Arduino Forum
Using Arduino => Interfacing w/ Software on the Computer => Topic started by: falexandru on Jul 17, 2017, 11:34 am
Title: Can be Arduino IDE installed on PC Pentium II?
Post by: falexandru on Jul 17, 2017, 11:34 am
Procesor Dual Core 1,8 GHz
Memory RAM 1Gb
HDD - 80 GB
Linux Ubuntu
Thank you!
Title: Re: Can be Arduino IDE installed on PC Pentium II?
Post by: horace on Jul 17, 2017, 12:29 pm
I have the IDE running on a Intel Core 2 6600 @ 2.4MHz, 2G RAM 146Mbyte hard disk  under Windows XP SP 3
Post by: falexandru on Jul 17, 2017, 12:39 pm
Thank you, Horace!
I guess the PC uses an USB 1.1., right?
On what Arduino do you connect it, please?
Post by: horace on Jul 17, 2017, 12:57 pm
the PC is a DELL OptiPlex 745 with USB 2.0
at  the moment it is connected to an Arduino Nano monitoring an experiment
on the PC I use C# with Visual Studio Express 2010 to communicate with the Arduino and display results
Post by: Robin2 on Jul 17, 2017, 01:35 pm
Have you tried it?  What happened.?
What version of Ubuntu are you using?
My guess is that it should be just fine - the IDE is just a Java program. There is very little to installing it. Download the version you want. Copy it to the directory you want. Extract the ZIP and enjoy.
...R
Post by: Nick_Pyner on Jul 17, 2017, 05:24 pm
Memory RAM 1Gb
HDD - 80 GB
Linux Ubuntu
The IDE will run on practically anything and, with a powerhouse like that, you can't go wrong. If you are having problems, it can hardly be your computer, unless it is actually faulty. Otherwise, you might look to the installation.
Post by: falexandru on Jul 17, 2017, 08:53 pm
Ok, thank you!
