Arduino Forum
Using Arduino => Microcontrollers => Topic started by: 2kohm on May 23, 2015, 12:37 am
Title: arduino isp error burning bootloader to fresh atmega32u4
Post by: 2kohm on May 23, 2015, 12:37 am
Hello Community,
i designed my own arduino leonardo board with an atmega32u4-au
the pcbs and the circuit are fine! i have one working board so this is no HW issue.
i cant upload the bootloader ! but with one board in the same setup it worked perfectly!
soldering checkt 20000% DMM tests etc...
i googled for hours...
now i get this error with all boards  :(
Bootloading Problem:
ArduinoMega2560 = ISP
Arduino IDE 1.0.3
Source atmega32u4-au ISP
bin kohm$ ./avrdude -C avr/etc/avrdude.conf [b]-v -v -v -v -F -t -u -V -B 1000 -patmega32u4 -carduino[/b] -P/dev/cu.usbmodem1451 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xcb:m -Uhfuse:w:0xd8:m -Ulfuse:w:0xff:m
avrdude: Version 5.11, compiled on Sep  2 2011 at 18:52:52
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/Users/kohm/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/cu.usbmodem1451
         Using Programmer              : arduino
         Overriding Baud Rate          : 19200
         Setting bit clk period        : 1000.0
avrdude: Send: 0 [30]   [20]
avrdude: Recv: . [14]
avrdude: Recv: . [10]
         AVR Part                      : ATmega32U4
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PA0
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    10     8    0 no       1024    8      0  9000  9000 0x00 0x00
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
avrdude: Send: A [41] . [80]   [20]
avrdude: Recv: . [02]
avrdude: Send: A [41] . [81]   [20]
avrdude: Recv: . [01]
avrdude: Send: A [41] . [82]   [20]
avrdude: Recv: . [12]
avrdude: Send: A [41] . [98]   [20]
avrdude: Recv: . [00]
         Hardware Version: 2
         Firmware Version: 1.18
         Topcard         : Unknown
avrdude: Send: A [41] . [84]   [20]
avrdude: Send: A [41] . [85]   [20]
avrdude: Send: A [41] . [86]   [20]
avrdude: Send: A [41] . [87]   [20]
avrdude: Send: A [41] . [89]   [20]
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: Send: B [42] . [00] . [00] . [00] . [01] . [01] . [01] . [01] . [03] . [00] . [00] . [00] . [00] . [00] . [80] . [04] . [00] . [00] . [00] . [80] . [00]   [20]
avrdude: Send: E [45] . [05] . [08] . [d7] . [a0] . [00]   [20]
avrdude: Send: P [50]   [20]
avrdude: 1 bytes of lfuse written
avrdude: Send: Q [51]   [20]
  Thank you.
:smiley-confuse:
Title: Re: arduino isp error burning bootloader to fresh atmega32u4
Post by: Peter_n on May 23, 2015, 07:10 pm
Could you try the newest Arduino IDE 1.6.4 and burn the bootloader from within the Arduino IDE.
Are you running this in linux ? I hope you don't use the Arduino IDE 1.0.3 from the repositories.
Do you have something else to program a ATmega chip ? An Arduino Uno perhaps ? I have USBasp version 2, but I had to add a rule for that in linux.
Post by: 2kohm on May 24, 2015, 11:46 pm
hi peter,
i try this in macosx
it is the old release 1.0.3 and with one of my boards all works!?!
this is crazy....
more -v-v debug infos
i use my atmega2560 as arduino isp
http://pastebin.com/1hKQ1x0q
Post by: Peter_n on May 25, 2015, 12:03 am
The communication is going wrong. Reading the lfuse, hfuse, efuse return all three only zero. That is probably a MISO or MOSI signal going bad.
It could be a very thin copper trace that shortcuts something. Or there is something that has a larger capacitance. Of a voltage level from a voltage regulator is slightly different. Or the ATmega32U4 is damaged. Or not enough decoupling capacitors. Or a bad ground wiring.
My best advice is to change as much as possible. An other programmer, other computer, other cables, and so on.
[ADDED] Maybe I'm wrong, and it is as Isaac96 writes in Reply #4. The newer versions of avrdude read the chip settings from the avrdude.conf file.
Post by: Isaac96 on May 25, 2015, 01:17 am
Looks like you don't have a avrdude.conf file or you have the wrong path for it. You could try reburning the other board you have to see if it works. The comms appear to be all right, but your ISP isn't reading the device signature.
Post by: 2kohm on May 25, 2015, 12:09 pm
thank you !!!
i get the same error also inside the arduino IDE if i hit "Burn bootloader"
so i think thr avrdude.conf is ok?
yikies! invaild device signature ;(
i check my HW setup today but again, one off my boards work!
i ordered and USB ISP programmer at ebay and check this also!
what should be inside the avrdude.conf?
Post by: 2kohm on May 25, 2015, 12:19 pm
avrdude is ok, i reuploaded the isp sketch to my mega2560. all ok
maybe i have the wrong commandline?
i read about 100000 times to NOT use the -F flag in avrdude but with -F and -V it looks good except for the fuses ;(
is there any wayni can burn the leonardobootloader using FLIP with Win?
everytime i try to select the HEX file, flip says, wrong checksume, to big file???
Post by: 2kohm on May 25, 2015, 12:30 pm
my board layout
http://www.mikrocontroller.net/attachment/257426/test.jpg
Post by: 2kohm on May 25, 2015, 03:01 pm
i checkt all connections, all ok...
somtimes if i touch the UCAP 1uf i get device signature 0xffffff and not 0x0000
changed usb cabel usb port another pc..
this is wired....
Post by: Peter_n on May 25, 2015, 03:19 pm
You should never use the -F flag. The -v is only extra debug output and that is okay.
When for example a new microcontroller is used, say ATmega328Px and the avrdude only knows the ATmega328P then the -F could be used if they are identical. You should try to find what causes the mismatch of the signatures.
Post by: Isaac96 on May 25, 2015, 03:51 pm
Definitely do not use -F ! It takes away useful info. It does look like you have avrdude.conf. If your device signature returns all zeros, then that usually means a comms problem. You said you have another 32u4 board- can you try reburning the bootloader on that one?
Post by: 2kohm on May 25, 2015, 05:39 pm
thanks for the hint! no more -F
i have some teensy boards, try to flash one with my mega2560 via isp.
i dont want to kill my working prototype but can i not coppy the working chip to another??
Post by: Isaac96 on May 25, 2015, 05:52 pm
You can probably move the chip, if that's what you need.
Post by: 2kohm on May 25, 2015, 05:58 pm
sorry for my bad english ;)
coppy the Software from my working prototype (bootloader and prgramm) in one hex file to another atmega32u4 with Atmels FLIP ?
in flip i see the chip via usb.
but the bootloader is the atmega32uf-DFU?
Post by: 2kohm on May 25, 2015, 08:19 pm
i cant flash the teensy via my atmega ISP - cstk500 not in sync...
i soldered an new prototype, same error :-(
avrdude -c vrdude.conf  -v -v -v -v -pm32u4 -cstk500v1 -P/dev/tty.usbmodem1451 -b19200 -Ulock:w:0x3F:m -Uefuse:w:0xcb:m -Uhfuse:w:0xd8:m -Ulfuse:w:0xff:m
avrdude: Version 6.0.1, compiled on Dec 16 2013 at 17:26:24
        System wide configuration file is "/usr/local/CrossPack-AVR-20131216/etc/avrdude.conf"
        Using Port                    : /dev/tty.usbmodem1451
        Using Programmer              : stk500v1
        Setting bit clk period        : 20.0
        PAGEL                         : PD7
        BS2                           : PA0
        RETRY pulse                   : SCK
        Timeout                       : 200
        StabDelay                     : 100
        CmdexeDelay                   : 25
        SyncLoops                     : 32
        ByteDelay                     : 0
        PollIndex                     : 3
        PollValue                     : 0x53
        Memory Detail                 :
          eeprom        65    20     4    0 no       1024    4      0  9000  9000 0x00 0x00
        Programmer Type : STK500
        Description     : Atmel STK500 Version 1.x firmware
        Hardware Version: 2
        Topcard         : Unknown
        Vtarget         : 0.0 V
        Varef           : 0.0 V
        Oscillator      : Off
        SCK period      : 0.1 us
 . [04] . [d7] . [a0] . [00]   [20]
Reading |                                                    | 0% 0.00savrdude: Send: V [56] 0 [30] . [00] . [00] . [00]   [20]
avrdude: Send: V [56] 0 [30] . [00] . [01] . [00]   [20]
Reading | #################                                  | 33% 0.03savrdude: Send: V [56] 0 [30] . [00] . [02] . [00]   [20]
Reading | | 100% 0.05s
avrdude: Device signature = 0x000000 (retrying)
Reading | #################                                  | 33% 0.04savrdude: Send: V [56] 0 [30] . [00] . [02] . [00]   [20]
Reading | ################################################## | 100% 0.06s
Reading | ################################################## | 100% 0.05s
avrdude: Yikes!  Invalid device signature.
        Double check connections and try again, or use -F to override
        this check.
avrdude done.  Thank you.
Post by: 2kohm on May 25, 2015, 08:24 pm
arduino 1.6
/Users/kohm/Downloads/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Users/kohm/Downloads/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega32u4 -cstk500v1 -P/dev/cu.usbmodem1451 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xcb:m -Uhfuse:w:0xd8:m -Ulfuse:w:0xff:m
avrdude: Version 6.0.1, compiled on Apr 14 2015 at 16:30:25
         System wide configuration file is "/Users/kohm/Downloads/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
         PAGEL                         : PD7
         BS2                           : PA0
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 2
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
         this check.
Post by: 2kohm on May 25, 2015, 08:41 pm
now i was able to set on fuse???
avrdude: safemode: lfuse changed! Was 62, and is now 0
Would you like this fuse to be changed back? [y/n] n
avrdude: safemode: Fuses OK (H:00, E:00, L:62)
http://pastebin.com/VzFPwX3n
Post by: Isaac96 on May 25, 2015, 08:59 pm
Probably a wiring problem. Please post pictures!
Post by: 2kohm on May 25, 2015, 09:23 pm
Schematic
(http://simplecircuits.de/gf/schematic.png)
Atmega2560 as ISP
(http://simplecircuits.de/gf/1.jpg)
My Board ISP Header
(http://simplecircuits.de/gf/2.jpg)
Connection
(http://simplecircuits.de/gf/3.jpg)
Main Atmega32u4 circuit
(http://simplecircuits.de/gf/4.jpg)
Post by: 2kohm on May 25, 2015, 09:38 pm
my atmega2560 ISP the teensy, try to burn bootloader is the same error...
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega32u4 -cstk500v1 -P/dev/cu.usbmodem1451 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xcb:m -Uhfuse:w:0xd8:m -Ulfuse:w:0xff:m
         PAGEL                         : PD7
         BS2                           : PA0
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
         Hardware Version: 2
         Topcard         : Unknown
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
Reading | avrdude: Send: V [56] 0 [30] . [00] . [00] . [00]   [20]
################avrdude: Send: V [56] 0 [30] . [00] . [02] . [00]   [20]
         this check.
Post by: hiduino on May 25, 2015, 10:49 pm
Do you have other components connected to the ISP pins?  They could be loading down the signals.
Post by: Isaac96 on May 25, 2015, 11:46 pm
It seems that your MEGA isn't working as an ISP, if it fails with the Teensy. Can you use the Teensy as an ISP?
If so, you could try that.
Post by: 2kohm on May 26, 2015, 07:26 am
thanks for all the help guys!!!
i get an isp programmer this week and an arduino leonardo form ebay.
i try to use another ISP prgrammer.
no commponents at the isp pins.
this is spooky. dont know how i flashed
my first prototype board ;-)
so my signature fail is def... an isp problem?
Post by: Isaac96 on May 26, 2015, 04:20 pm
Well, can you use a Teensy as a ISP? If possible, use that to ISP your board.
Post by: 2kohm on May 26, 2015, 06:47 pm
avrdude: Device signature = 0x1e9587
THANK YOU ALL <3 great Forum!
the teensy made it on the first run!!! -> h a l l e l u j a h
now i can go to sleep xD
so... my atmega cant ISP the mega32u4?  the mega is working fine... strange
Post by: Peter_n on May 26, 2015, 11:34 pm
sweet dreams  :smiley-sleep:
I'm glad it is working. The Arduino ISP is mostly done with an Arduino Uno.
Post by: 2kohm on May 27, 2015, 10:23 am
thank you peter_n :)
i make my own simple Teensy ISP and  modified isp sketch.
if someone like to have it -> PM me
Post by: Isaac96 on May 30, 2015, 04:23 am
Glad you got it to work! :D
