Arduino Forum
Using Arduino => Sensors => Topic started by: Bigginger61 on Dec 06, 2018, 10:47 pm
Title: Grove LCD interfering with DHR11 sensor
Post by: Bigginger61 on Dec 06, 2018, 10:47 pm
I have an Arduino Leonard with Grove Base Sheild. I wrote code to read the sensors temperatire and humidity readings and read them via the serial monitor.
Seperate to that I obtained the Grove LCD panel and succesfully ran the "Hellow World" code. Howver when I combine the code the sensor readings are not taken, If I rematk out the LCD related code the sensor
works.
The grove DHT11 sensor is connected to a D2 port on the shiled and the LCD to one of the I2c ports.
I combined code is below, can anyone please guide me towards a solution.
// Code to read a temperature and humidity sensor and send the reading to the serial monitor and an LCD
// Ultimately I want to control a heater via a relay.
// Load in the DHT library
#include "DHT.h"
#define DHTPIN 2     // what pin we're connected to
#define DHTTYPE DHT11   // DHT 11 - identify the type of sensor
#include <Wire.h>
#include "rgb_lcd.h"
// Define Global variabals
float maxTemp = 0;
float minTemp = 200; // start reading
float maxHumidity = 0;
float minHumidity = 200;  // start reading
float currentTemp = 0;
float currentHumidity = 0;
float triggerTemp = 0; // The temp and which the relay needs to be tripped
long readingInterval = 2000;  //Sensor reading interval 1000 = 1 second
long counter = 0;
const int colorR = 255;
const int colorG = 0;
const int colorB = 0;
DHT dht(DHTPIN, DHTTYPE);
rgb_lcd lcd;
// Set Up
  // set up the serial monitor for debugging
  Serial.println("DHTxx test!");
  dht.begin();
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  lcd.setRGB(colorR, colorG, colorB);
// Main Loop
  GetTemp();                //Get the temperature and humidity readings
  UpdateMaxMin();           //Update Max Min temps
  MinTempAlarm();           //Check for low temp
  PrintToMonitor ();        //Print dat in the serail monitior
  PrintToLED();
void GetTemp() {
  // Get the readings from the sensor
  float h = dht.readHumidity();
  float t = dht.readTemperature();
  // transfer the value of the local variable h and t to global varaiables
  // to make them avaialble in the other sub routines
  currentTemp = t;
  currentHumidity = h;
void PrintToMonitor() {
  // Print the readings to the serial monitor
  Serial.println(" ");
  Serial.print("Reading Number: ");
  Serial.println(counter);
  Serial.println("----------------------- ");
  Serial.print("Curr Humidity : ");
  Serial.print(currentHumidity);
  Serial.println(" %\t");
  Serial.print("Max  Humidity : ");
  Serial.print(maxHumidity);
  Serial.print("Min  Humidity : ");
  Serial.print(minHumidity);
  Serial.print("Curr Temp     : ");
  Serial.print(currentTemp);
  Serial.println(" *C");
  Serial.print("Max  Temp     : ");
  Serial.print(maxTemp);
  Serial.print("Min  Temp     : ");
  Serial.print(minTemp);
  delay(readingInterval);
void UpdateMaxMin() {
  //Update the max and min temps and humidity readings
  if (currentTemp >= maxTemp) {
    maxTemp = currentTemp;
  if (currentTemp <= minTemp) {
    minTemp = currentTemp;
  if (currentHumidity >= maxHumidity) {
    maxHumidity = currentHumidity;
  if (currentHumidity <= minHumidity) {
    minHumidity = currentHumidity;
  counter = counter + 1;
void MinTempAlarm() {
  if (minTemp <= triggerTemp) {
    Serial.println("Turn the bloody heater on!!!");
void PrintToLED() {
  // set the cursor to column 0, line 1
  lcd.setCursor(0, 0);
  //print the current temperature
  lcd.print("Current Temp ");
  lcd.print(currentTemp);
  delay(100);
Title: Re: Grove LCD interfering with DHR11 sensor
Post by: pylon on Dec 07, 2018, 03:33 pm
D2 is internally connected to SDA on the Leonardo. Use another pin for the DHT sensor!
Post by: Bigginger61 on Dec 07, 2018, 10:35 pm
Thanks Pylon, I switched Pin 4 and it as all working now.
