Arduino Forum
Using Arduino => General Electronics => Topic started by: Halayman on May 25, 2018, 12:07 pm
Title: TC74 not recognized in SigFox MKRFOX1200
Post by: Halayman on May 25, 2018, 12:07 pm
Hi all,
I want to make temperature monitor using SigFox MKRFOX1200 and sensor TC74 A0 3.3V
I want to be sure of the connections as I  made many trails and the sensor is not recognized ...
I connected:
 SDA in sensor to SDA(pin 11) in the kit
 SCLK in sensor to SCL(pin 12)in kit
I use pull up resistors between the Voltage (I tried 5 Volt and 3 and 4.5 and Vcc ) and the SDA and SCL
I read that the range should be between 2-10 kilo Ohm so I tried many values in this range and still not recognized
I even got a newer sensor coz i thought i might have damaged my sensor..
If anybody can figure out what is  the problem I will be sooo grateful
Thanks in advance
Title: Re: TC74 not recognized in SigFox MKRFOX1200
Post by: Halayman on May 26, 2018, 10:48 am
Hi
It worked when I used :
1. Two parallel resistors each 5kohm and connected them between SDA and 5volt
2. Two parallel resistors each 5kohm and connected them between SCL and 5volt
3. Connected the sensor to the 5 V pin in the kit
Have a nice day :)
Post by: Grumpy_Mike on May 27, 2018, 12:46 am
It worked when I used :.....
So you must have disturbed the wiring to correct something because there is no way using pull up resistors on Arduino outputs will make any difference. Also even if it did then using two 5K resistors ( a none standard value ) would be no difference from using a 2L to 3K resistor which you said you tried in the first post.
So it might be working but not because of what you did intentionally.
Post by: Wawa on May 27, 2018, 06:06 am
Don't use pull up resistors to 5volt on a 3.3volt processor.
