Arduino Forum
Forum 2005-2010 (read only) => Hardware => Troubleshooting => Topic started by: karandex on Jan 20, 2010, 06:56 pm
Title: Strange power problem
Post by: karandex on Jan 20, 2010, 06:56 pm
I am making a line follower with arduino
so here is my setup
moter driver have 8 pins for
5 motors
2 pwm
vcc
gnd
driver http://robokits.co.in/shop/index.php?main_page=product_info&cPath=1&products_id=176
now some strange stuff
when i attach grd then every thing is okey but when i attach vcc it takes power which is provided for motor to arduino. i dont know arduino runs or lit up led only
second thing is when i  pwm pins it light up sensors and ALL led ( exept pin 13) pwr tx and rx and sensors which are taking power from 5v and gnd on arduino
when i attach pwm nothing works
please help
Title: Re: Strange power problem
Post by: karandex on Jan 21, 2010, 06:28 am
please anybody help me
Post by: GrooveFlotilla on Jan 21, 2010, 08:34 am
What is "grd"?
Could you maybe rephrase your question, post a sketch, show a schematic?
Post by: daveg360 on Jan 21, 2010, 12:16 pm
As above although it does sound like you're trying to run 5 motors from the arduino?
Post by: karandex on Jan 21, 2010, 12:24 pm
now its okey. when i power motor driver it lit up arduino led but not arduino
But main problem is i can power teds for sensor they are dim when powered with 9 v no problem in usb
Its problem when there are more than 2 sensors
is there problem arduino for providing power
is it possible to provide power to arduino throgh it 5v pin because when i connect vcc pin to arduino then arduino start up. And circuit can i run without connecting both ground
Main thing is please suggest that do i need to provide seprate power to sensors
Post by: GrooveFlotilla on Jan 21, 2010, 12:47 pm
No sorry, it isn't making any sense.
You don't say what the sensors are, though unless they're taking an awful lot of current, it seems unlikely they're causing problems.
A schematic would be a great help.
Have you got grounds connected?
Have you double and triple checked your wiring?
Could this be a decoupling problem?
