Arduino Forum
Using Arduino => Microcontrollers => Topic started by: SukkoPera on Jul 23, 2015, 12:27 pm
Title: How exactly slow is digitalRead()?
Post by: SukkoPera on Jul 23, 2015, 12:27 pm
OK, we all know that Arduino sacrifices speed for simplicity and portability, when it comes to reading and writing pin states. I know I can circumvent this with direct port manipulation, but I want to know if I can avoid this to maintain portability to different microcontrollers.
So what I would like to know is exactly how slow digitalRead() is. I can't measure this myself, I tried to look up numbers on the web and I came up with different numbers. I know that it can a different time according to whether the pin has "recently" been used as PWM or not, so let's suppose a simple case where I set a pin as INPUT and just call digitalRead() on it from time to time. Some sources I found state that it takes ~1 us, while others say ~4 us.
Who is right? A figure in the us range will be enough for me.
Title: Re: How exactly slow is digitalRead()?
Post by: mart256 on Jul 23, 2015, 01:06 pm
Depends on the crystal frequency. And how many instructions it takes in assembly to read a pin. You could check on avr forums.
Post by: SukkoPera on Jul 23, 2015, 01:16 pm
Let's take a standard Arduino Uno, so clocked at 16 MHz and using the Arduino libraries.
BTW, I have just noticed the sticked I/O Benchmarks post, it says for the Uno:
Digital Pin Read  Takes About 4.78 Microseconds.
So it seems I have my answer: almost 5 us! Sorry I didn't notice that before :smiley-confuse:.
Post by: jboyton on Jul 23, 2015, 07:06 pm
An alternative is to obtain the port and bit mask with some macros. I think these macros are supported in the various cores. It's slightly slower than direct port access because of the architecture of the AVR chips, but it's a lot faster than digitalRead.
    #define MY_PIN    8
    // do this once at setup
    uint8_t myPin_mask = digitalPinToBitMask(MY_PIN);
    volatile uint8_t *myPin_port = portInputRegister(digitalPinToPort(MY_PIN));
    // read the pin
    uint8_t pinValue = (*myPin_port & myPin_mask) != 0;
There's no doubt a nicer way to dress this up.
DigitalWrite is also slow. You can do the same thing except use portOutputRegister() instead.
Post by: robtillaart on Jul 23, 2015, 07:26 pm
if you know the pin number at compile time you can optimize a lot.
if the pin number is not known ...
check - http://forum.arduino.cc/index.php?topic=46896.0 -
Post by: Peter_n on Jul 24, 2015, 05:27 am
A single I/O instruction is 0.125us. The ATmega chip is optimized for single I/O bit instructions.
A digitalRead() is about 3.6us. That is without the time for the iteration/loop. The 4.78us is with the iteration/loop included.
Using the digitalPinToPort() and so, will increase the speed a lot. It is not as fast as 0.125us, because a few variables have to be read from memory.
The digital...Fast functions are more or less portable. For fully portability you are stuck with that 3.6us.
Post by: SukkoPera on Jul 24, 2015, 08:08 am
Thanks a lot, Peter, that's what I needed to know. One more question though: all those timings are going to double when running at 8 MHz, right?
Post by: Paul__B on Jul 24, 2015, 09:13 am
Naturally.
The complication is of course, that digitalRead() includes the option of using a variable to select the port.  That includes the overhead of performing a bit shift according to the variable value (essentially a FOR loop) on the mask bit which is used to select the bit.  Then it must perform a zero test in order to determine which value - TRUE or FALSE - to return.
All this is easy but not simple, whereas if you know at compile time, exactly which bit you want and are happy to cope with a zero/ non-zero but probably not specified result, it can be programmed in assembler at lightning (sort of) speed.  The digitalRead() function is almost like using an interpreter.
Post by: SukkoPera on Jul 24, 2015, 09:42 am
Thanks again. Yes, I understand why it is slow and the various ways readings can be sped up, but before going that way I wanted to make sure it was absolutely necessary.
Indeed, it is. I have a signal that I must sample on a 12 us clock. Of course I use an interrupt: it seems it takes about 3 us to enter the handler and 2 more to leave it. If running at 8 MHz, like I plan, that doubles and doesn't leave much time for the actual job :(.
Post by: Riva on Jul 24, 2015, 09:59 am
The benchmark sticky you quoted is not perfect but I figured your normally going to want to act on result from reading so the for-next loop overhead sort of makes up for this.
To sample at that speed I would consider a faster MCU/clock speed as you won't have much time to do anything else. If you supply more details of what you need/want then maybe we can suggest options.
Post by: Peter_n on Jul 24, 2015, 02:30 pm
Super extra awesome interrupt tutorial : http://www.gammon.com.au/interrupts (http://www.gammon.com.au/interrupts)
There is a section: "How long does it take to execute an ISR?"
With 8MHz, you have to double the numbers  :(
Post by: jboyton on Jul 24, 2015, 05:34 pm
Isn't it just one cycle (62.5ns at 16MHz) for reading/writing one of the GPIO ports?
Post by: Peter_n on Jul 24, 2015, 06:49 pm
Try it !
Perhaps the other cycle is loading the constant for a byte to read/write to the port.
Post by: jboyton on Jul 24, 2015, 07:43 pm
Okay. I tried it. It took one cycle to read PINB.
In the context of the rest of a sketch of course there will be overhead. You can't just read a value into a register and call it a day. But if you do it differently, for example by using a pointer to the port instead of an immediate value, it will take more cycles.
Post by: Peter_n on Jul 24, 2015, 07:48 pm
Thanks for testing that  8)
Two two cycles is probably not the constant for the bit, but storing the value into a variable.
Post by: jboyton on Jul 24, 2015, 08:36 pm
It depends, doesn't it? In isolation it's just one cycle. And if you do the same thing but address the port indirectly instead it's going to take longer, at least with an AVR processor.
I have some code that I originally wrote to use pin numbers defined in the library header file. That way the port accesses would be via immediate values. But in the Arduino environment having values in the header files makes it hard to go from one sketch to the next where the pins might different. So I rewrote it to use values passed in the constructor. That ultimately meant that the ports were addressed indirectly, even though technically the pin numbers were known at compile time -- just not library compile time. And it affected the performance.
Post by: SukkoPera on Jul 28, 2015, 05:43 pm
Sorry for the delay, but I have some news!
First of all, what I'm doing is snooping the NES Controller Protocol (Which is based on a CD4021 shift register as probably everybody knows, see here: http://www.mit.edu/~tarvizo/nes-controller.html). I'm not just trying to drive a pad connected to the Arduino, I'm rather intercepting the signals while the console is running, and they're pretty fast.
I have no problems doing that on a 16 MHz Arduino, even digitalRead() works fine (provided that I use an interrupt to detect clock transitions) but my final objective is to create a sort of modchip to install in the console, so the least components, the better. This means that I would happily avoid the crystal, so I am trying to get things running fine at 8 MHz. It would even be better to use a smaller MCU in the end, my ideal target being the ATtiny84.
But at 8 MHz detection isn't reliable. I have tried different strategies (direct port manipulation, register variables, different interrupts, etc...), but it seems that the code is always too slow and drags behind the strict timing required. The best result I could get was getting only the first 4 buttons read correctly (over 8 ).
But yesterday I discovered SPI! I spent some time with it and got it working easily on the '328. I used the much neglected (on the Arduino) slave mode, since everything is being driven by the console. Then I switched to the '84 and I found out that there's no ready-made library and that it doesn't have real hardware SPI, then I found Atmel's Technical Note about USI and managed to get something working on the '84 as well. It's not complete yet, and I'm not sure it will work 100% (it's hard to debug without a Serial Console), but results are promising so far.
So I guess we are a bit out of topic by now, but anyway... Any hints?
Post by: Riva on Jul 28, 2015, 06:06 pm
The tiny85 has a PLL clock mode so you can run it at something around 16MHz with no external xtal. Maybe it will do the job or another similar mode chip?
Post by: SukkoPera on Jul 28, 2015, 10:14 pm
Interesting! But the '84 doesn't have that, right? Too bad, I already had in mind a version for the '85 but I don't think I will be able to squeeze all the features in :smiley-confuse:.
What do you mean with "another similar mode chip"?
Post by: jboyton on Jul 28, 2015, 10:30 pm
The ATtiny84 doesn't have that PLL, but you can rev up the internal oscillator to around 14MHz, give or take:
(http://s21.postimg.org/w451jeoav/ATtiny84_OSCCAL.png)
The Tiny chips also lack a MUL instruction. Depending on what you're doing that can have a noticeable effect on execution time.
Post by: rogerClark on Jul 29, 2015, 04:04 am
If you really need more performance, I'd advise you switch to using an ARM based processor
Arduino have recently released the Zero, and the Due has been around for ages, both of which are significantly faster than the 16Mhz AVR's
There are also various other third party options including the Teensy, STM32F103 based boards and also PIC32, all of which have options to develop using the Arduino IDE
However, one note of caution, ARM boards are 3.3V and also, not all libraries have been ported to ARM (though Teensy have a lot of libs ported by Paul who developed the Teensy)
My personal favourite in terms for value for money is the STM32 Maple Mini board.
Post by: SukkoPera on Jul 29, 2015, 10:52 am
@rogerClark: Thanks for your advice, but if you read my last post you'll see that a Due doesn't meet basically any of my requirements :D.
@jboyton: I don't use MUL, so it will be fine.
Anyway I've experimented a bit more with USI/SPI on the '84 at 8 MHz and it's working really really well, *never* missing a shot. It actually works much better than I expected, and I wonder how this can be possible for at least two reasons:
BTW, the '84 with its USI even has some advantage over the full SPI implementation of the '328 for me as I actually have no SS signal: USI does not implement SS, so it just works, but on the '328 you actually have to bring down SS to let the hardware do the job. The only signal I can use for the matter is the LATCH signal, which goes UP and just for a BIT at the beginning of a transfer (while SS is active low and should be kept low for the whole transfer), so I have to catch it with an interrupt and drive SS through another pin, which means more connections and more work!
Post by: eddiea6987 on Jul 30, 2015, 04:59 pm
you can blink an led with no delay with arduino code  and check it out with a scope...
then do the same via direct port manipulation and check that out with a scope ...
then multiply the frequency reading  by two since its one command to turn on and one to turn off ..
 then you can get a more real world idea of the speed difference .
If you do go into ARM i recommend using Atmel Studio , their ASF makes using the Cortex very easy and a lot less overhead then Arduino code . Its a good way to get to learn the chip
Post by: eddiea6987 on Jul 30, 2015, 05:03 pm
Here is a video of the blink led and measuring the frequency ... YOUTUBE (https://www.youtube.com/watch?v=uD6e7FbEqBA)
he starts at around 4 minutes or something
