Arduino Forum
Forum 2005-2010 (read only) => Software => Troubleshooting => Topic started by: jhonray on Jan 17, 2011, 08:10 pm
Title: frequencyTimer2 problem
Post by: jhonray on Jan 17, 2011, 08:10 pm
can someone help me..... i have a problem about timer2.. and this are the following problems.... so please help me i need it now... huhuhu.. how can i fix it..
C:\Program Files\arduino-0021\libraries\FrequencyTimer2\FrequencyTimer2.cpp: In static member function 'static void FrequencyTimer2::enable()':
C:\Program Files\arduino-0021\libraries\FrequencyTimer2\FrequencyTimer2.cpp:150: error: 'TCCR2' was not declared in this scope
C:\Program Files\arduino-0021\libraries\FrequencyTimer2\FrequencyTimer2.cpp:150: error: 'COM20' was not declared in this scope
C:\Program Files\arduino-0021\libraries\FrequencyTimer2\FrequencyTimer2.cpp: In static member function 'static void FrequencyTimer2::disable()':
C:\Program Files\arduino-0021\libraries\FrequencyTimer2\FrequencyTimer2.cpp:160: error: 'TCCR2' was not declared in this scope
C:\Program Files\arduino-0021\libraries\FrequencyTimer2\FrequencyTimer2.cpp:160: error: 'COM20' was not declared in this scope
Title: Re: frequencyTimer2 problem
Post by: Coding Badly on Jan 17, 2011, 08:13 pm
Which board is selected in the Arduino IDE?
Post by: jhonray on Jan 17, 2011, 08:18 pm
arduino duimelanove/ nano w/ atmega328..
Post by: Coding Badly on Jan 17, 2011, 08:35 pm
http://www.google.com/search?q=frequencytimer2+328+arduino
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1239820770
 FrequencyTimer2.h - A frequency generator and interrupt generator library
 Author: Jim Studt, jim@federated.com
 Copyright (c) 2007 David A. Mellis.  All right reserved.
 This library is free software; you can redistribute it and/or
 modify it under the terms of the GNU Lesser General Public
 License as published by the Free Software Foundation; either
 version 2.1 of the License, or (at your option) any later version.
 This library is distributed in the hope that it will be useful,
 but WITHOUT ANY WARRANTY; without even the implied warranty of
 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
 Lesser General Public License for more details.
 You should have received a copy of the GNU Lesser General Public
 License along with this library; if not, write to the Free Software
 Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
#include <FrequencyTimer2.h>
#include <avr/interrupt.h>
void (*FrequencyTimer2::onOverflow)() = 0;
uint8_t FrequencyTimer2::enabled = 0;
#if defined(__AVR_ATmega168__) || defined(__AVR_ATmega328P__)
SIGNAL(SIG_OUTPUT_COMPARE2A)
#else
SIGNAL(SIG_OUTPUT_COMPARE2)
#endif
   static uint8_t inHandler = 0; // protect us from recursion if our handler enables interrupts
   if ( !inHandler && FrequencyTimer2::onOverflow) {
     inHandler = 1;
     (*FrequencyTimer2::onOverflow)();
     inHandler = 0;
void FrequencyTimer2::setOnOverflow( void (*func)() )
   FrequencyTimer2::onOverflow = func;
   if ( func) TIMSK2 |= _BV(OCIE2A);
   else TIMSK2 &= ~_BV(OCIE2A);
#else
   if ( func) TIMSK |= _BV(OCIE2);
   else TIMSK &= ~_BV(OCIE2);
#endif
void FrequencyTimer2::setPeriod(unsigned long period)
   uint8_t pre, top;
   if ( period == 0) period = 1;
   period *= clockCyclesPerMicrosecond();
   period /= 2;            // we work with half-cycles before the toggle
   if ( period <= 256) {
     pre = 1;
     top = period-1;
   } else if ( period <= 256L*8) {
     pre = 2;
     top = period/8-1;
   } else if ( period <= 256L*32) {
     pre = 3;
     top = period/32-1;
   } else if ( period <= 256L*64) {
     pre = 4;
     top = period/64-1;
   } else if ( period <= 256L*128) {
     pre = 5;
     top = period/128-1;
   } else if ( period <= 256L*256) {
     pre = 6;
     top = period/256-1;
   } else if ( period <= 256L*1024) {
     pre = 7;
     top = period/1024-1;
     pre = 7;
     top = 255;
   TCCR2B = 0;
   TCCR2A = 0;
   TCNT2 = 0;
   ASSR &= ~_BV(AS2);    // use clock, not T2 pin
   OCR2A = top;
   TCCR2A = (_BV(WGM21) | ( FrequencyTimer2::enabled ? _BV(COM2A0) : 0));
   TCCR2B = pre;
#else
   TCCR2 = 0;
   TCNT2 = 0;
   OCR2 = top;
   TCCR2 = (_BV(WGM21) | ( FrequencyTimer2::enabled ? _BV(COM20) : 0)  | pre);
#endif
unsigned long  FrequencyTimer2::getPeriod()
   uint8_t p = (TCCR2B & 7);
   unsigned long v = OCR2A;
#else
   uint8_t p = (TCCR2 & 7);
   unsigned long v = OCR2;
#endif
   uint8_t shift;
   switch(p) {
     case 0 ... 1:
     shift = 0;
     break;
     case 2:
     shift = 3;
     break;
     case 3:
     shift = 5;
     break;
     case 4:
     shift = 6;
     break;
     case 5:
     shift = 7;
     break;
     case 6:
     shift = 8;
     break;
     case 7:
     shift = 10;
     break;
   return (((v+1) << (shift+1)) + 1) / clockCyclesPerMicrosecond();   // shift+1 converts from half-period to period
   FrequencyTimer2::enabled = 1;
   TCCR2A |= _BV(COM2A0);
#else
   TCCR2 |= _BV(COM20);
#endif
   TCCR2A &= ~_BV(COM2A0);
#else
   TCCR2 &= ~_BV(COM20);
#endif
Post by: jhonray on Jan 17, 2011, 08:54 pm
another problem occur... like
In file included from C:\Program Files\arduino-0021\hardware\arduino\cores\arduino/WProgram.h:6,
                from sketch_jan26a.cpp:70:
c:/program files/arduino-0021/hardware/tools/avr/lib/gcc/../../avr/include/math.h:439: error: expected unqualified-id before 'double'
c:/program files/arduino-0021/hardware/tools/avr/lib/gcc/../../avr/include/math.h:439: error: expected `)' before 'double'
Post by: Coding Badly on Jan 17, 2011, 09:01 pm
#ifndef FREQUENCYTIMER2_IS_IN
#define FREQUENCYTIMER2_IS_IN
[glow]//[/glow]#include <wiring.h>
[glow]#include <WProgram.h>[/glow]
class FrequencyTimer2
 private:
   static uint8_t enabled;
 public:
   static void (*onOverflow)(); // not really public, but I can't work out the 'friend' for the SIGNAL
 public:
   static void setPeriod(unsigned long);
   static unsigned long getPeriod();
   static void setOnOverflow( void (*)() );
   static void enable();
   static void disable();
#endif
Post by: jhonray on Jan 18, 2011, 09:37 am
sir.. where do i put that code?... confusing..
