Arduino Forum
Forum 2005-2010 (read only) => Software => Troubleshooting => Topic started by: mrbbp on Mar 17, 2006, 12:26 am
Title: strange behavior on my prog !
Post by: mrbbp on Mar 17, 2006, 12:26 am
Hi all,
well i've made a small prog base on the LCD Display tuto.
The soft is quite simple, it's like a calendar.
it write on the LCD a date like "lundi dix-sept janvier deux mille deux" (it's in french, but this is not really important)
strangely, the word "fevrier" doesn't appear in the sentence.
the soft write the month only at "mars" and other month but not february !!!!
if i delete "sAnnee" declaration, the prog doesn't work any more. (it's not in use in the prog)
have you an idea ?
i add a printString() by the serialport  to debugg.
would you try my prog and tell me if there is the same prob (with "fevrier") on your board.
I suppose there is an init prob with the vars... but why ! not enough memory ?
or have made a bad declaration ?
oh, it delete "janvier" too !
best regards
eric
//boolean b;
int RS = 12;
int RW = 11;
int DB[] = {3, 4, 5, 6, 7, 8, 9, 10};
int Enable = 2;
// init poeme
int jour = 0;
int nJour = 17;
int mois = 2;
int an = 2;
char chaine[65] = " ";
char ligne[0x10] = "";
int jMax[] = {0,31,28,31,30,31,30,31,31,30,31,30,31};
const char *sNomJour[7] = {"dimanche", "lundi", "mardi", "mercredi", "jeudi", "vendredi", "samedi"};
const char *sJour[33] = {"", " premier", " deux", " trois", " quatre", " cinq", " six", " sept", " huit", " neuf", " dix", " onze", " douze", " treize", " quatorze", " quinze", " seize", " dix-sept", " dix-huit", " dix-neuf", " vingt", " vingt-et-un", " vingt-deux", " vingt-trois", " vingt-quatre", " vingt-cinq", " vingt-six", " vingt-sept", " vingt-huit", " vingt-neuf", " trente", " trente-et-un", " mille"};
const char *sMois[13] = {"", " janvier", " fevrier", " mars", " avril", " mai", " juin", " juillet", " aout", " septembre", " octobre", " novembre", " decembre"};
const char *sAnnee[8] = {"", ""," deux mille deux", " deux mille trois", " deux mille quatre", " deux mille cinq", " deux mille six"};
void LcdCommandWrite(int value) {
 int i = 0;
 for (i=DB[0]; i <= RS; i++) {
   digitalWrite(i,value & 01);
   value >>= 1;
 digitalWrite(Enable,LOW);
 delayMicroseconds(1);
 // send a pulse to enable
 digitalWrite(Enable,HIGH);
void LcdDataWrite(int value) {
 // poll all the pins
 int i = 0;
 //delay(25);
 //printInteger(value);
 //printNewline();
 digitalWrite(RS, HIGH);
 digitalWrite(RW, LOW);
 for (i=DB[0]; i <= DB[7]; i++) {
   value >>= 1;
void lcdGotoXY (int x, int y) {
 // depend of your LCD datasheet DDRAM adress
 int DDRAMadresses[]={0x80, 0xC0, 0x90, 0xD0}; // it's a 4X16 LCD DISPLAY
 int i, value;
 digitalWrite(RS, LOW);
 value = DDRAMadresses[x-1]+y;
   value >>= 1;
void printStringLCD(unsigned char *s)
 while (*s)
   LcdDataWrite(*s++);
void setup (void) {
 int i = 0;
 beginSerial(115200);
 for (i=Enable; i <= RS; i++) {
   pinMode(i,OUTPUT);
 delay(100);
 LcdCommandWrite(0x30);
 delay(64);
 delay(50);
 delay(20);
 LcdCommandWrite(0x38);
 delay(20);
 LcdCommandWrite(0x6);
 //LcdCommandWrite(0x07);
 delay(20);
 LcdCommandWrite(0xE);
 delay(20);
 LcdCommandWrite(0x1);
 delay(100);
 LcdCommandWrite(0x80);
 delay(20);
void loop (void) {
 int i = 0;
 int j = 0;
 delay(4000);
 delay(10);
 LcdCommandWrite(0x2);
 delay(10);
 if (jour > 6) {jour = 0;}
 if (nJour > jMax[mois]) {nJour = 1; mois++;}
 if (mois == 2 && an == 3) { jMax[2] = 29;} else { jMax[2] = 28;}
 if (mois > 12) {mois = 1; an++;}
 // concatenation des chaines
 chaine[64] = " ";
 strcpy(chaine, sNomJour[jour]); // dimanche
 strcat(chaine, sJour[nJour]); // dix-sept
 strcat(chaine, sMois[mois]); // Février
 strcat(chaine, sJour[2]); // deux
 strcat(chaine, sJour[32]);// mille
 strcat(chaine, sJour[an]); // deux
 printString(chaine);
 printNewline();
 jour++;
 nJour++;
 // ecriture des lignes
 lcdGotoXY(1, 0);
 strncpy(ligne,chaine,16);
 if (strlen(ligne) >= 16) {
   ligne[16] = '\0';
 // ecrit la ligne
 printStringLCD(ligne);
 delay(100);
 /*printInteger(an);
 printNewline();*/
 *ligne=" ";
 for (i=2; i<=4;i++) {
   lcdGotoXY(i, 0);
   strncpy(ligne,&chaine[16*(i-1)],16);
     ligne[16] = '\0';
   // ecrit la ligne
   delay(100);
   *ligne=" ";
Title: Re: strange behavior on my prog !
Post by: mellis on Mar 17, 2006, 11:14 am
You may be running out of RAM on the ATmega8 (it only has 1KB).  Since your strings never change, you could try storing them only in program Flash memory (instead of RAM).  See:
http://www.nongnu.org/avr-libc/user-manual/FAQ.html#faq_rom_array
Post by: mrbbp on Mar 17, 2006, 11:34 pm
Thank you Mellis...
i'll try your link.
a question: can we change the atmega16 for an atmega32 :
in the datasheet, the pin are the same... with 2K ram ?
have to burn the bootloader...
regards
eric
Post by: mrbbp on Mar 18, 2006, 02:52 am
oops sorry.
it's atmega8 only 20 pins no 40 pins...
i suppose this is complex but can we add more ram :-? to the avr or do we need to change the microcontroler ?
i'm a bit confuse between the ram, the eeprom and the flash
the flash is to store the prog, the ram to store the vars and the eeprom ?
have you a link to help ? :-[
regards
eric
Post by: admin on Mar 18, 2006, 08:37 am
hello
just to clarify a bit. There are three types of memory in the atmega8:
* Flash memory: it's a rewritable non-volatile memory. this means that its content will still be there if you turn off the power. it's a bit like the hard disk on the arduino board. your program is stored here.
* RAM: it's like the ram in your computer.its content disappears when you turn of the power but it can be read and writter really fast.
* EEPROM: it's an older technology to implement rewritable non-volatile memory. it's normally used to store settings and other parametres.
remember that only a few years ago flash memory was expensive and very few microcontroller had one. it was common to use OTP memory, which is a type of memory that can ony be written once and can't be reporgrammed anymore. in this situation if you want to store settings or parametres you need an EEPROM.
Lastly when you desing  a product, let's say an egg timer, that you manufacture in large quantity it is normal to buy the processors pre programmed (masked) by the factory. in this case not even a nuclear explosion will change the content of the program and the eeprom comes handy.
The link that mellis sent you allows you to use the program memory to store arrays which is very useful. We're using this technique to store strings for a UI prototype we're building for an appliance manufacturer.
hope this cleared the air a bit :)
Post by: mrbbp on Mar 19, 2006, 06:37 pm
Well thanks for helps...
i've try this code... from your link
#include <avr/pgmspace.h>
PGM_P array[2] PROGMEM = {
   "Foo",
   "Bar"
void loop ()
   char buf[32];
   strcpy_P (buf, array[1]);
   return 0;
and have received this error ;
"unexpected token:array" :-/
don't know !
i've tried the second exemple, same result :
"unexpected token:const"
do i need to add pgmspace.h somewhere ?
regards
eric
Post by: mbanzi on Mar 20, 2006, 10:05 am
hmm it's a tricky issue
it's a problem with include files and the rest
I have to do some tests with C files before..
I need a few days because we are very very very busy at the moment..
massimo
Post by: mrbbp on Mar 20, 2006, 01:11 pm
No prob massimo :-[
take your time.
I'll be patient.
thanks for your help
eric
Post by: leKuk on Apr 14, 2006, 06:31 pm
hi guys,
i'm wondering if you figured this out in the meantime!?
as documented in another thread, i am interfacing a graphical LCD.
The original code (threw in by massimo) defines the ASCII characters in pixels.
like that:
static const byte FontLookup [][5] =
   0x7E, 0x11, 0x11, 0x11, 0x7E     }
 ,   // A
   0x7F, 0x49, 0x49, 0x49, 0x36     }
 ,   // B
   0x3E, 0x41, 0x41, 0x41, 0x22     }
 ,   // C
   0x7F, 0x41, 0x41, 0x22, 0x1C     }
    //D
using this code the array is stored in RAM right? or is it in the flash memory??? (BTW what does the "static const" declaration do exactly?)
since every character takes 5 Bytes of memory and there are 95 printable ascii characters, i'm constantly running out of memory when working on the code. those 512 bytes of eeprom would come very handy!
is there a way to put all those pixel bytes into the eeprom using the ide? if i understand it right, the bootloader just copies the program into the flash-memory. is the bootloader able to write into eeprom at all?
i know i could copy the bytes from the RAM to the EEPROM using eeprom_write_byte(adr,val); but as it looks i'm not even able to get the program up running with *every* ascii character describe. :-(
another question:
is the eeprom used for anything when doing *normal* arduino stuff (no fancy c)? as a buffer for serial communication or something? or some debugging data maybe? just because it wasn't empty when i first accessed it for testing.
hope to hear from you.
i whish you all a nice easter weekend.
kuk
Post by: mrbbp on Apr 14, 2006, 07:00 pm
"static const byte FontLookup [][5] ="
static : that mean the compiler attribute a fixed adress in ram
constant : that doesn't vary along the prog !
byte : this is the type of your constant...
i think the solution of your prob, is the same of mine...
we have to wait a bit more for a solution.
put your patience under your foot and wait ::)
my two pences...
eric
Post by: mbanzi on Apr 14, 2006, 07:40 pm
Eric
can you try this code??
const char *sNomJour[7]   __attribute__((section(".eeprom"))) = {"dimanche", "lundi", "mardi", "mercredi", "jeudi", "vendredi", "samedi"};
beginSerial(9600);
  printString(sNomJour[2]);
not sure it's going to work but I forced the program to store the array in the eeprom
can you try this technique with your code?
see if it solves the problem
massimo
Post by: mrbbp on Apr 14, 2006, 08:15 pm
i've tried this :
const char *sJour[33]   __attribute__((section(".eeprom"))) = {"", " premier", " deux", " trois", " quatre", " cinq", " six", " sept", " huit", " neuf", " dix", " onze", " douze", " treize", " quatorze", " quinze", " seize", " dix-sept", " dix-huit", " dix-neuf", " vingt", " vingt-et-un", " vingt-deux", " vingt-trois", " vingt-quatre", " vingt-cinq", " vingt-six", " vingt-sept", " vingt-huit", " vingt-neuf", " trente", " trente-et-un", " mille"};
and have as result
mercrediü fevrierüü
jeudir fevrierüü
vendredi¨ fevrierüü
samedi fevrierüü
dimanche fevrierüü
i've tried this :
result :
ç dix-sept fevrier deux mille deux
t dix-huit fevrier deux mille deux
ü dix-neuf fevrier deux mille deux
vingt fevrier deux mille deux
vingt-et-un fevrier deux mille deux
i think this not the good solution :'(
regards
eric
Post by: leKuk on Apr 15, 2006, 12:59 am
i can't get it work neither.
i don't think that this line writes anything to eeprom
i read out the eeprom in the main loop function afterwards but it always showed the values that i put there the run before.
      int EEadr;
     for ( EEadr=0;  EEadr<512;  EEadr++){
       value1 = eeprom_read_byte(EEadr);
       printInteger(EEadr);
       printByte(62); //">"
       printHex(value1);
       printNewline();
    // eeprom_write_byte(EEadr,0xDD); //uncommented in the second run
is giving out 0xDD for all addresses.  :-/
Post by: mrbbp on May 04, 2006, 11:49 pm
hello,
i've find in avrfreak forum a thread about how to put cosntant in flash...
http://www.avrfreaks.com/index.php?name=PNphpBB2&file=viewtopic&t=36339&highlight=enough+ram+var&sid=ac0aaea81038b29246ff1a3bb17834a7
but i'm not sure to understand with my poor knowledge... :-[ do you think it works ?
and what code do the trick :-/
sorry...
any help will be cool... :-*
eric
