Arduino Forum
Products => Arduino Yún => Topic started by: KenNET on Sep 26, 2013, 08:49 pm
Title: Move config web
Post by: KenNET on Sep 26, 2013, 08:49 pm
Is is possible to move the default site (/cgi-bin/luci/webpanel/homepage) to another port, lat say :81
Then I want my webpages on the SD card on the "root" of webserver, not like now "192.168.1.100/sd/mypage.html", I want "192.168.1.100/mypage.html"
And last how do I install PHP on Yun?  I'm not that good with linux.
Thanks!
Title: Re: Move config web
Post by: federicofissore on Sep 26, 2013, 09:08 pm
Edit file /etc/config/uhttpd, 5th row
list listen_http 0.0.0.0:80
Change
option home /www accordingly. Beware that your files will be the only one served by the webserver (ie: you'll lose access to the webpanel).
Thanks!
Access the yun via ssh or via the YunSerialTerminal. Be sure it's properly configured to access the internet then type
opkg update
opkg install php5-cgi
(or php4 if you prefer)
PS: once you're done with uhttpd configuration, don't forget to restart it:
/etc/init.d/uhttpd restart
Post by: KenNET on Sep 26, 2013, 09:22 pm
Wow that was fast!
Ok I got PHP working
can I run multiple webservers? Yun admin on port 81, and my with pages from SD on port 80. How do I config that?
Thanks!
Post by: federicofissore on Sep 26, 2013, 09:25 pm
I'm not sure that's possible. uhttpd is made for very constrained environments. Maybe google can help
Post by: KenNET on Sep 26, 2013, 09:34 pm
I fond this and it works. Just put # on the original settings.
# Server configuration
config uhttpd main
    option home        /www
    option cgi_prefix     /cgi-bin
config uhttpd secondary
    list listen_http    0.0.0.0:81
    option home        /mnt/sda1/arduino/www/
Post by: federicofissore on Sep 26, 2013, 10:26 pm
ah, well done. good to know :)
