Arduino Forum
Topics => Device Hacking => Topic started by: ElectronicNoob on Jul 10, 2018, 06:36 pm
Title: Reversing calculator keypad
Post by: ElectronicNoob on Jul 10, 2018, 06:36 pm
Hi, I just dissasembled a calculator and wanted to connect the keypad to my arduino. Honestly I have no clue how to do that. I think I know the idea behind matrix keypads, but the keypad works bit different.
The only things I know:
-The keypad is piece of paper
-There is specially crafted rubber pad, that helps to make connection between paper and finger
-The keypad is connected via 11 pin FFC/FPC
-There are 25 keys on the keypad
-I have no success with checking conductivity between each pin pair with pressed button
Does anybody have any tips that would help connect the keypad with mine microcontroller?
Images:
Front:
(https://i.imgur.com/slq0bTa.jpg)
Back:
(https://i.imgur.com/gE4CI8Jg.jpg)
Title: Re: Reversing calculator keypad
Post by: Paul_KD7HB on Jul 10, 2018, 07:36 pm
Images:
Front:
Back:
Explain your method of testing the conductivity. The rubber contacts are carbon filled, so are resistors. The printed contact pads have infinite resistance until a rubber pad is pressed onto it. Then the resistance will no longer be infinite. Over time these things stop working for various reasons.
Is such a keyboard usable with an Arduino? Depends on the resistance you read with your ohmmeter when the pad is pressed down. Pressure also has a bearing on the resistance.
Paul
Post by: ElectronicNoob on Jul 10, 2018, 09:07 pm
Firstly, thanks for the answer.
The first method I was trying was to remove the secure thing from the FPC tape, then put ohmmeter probes between pin 1 and 2, then move the second probe from pin 2 to pin 3, 4, 5 and so on, before every probe move i was trying to press every button and check for connection, just like in casual matrix keypad but as I said it gave no results.
Now i attached the probes like on the image:
(https://i.imgur.com/aLrSyVU.png)
Normally the ohmmeter shows about 20M Ohm, when i press some buttons it drops to 5M Ohm, but I'm not sure if it's measurement error because i need to hold the paper upside-down. I probably need an FPC connector to get reliable results.
Am I measuring it in wrong way?
Post by: Paul_KD7HB on Jul 10, 2018, 09:14 pm
Your measurements seem pretty normal for that type keyboard.
Paul
Post by: ElectronicNoob on Jul 10, 2018, 09:26 pm
So, if these measurements are correct is the 5M Ohm value good enough? If so how can I recognize which key was pressed? I assume that it works quite different from the casual matrix keypads, because there are actually 11 pins on the keypad, while there are 5 rows and 5 columns
Post by: Paul_KD7HB on Jul 10, 2018, 09:55 pm
It is not usable without some type of interface circuitry to convert the change from 20meg to 5 meg into some value, either 0 volts or 5 volts. I am not engineer enough to conceive of such a circuit.
Paul
