
Post by: tcengs on Feb 09, 2014, 02:40 am
its been 15 years since I've written code. Thanks for the quick reply
Post by: arielcosco on May 06, 2019, 01:23 am
como hago para que el servo suba despacio en la apertura?
Post by: Phop on Aug 03, 2019, 05:57 pm
Sorry to ask but im not good with any of this bought a kit cant work it out but can follow a diagram, would some one be able to post one of how the board would be set up
Post by: cedarlakeinstruments on Aug 03, 2019, 06:08 pm
Besides the fact that you're dredging up a 5 year-old thread, what kit? what board? Set up for what?
Post by: Phop on Aug 04, 2019, 09:16 pm
So at the top of this post is a sketch for a iron man helmet. I want to know how to set up the breadboard and how to wire it up
Post by: xl97 on Aug 14, 2019, 06:19 pm
Have you done a search?
This topic has been posted before..
Also.. maybe check out:  www.therpf.com  where prop makers hang and show their work..
many diagrams and code there for this type of project.
Post by: Phop on Aug 14, 2019, 10:16 pm
Hi pal already found your post followed and build thanks for that helped loads. Just came across this first and asked the question but sorted thank to you cheers
Post by: herbertvwright on Aug 29, 2019, 01:18 am
Is the helmet connected via USB? The helmet shell itself is a slightly modified model from Thingiverse, the LED eyes are inspired by another persons project but the motor setup, hinge design, remote control and arduino code is all my own.
Post by: xl97 on Aug 29, 2019, 02:29 pm
What are you talking about?
